    Reputation: biketuna's Avatar
    IBIS SL-R angleset queastion
    If I put a EC49 1 degree on the bottom and a EC44 1 degree on top will this get me 2 degrees total?
    _______________
    1x10 IS SO FINE on my 21.9 lbs IBIS SL-R
    11-36 XTR in the rear, 36T wide-narrow upfront
    Reputation: getbusyliving's Avatar
    Quote Originally Posted by biketuna View Post
    Sorry this doesn't answer your specific question, but just FYI I have heard from a couple buddies who run the Angleset that they have had consistent creaking issues. Evidently can be quite a bit more high maintenance than a standard headset.
    Commit or eat sh!t
    Reputation: Cable0guy's Avatar
    I believe that will get you 1* total. If you want to increase head angle more than 1*, you will need to use 1* or 1.5* Angleset plus a fork with higher AC than what Ibis measured their spec bike with (or with offset bushings or shorter shock, etc.).
    Just talked to Canecreek on the phone. It will get me 2 degrees but NOT recommended.
    The most I can do is 1.5 on bottom and 0 on top.
    _______________
  1. Replies: 13
    Last Post: 07-31-2013, 02:30 PM
  2. Replies: 0
    Last Post: 05-24-2013, 09:15 AM
  3. Replies: 11
    Last Post: 02-21-2013, 01:18 AM
  4. Ibis Mojo SLR 140 and Angleset
    By jmacovei in forum Ibis
    Last Post: 09-05-2012, 11:27 AM
  5. 1 1/8 angleset: How much would you pay?
    By stumblemumble in forum General Discussion
    Last Post: 07-14-2011, 01:43 PM
