Results 1 to 58 of 58
    Hey, Ibis Folks: Any thoughts of doing HDR 150mm??
    I love the way my HD rides. It's the std 160 travel AM rig. Love it, love it. Then I 650b'd my TRc (Sorry to mention another brand here) and love it too. It really came alive with the 650b. So then I hear the HD is now in a 650b version too. Yippie. "Now the symphony is playing in full harmony, birds are chirping..."
    Until I read that it's 130mm?! "Music soundtrack coming to an abrupt warping..." Huh????? That's even less than the SL. Why make the HD 130mm and not 150mm? I'm sorry I just dont get it.
    150mm 650b HD with correct geometry, not having to modify anything like shimming rear shocks, gobs of rear wheel clearance, a BB height of around 13.2-13.5 now that would be the ticket.
    Hans, and the Ibis folks. You folks have excellent customer service. I was just wondering...
    We Ride In God's Country!
    Quote Originally Posted by myitch View Post
    That would be a different bike. Especially since the 27.5 fork is longer and the tires are getting larger all the time, it is pretty challenging to lower the bike that much.
    H
    More to the bike than the travel.......Stiffness and Geometry. I would imagine the SL-R to be lighter and quicker feeling in turns than the HD-R even with 130mm travel.
    Quote Originally Posted by hanssc View Post
    H
    Hi Hans,
    Any comments on the configurations bikeco.com is making available? If I were getting an HDR right now, their 147mm 27.5 setup is the one I would get. It seems like this is the 27.5 HD most people want.
    The Bike Company - Powered by ironfly internet
    Reputation: KRob's Avatar
    Until I read that it's 130mm?! Huh????? That's even less than the SL....
    I thought Hans said somewhere that the 26" Mojo HD 140 was actually only 130....( not sure what the actual measurement is on the Mojo SL).
    I think 130-140 is the sweet spot for a 650b trail/am bike. 150-160 might be nice for bigger stuff (AM/FR) but like he said, then it's a different bike.
    Isaiah 58:14
    www.stuckinthespokes.com
    I have the Bike-co 150MM HDR and I could not be more pleased. I'm sure the stock HDR in 650B is awesome but nothing compares to a Bike-co set-up period, end of story (There is a reason why Joe is Brian Lopes personal mechanic). My HDR has More travel and my BB is lower then my old 26" Bike-co built HD. I love Ibis, I have been riding them since they returned but Bike-co will take an already superior, class leading bike and make it even better.
    Quote Originally Posted by cdsdad View Post
    What are the geometry numbers for the Bikeco HDR?
    I'm not exactly sure but I will call them tomorrow and get the numbers.
    What fork did you pair with the Bikeco shock? Did you go with the short shock or long shock with offset bushings? Would like to know what the HA is plus BB height?
    Any sufficiently advanced technology is indistinguishable from magic
    - Arthur C. Clarke
    I just ordered a BikeCo HDR 650b with 147mm travel.
    They really know what they are doing and the ProTune front fork from Fox (150mm) is a totally different animal. The rear shock they use is tuned to get the 147mm and I will be running a 2.25" rear tire, so clearance is not much of an issue.
    I can't wait to get this bike as my original Mojo c is 6.5 yrs old and I am over due !
    Quote Originally Posted by dcpowpow View Post
    Are they setting you up with the short shock or the long shock? Did you ask them what the difference is between the long shock versus using the short shock?
    Long body shock. It has more volume. They are amazing on the phone and if you order a bike, they will spend the time to go over every detail.
    Nice. I think the long shock uses offset bushings so I'd appreciate you measuring the HA and BB height when you get it. Assume it's a 8.5x2.5 but would appreciate confirmation on that also. Thanks.
    - Arthur C. Clarke
    What exactly do they do to make the bike 'this' amazing?
    Quote Originally Posted by seleniak View Post
    Has anyone gotten specific info on this yet? I'm curious to know what the recipe is.
    Too Much Fun
    Reputation: benja55's Avatar
    Aug 2005
    Caution;  Merge;  Workers Ahead! Some info on Ibis site...
    It's worth noting (didn't see it mentioned in the thread) that Ibis is working on a shock spec to make the longer travel HDR650b option a bit easier to set-up:
    Mojo HDR 650b | Bikes | Ibis Cycles US
    "Like with its predecessor the Mojo HD, it's possible to set up your HDR 650b with travel greater than 130mm. You need to travel limit the shock in order to do this. If you configure an HDR this way you can get about 140mm or 145mm of travel depending on tire size.
