Results 1 to 17 of 17
    Dec 2004
    How do I clean sticker goo off my frame?
    I have a superbly awesome Mojo SL, which has the "rubber" paint.
    Stickers and tape when peeled off leave sticky goo, and I would like to remove this without damaging the surface in any way.
    What kind of a cleaner/solvent/scrubber should I be using?
    I have decided to strip and clean my bike, as winter appears to be fading away here in NZ and the old thing was getting a bit creaky...
    cheers,
    Rob
    Attached Thumbnails Attached Thumbnails How do I clean sticker goo off my frame?-precious-apart-s.jpg
    Sep 2012
    Goo gone. Pick it up at your local walmart.
    Steve
    Dec 2004
    Hmm here in NZ we lack Walmarts.
    I shall look for the "Goo gone"
    Reputation: zicked's Avatar
    Lighter fluid?
    Please don't mistake my enthusiasm for mountain biking as an indication of my skill level.
    Dec 2004
    I do not know any smokers..maybe Vodka?
    I once got fresh tar on my carbon giant that hardened while I was at work. I found that WD-40 was a good solvent for removing it. If you try it you should test it on a location that can't be seen like the bb just in case it eats the paint.
    Sep 2012
    Window cleaner works well, so does wd40. You should be able to get those in NZ
    Steve
    Look for the citrus based GooGone. Really works well in getting the goo off.
    Lightly salted
    Reputation: fuenstock's Avatar
    I've always used rubbing alcohol to remove sticker residue. I spray some on and leave it for 5-10 minutes, then another spray and wipes off.
    Sep 2012
    Alcohol wipe pads you et at fast food joints do as well.
    Dec 2004
    Cheers people, I shall first start with window cleaner as I have heaps
    That guy
    Quote Originally Posted by robbieracer View Post
    I'd try the Vodka first
    Sep 2012
    Cheap grocery store lemon juice. Using Vodkas like wipin your @ss with $10 dollar bills. It works but its such a waste
    Reputation: GiantMountainTroll's Avatar
    Mar 2012
    Goo gone, rubbing alcohol on some toilet paper or even soap and water on an old sock. Just remember the elbow grease
    2013 Specialized P 26 AM green/purple. Nuff said
    Giant Faith
    Reputation: getbusyliving's Avatar
    Try some kiwi juice.
    Reputation: ScottW's Avatar
    You can smear cooking oil over sticker residue and it softens it up so you can wipe it off.
    Dec 2004
    In the end I found that cheap window cleaner (that I had heaps of) worked very well.
    I was careful to thoroughly wash it all off.
    The other stuff suggested might work as well or even better
