Results 1 to 5 of 5
    Feb 2005
    Ibis hakkalugi, small hole on down tube close to bottom bracket shell
    Okay, so I got a ibis 'lugi, and I am excited. I was looking closely at the frame, and there is a small hole (about 1 mm diameter) on the underside of the down tube close to the BB junction. It is not for cable routing (this hole runs through the top tube).
    The paint around the hole looks smooth, but the hole itself does not look "perfect" like the holes used to route the cable.
    So does anyone have a hakkalugi with a small hole on the bottom of the down tube right by the bottom bracket junction? Maybe to drain water?
    Thanks,
    holding back the darkness
    Reputation: subliminalshiver's Avatar
    pictures please
    Reputation: miles wadsworth's Avatar
    Nov 2006
    I am sure it is fine , I have one too.
    milesW
    Reputation: freebiker's Avatar
    Mar 2006
    call an exterminator stat!
    sounds like a carbon termite
    Feb 2005
    Quote Originally Posted by miles wadsworth
    You have a little hole as well
    on the down tube or a Hakkalugi?
    thanks