    Please keep in mind that changing travel on the HD and now HDR is something that people have figured out on their own, this has not been an Ibis spec shock set up. Changing the travel or eye to eye on your shock needs to be done carefully or you can damage your frame. We are currently working on an Ibis approved shock spec for those wishing to run their HDR in longer travel 650b mode. We will update as info becomes available."
    - -benja- -
    On the Bikeco website, what they did to make HDR 147mm is a secret. But they must also charge an arm+leg if they're already taking a stock $2700 HDR frame and tuning the shock. Are these frames still covered under factory warranty afterwards?
    Why assume? You know what they say about assuming right? Why not call and ask, I did.
    No they don't charge an arm and a leg, they actually give you credit for the 'stock' shock and then charge you for the new tuned one. Their price for the tuned shock is reasonable when compared to other tuners out there.
    If I remember correctly it was around $2725 with the new tuned shock.
    Tallboy 3
    OG Ripley v2
    Carver 420 TI
    Oct 2007
    TwoTone is right on track about BikeCo
    I just finalized my HDR build with them yesterday with the 147mm option TST-R and they work some kind of magic with pricing, very impressed. Especially considering the amount of time they've spent on the phone with me to cover all the details and for the right price.
    While it may not be something they post on their website, I don't know many people who would buy a frame like that without having the details disclosed to them.
    Reputation: Yody's Avatar
    So I wonder what the geo is like with 650b wheels, 140-145mm rear travel, and a pike/fox 34 reduced to 150mm. I'm happy with my BB height on my 26" wheeled HD160. If I can get 650 wheels on this new hdr and only lose 10-15mm suspension travel and keep the same BB height I'd be good with that. The 130mm travel is gonna come up a bit short for me. I'm sure it would be faster for flowy trail riding, but if I have only one trail bike I want it to be able to take on some harder riding than 130mm travel allows. I know 15mm of travel isn't a lot, but 30mm less is not going to cut it. 145rear/150 front would work, especially with a bit bigger wheel.
    Reputation: BikeThreads's Avatar
    Oct 2011
    Conekilr,
    When do you hope to take delivery of your 147 HDR?
    I'm seriously looking at the same ride and would love to hear your thoughts.
    I called Bikeco and spoke with a salesperson/tech, then a salesgirl. It was informative, but it sounds like basically they take a Marzocchi shock, change the internals and customize the valving, eye to eye, and stroke length. It doesn't sound like anything else is done such as different limbo chips, or play with the links. Or at least they didn't tell me anything to that effect, unless I just didn't understand right.
    But for sure, if I'm going to plunk down $2700+ I need to know what they've done to the original frame and parts. What they do sounds good but I'd just rather have a factory built-from-the-ground-up 650b 150mm travel AM Mojo frame. Then I can take my own shock choice (Such as a Monarch) and have it tuned myself.
    Apparently these HDRs are really selling, so I don't anticipate Ibis redesigning it anytime soon. Too bad. I really think this HDR could have been an even better design. Oh well. Market demand
    Yeah from reading into it, its just the internals of the shock modded, nothing too fancy. I'm just curious how the suspension curve works/ bb height, etc
    Jul 2013
    Quote Originally Posted by Yody View Post
    I ordered one a week ago, 147mm rear travel (short shock), 150mm Pike. Once I get it I'll measure BB and HA (and anything else you want), unless Conekilr beats me to it. Mine is supposed to arrive last week of July.
    Hey Kibosh, your in line after me. : ) I ordered a 147mm rear with the ProTune Fox front fork 150mm about 1.5 wks ago. Large Blue.
    I am interested to see what you think about the Pike. I decided to stick with the Fox as they told me with the ProTune it is a totally different fork
    Same here, I will post the dimensions and a ride review right away.
    I can't wait !
    Just curious, what size is everyone getting for the HDR ?
    I am just a hair under 5' 11" and my last Mojo was Large, but just wondering if the sizing on the HDR would be different ? Perhaps a Med would be better ?
    Jul 2013
    I can't wait !
    I'm local though (maybe you are too), so when they are done, I get it the same day, I don't have to wait for them to ship it to me.
    They told me the same thing about the Fox fork, that they can work magic with it, but I decided to try something new and get the Pike, plus the Pike is black on black, which looks good on the black frame and I got a reverb dropper post which is also black on black. I just wish the yellow details were stickers and not paint.
