Results 1 to 26 of 26
    Reputation: FastDDS's Avatar
    Ibis Ripley Large arrived weight lbs
    5.48LBS with Fox rear shock, lizard skin, blue paint and seat clamp. Building at CalCoast with a Rock Shox SID RCT3 120mm 51mm (good luck finding these) , XTR, Stans Crest, rocket ron 2.2 ...
    Looks really solid
    Attached Thumbnails Attached Thumbnails Ibis Ripley Large arrived  weight lbs-img_2765.jpg
    So envious.. any thoughts on the choice of Fox vs X-Fusion shock?
    Reputation: robertj's Avatar
    Feb 2005
    Congrats!
    I was hoping to give the x-fusion shock a try (save a few grams), but they are not available for many weeks per my LBS.
    Dropshot Champ!
    Reputation: redmr2_man's Avatar
    that blue looks SWEET in pics.
    super awesome man!
    Large matte XT build was just shy of 26lbs w/o pedals, Fox Float CTD shock, setup tubeless
    Mtb Guide
    Sep 2012
    Get er built, gonna be good to see some built Ripelys, stunning frame!
    May 2010
    So Jealous, can't wait to see your build and also can't wait to get mine.
    That Blue looks really good!
    Green with envy
    Thanks for the frame weight. Was hoping to see that. That blue looks amazing in your photos. Looking forward to finished build photos! Thought I wanted matte black/green but now ...Good thing I get to wait for the XL frames and go back and forth on color
    Any sufficiently advanced technology is indistinguishable from magic
    - Arthur C. Clarke
    MSH
    MSH is offline
    Reputation: MSH's Avatar
    Jun 2005
    Quote Originally Posted by FastDDS View Post
    Building at CalCoast with a Rock Shox SID RCT3 120mm 51mm....
    Looks sweet! So on your SID I'm just curious...did the shop do the internal air spring conversion to make it a 120?
    Quote Originally Posted by MSH View Post
    I bought a 120 Sid. The shop is swapping out the upper assembly to G2 (15mm offset). I'll know in a week how this pans out.
    MSH
    MSH is offline
    Jun 2005
    Thanks. Would you mind sharing the cost to do the conversion? I know the labor rates will obviously vary by shop but it should still give me an idea of which is the most cost effective route...your route OR buying the 100mm/51mm offset version and converting the air assembly to the 120mm. Going the air spring assembly swap route locally here in CO would be $85-ish for the assembly and $50 in labor.
    Your way is much less $$. I will have an extra upper I may be able to sling on eBay. another option is the manitou 29 tower fork 48mm offset. 1/2 $ of fox or sid.
    I also pre-emptively bought a 46mm offset 120mm SID for the Ripley, so am really interested to know if the CSU swap works out.
    MSH
    MSH is offline
    Jun 2005
    Quote Originally Posted by alixta View Post
    Bumpin' this for an update if at all possible.
    Looks like the upper swap is the cheaper route if you want the SID 120/G2 offset for the Ripley. After discussions with a RS tech it looks like if you want to convert a 100mm SID to 120 it's not just a simple air spring assembly swap. You have to change the air spring ($85), lowers ($240) (120mm has different lowers than the other shorter travel SIDs), and swap to different bushings ($30-$40??) on the 120mm.
    FastDDS,
    Did you have to update/change any other parts than the Upper Assembly? Did you use RS Part # 11.4018.008.136? That looks to be the correct one
    Looks like the best option might be to buy 2 forks (46/120 & 51/100). Swap the CSUs and sell off the 46/100.
    MSH
    MSH is offline
    Jun 2005
    Bingo! Definitely a "Why didn't I think of that" moment when I read this. I already have a 51/100. I might just go this route. Thanks for the idea
    Cool let me know how you get on with this. I'm planning on doing the same. The only thing holding me back from buying the 51/100 is confirmation that the CSU in that will indeed go to 120.
    3 weeks later ... anybody had progress (success or failure) building their own 120mm 51mm FrankenSID?
    MSH
    MSH is offline
    Jun 2005
    I gave up on it. It's just a ridiculous hassle that I spent way too much time researching (do I sound bitter ) Meanwhile I'm stuck with a G2 100mm SID that I cant seem to find a buyer for. Unless RS comes out with a 120mm G2 SID between now and when I finally get my XL frame I'm going with the Ibis issue Fox
    Yep I feel your pain. It's not Ibis's fault that RS don't have 51mm option, but a bit more help from them would be nice. Maybe it's a good thing that the XL is sooo far away so we can gestate ideas.
    PM me if you want to ship your 51mm to Aus (if it's a black solo air, shipping will probably kill the deal though).
    MSH
    MSH is offline
    Jun 2005
    ...PM me if you want to ship your 51mm to Aus (if it's a black solo air, shipping will probably kill the deal though).
    Thanks. PM sent.
    MSH
    MSH is offline
    Jun 2005
    Another weight data point for large frames.
    Black/green with with Fox rear shock, Ibis chainstay protector, seat clamp, and 142mm Maxle rear axle = 2511g (5.536 lbs).
    Fast DDS large weight didn't include the Maxle rear axle so if we take that out of the equation (73g for axle) weight = 2438g (5.375 lbs).
    So comparing the two only 47+g for the blue paint in this case/comparison...
    Ibis Ripley Large arrived  weight lbs-ripley-frame-weight-1-5-20-2013.jpgIbis Ripley Large arrived  weight lbs-ripley-frame-weight-2-5-20-2013.jpg
    I'll answer my own question here, yes it works, you can make your own Ripley friendly 120mm Rockshox SID.
    The recipe is simple, take one standard offset (46mm) 120mm SID and mix it up with a 51mm offset 100mm SID. Bolt the 51mm 120mm SID to your Ripley, stick the remaining 46/100 on eBay.
    This works for current model solo-air SID, there is no such thing as a dual-air 29er 120mm travel SID, who knows what will arrive in 2014.
    For more info check out RockShox SID 120mm 51mm Offset Conversion | Defconcycles
    (p.s. I posted the same link in another Ripley thread)
  1. Tallboy LTc vs Ibis Ripley
    By Tahoe Gator in forum Santa Cruz
    Last Post: 04-09-2015, 02:34 PM
  2. Ibis Ripley - Believe it or not, it's here!
    By doismellbacon in forum 29er Bikes
    Last Post: 03-30-2013, 05:39 PM
  3. Ibis Ripley
    By yeti575inCA in forum Yeti
    Last Post: 03-25-2013, 03:45 PM
  4. Ibis Ripley?
    By tantra in forum 29er Bikes
    Last Post: 01-22-2013, 08:01 PM
  5. Pivot 429 vs Ibis Ripley
    By schneidw in forum Pivot Cycles
    Last Post: 09-16-2011, 10:42 PM
