Results 1 to 9 of 9
    Which housing to use with KS Lev Dropper?
    Uncertain which housing to use with KS Lev Dropper post. 4mm Gear housing? Check out the housing provided by KS in the box - it's folded into a triangular shape, lol.
    Reputation: Vespasianus's Avatar
    Whatever you do, do not used the housing that they provide. It tends to fold up like that even after installation.
    Sorry. It works fine, why don't you want to use it?
    On MTBR, the reputation is infamous.
    Reputation: mwandrusz's Avatar
    I used standard shifter housing. Works just fine.
    Lightly salted
    Reputation: fuenstock's Avatar
    I use the same housing I use for shifters.
    Reputation: brankulo's Avatar
    Aug 2005
    what is the cable head called that they use? it looks different )smaller) than shifter cable head.
    Quote Originally Posted by brankulo View Post
    The ferrule? Well it is 4mm housing.
    I spoke to KS, was advised to leave the housing out in the sun for a few hours to soften it up, straighten it out. Seems to be working.
    Aug 2005
    no, cable head, end of braided cable. it is different than your standard shifter cable head.
    That's the european or old standard. It looks like a flattened disc, right? You'll have to cut the braided cable down to length, so only the end that inserts in the remote lever matters.
    I can guarantee you (as I installed mine per the instructions a month or two ago), that the cable that is included with the LEV will work in standard shifter housing.
    Reputation: watts888's Avatar
    Oct 2012
    based on some shifter cables I've used, they are a molded plastic cable ferrule instead of the crimped metal ones. Makes changing the cable length more difficult, but they work OK.
  1. Gravity Dropper housing
    By solitone in forum All Mountain
    Last Post: 09-10-2013, 10:56 PM
  2. New? housing
    By doccoraje in forum Weight Weenies
    Last Post: 10-25-2012, 08:25 PM
  3. Is the shifter cable/housing the same as my brake cable/housing
    By dstorjoh in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-13-2012, 09:18 AM
  4. Rear Derailler Issues: dirty housing, full housing, new housing?
    By TwoHeadsBrewing in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-31-2011, 10:49 AM
  5. New Housing Help
    By one4teen in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-15-2011, 12:49 PM
Members who have read this thread: 8