    I am (a little over) 6' and got the large, was thinking about the XL though. At 5'11" large is probably the right way to go. I rode a medium (with a really long stem) and it didn't feel right, way too cramped.
    Yes, I am out of town, so you will probably have your bike before me.
    I agree, the large should be good, thanks for the feedback and enjoy !
    Too Much Fun
    Aug 2005
    Stick with the Large
    IMO, Mojo C/Mojo SL/Mojo SL-R sizing translates pretty directly to the HD/HD-R.
    I'm 5'8" and ride a Med SL and now a Med HD. I've got rider pals who are a bit taller then me, maybe close to 5'10"-5'11", and they're on Large HD's.
    - -benja- -
    Stop all this talk of taking delivery on these 147s. Grr. They sound sweet. I guess it'll be a long time before Hans makes a factory HDR at 150mm. The 130 HDRs seem to be selling well. I still don't get it though. 130 on the HD? I'd just assume make an SL 140 instead
    What's with the 3mm hang up? 147mm HDR is a shock change that's it. I'm new to looking at Ibis bikes and it didn't take much research to learn that's how others where getting more travel.
    Hell even in this thread it's spelled out for you. Does that sound like a company voiding frame warranties for putting a longer shock on?
    from about 5 posts up
    Please keep in mind that changing travel on the HD and now HDR is something that people have figured out on their own, this has not been an Ibis spec shock set up. Changing the travel or eye to eye on your shock needs to be done carefully or you can damage your frame. We are currently working on an Ibis approved shock spec for those wishing to run their HDR in longer travel 650b mode. We will update as info becomes available." "
    Tallboy 3
    OG Ripley v2
    Carver 420 TI
    So for those that have ordered the 147mm HDR... were you really not told what the HA/BB measures in at before you handed over your cash?
    Jul 2013
    Quote Originally Posted by Mattoid View Post
    I was told 0.2" higher BB than stock. HA with a 150mm fork would be about the same as stock.
    large for sure...Truuuuussssstttttt Meeeeee!
    Quote Originally Posted by kibosh View Post
    They did say 0.2" higher than stock but also that its lower than a stock 26" HD. But they did not specify what the BB height is.
    Those of you with the HDR 147mm's. Can you measure you BB heights? What is the actual weight on these frames too, not just the claimed weights?
    They did say 0.2' higher than stock but also that its lower than a stock 26" HD. But they did not specify what the BB height is.
    Wow really? .2" higher than stock, there you go that is the BB height. Take that, add to the number you'll find here Mojo HDR 650b | Bikes | Ibis Cycles US and you have your BB height.
    Here's the bb height for the stock 160mm Mojo HDR | Bikes | Ibis Cycles US Take that number and compare to the height you get above, is it lower? Hint: Yes
    Do you bother to try and find out anything for yourself first?
    Tallboy 3
    OG Ripley v2
    Carver 420 TI
    I don't know if anyone on here has actually received their 147mm bike yet. Once I get mine I will post up info. Probably won't be able to give you frame only weight since it's a full build.
    As far as BB height and HA, there are probably some slight variations between each bike depending on tires size and various fork A2C values. I don't get too hung up on the absolute numbers if it rides the way I want.
    Too Much Fun
    Aug 2005
    Quote Originally Posted by kirchart View Post
    ...and that my friends, is the key to enjoying a bike.
    - -benja- -
    Yes, I agree. The truth is in the ride. But I'd like to get an idea of some real world measurements out there. Claimed BB height and weights are always just that; claimed and not real world. I'd like to know what I'm getting before plunking down all that $$$$$$$$$$$$$ for these expensive frames. I already know the BB height on my std 160 HD is a bit tall for me.
    I look forward to seeing those numbers. It'll be interesting to see.
    Any idea on the cost of this 147mm BikeCo upgrade?
    Quote Originally Posted by luvbuggin View Post
    Try calling them?
    Tallboy 3
    OG Ripley v2
    Carver 420 TI
    Reputation: mwandrusz's Avatar
    Bikeco: 888 697 6717
    Reputation: TahoeBC's Avatar
    The quote I got from Bikeco for the shock is $550. You would utilize the 160mm chips with there custom shock
    It is based on a Marzocchi Roco chassis with custom internals and modifications. It has a custom developed eye to eye and stroke allowing the 147mm of travel on the HDR. There are no offset bushings with the shock.
    Some clarification on the Bikeco setup. This is the same geometry of a HDR 160 with a 160mm travel fork 26 fork as long as you stick with a 150mm 275 fork which is 67.5 degrees. Both are ~545mm A2C. With a 160mm travel 275 fork it will be similar geometry to a 26/170mm fork which are both ~555mm A2C or approximately 66.5 degrees. BB height should be around the 14.2" I measured on a friends HD with a similar setup.
    Bikeco does not change the limbo chips, they are tuning and shimming the shock to reduce the shock travel approximately 5mm. You will still be limited to sub 2.3 tires in the rear. The pricing is very competitive since to buy the frame and have someone else mod the shock will probably add $400 to the price. Someone else noted a Bikeco price of $2725, but I have not verified that number.
    Quote Originally Posted by Salespunk View Post
    That was me, I called and if you buy the frame, they credit you for the stock shock.
    Tallboy 3
    OG Ripley v2
    Carver 420 TI
    Quote Originally Posted by TwoTone View Post
    You have to add it to the 160/26 bike, not the 130/275 bike. Copy and paste from the other 275 thread;
    That being said, I think that the Bikeco numbers are questionable. I would like a REALLY good explanation on how they are extending the travel of the bike in 130 mode since that is the ONLY way they could get the BB between the 275 and 160 bike. BTW a 150 travel 275 fork is the same length as a 160 travel 26 fork which is also going to raise the BB.
    I guarantee that they are not doing this since the wheel would hit the seat tube. They are instead using the 160 limbo chips with an 8.5x2.5 shock and a 5mm delrin washer to limit the travel. That 5mm washer times a 2.6 leverage ratio equals 13mm reduction in travel equalling 147mm. That 13mm reduction is at the END of the stroke so the static BB measurement will be 13.8 with 26 wheels in theoretical land. In the really real world with decent sized tires (anyone run Hans Dampfs?) you are going to see a 14.0" BB height on the 26 160 bike. Add in the height of the 275 wheels and you get 14.2" BB height which is exactly what I have measured on other 275 147 setups.
    Reputation: motard5's Avatar
    any ride reports on the bikeco HDR 140mm+ setup?
    I have Marzocchi Canada down the street. From what it sounds like they can custom modify the shaft to shorten the EtoE on the shock. I'd imagine you would get similar results with a 5mm washer and offset bushings? The shock may benefit from a tune though. However I have been running my HD140 in 650b mode with offset bushings for a while. I haven't noticed any quirky behaviour with the shock performance. I was originally running a fox 36 at 140, but I found the steering to be slightly off. I've since borrowed a WB Loop to try a larger offset, and it handles fantastic. So now I'm looking to get a 34 650b fork.
    With both offset bushings fully offset, Loop fork at 140, archEX rims with Maxxis Highroller 2 2.3 tires, I have a BB of 13.5, maybe a hair lower.
    I have a 160mm setup (chips and shock), so what I may do is at least install the HV shock with bushings to see generally what BB we are looking at before I shim it. The only thing is the Loop is borrowed so I don't want to increase the travel to 150. But it will give me a ballpark figure.
    The picture is with an Ardent 2.25, which proves to actually be a bit taller than the HR.
    Attached Thumbnails Attached Thumbnails Hey, Ibis Folks: Any thoughts of doing HDR 150mm??-image.jpg
    screamer
    Reputation: budgie's Avatar
    Quote Originally Posted by ukr77 View Post
    Interesting! Eager to hear your results @160 with the offset bushings. Incidentally, how is the tire clearance w/the HR & Ardents on the HD?
    On heavy rotation: White Lung: Deep Fantasy
    So after a couple weeks in Aliso and El Moro with the new BikeCo shock, I feel I can compare my old and new setups pretty well now.
    I had been running the medium HDR with the stock 2014 Float Factory CTD shock at 130mm (always on Descend mode) with the stock 2014 Float Factory CTD 34 at 140mm (using all 3 modes) for over 3 months with 30+ rides all over OC (Aliso, El Moro, Laguna, Santiago Oaks, Whiting) and 26+ DH runs at Camp Nelson and Snow Summit. The BB measured 13.7" with stock Pacenti Neo-Motos 2.3" and the bike weighed 29.8 lbs.
    I had BikeCo install their Marzocchi short shock 147mm setup and increase the fork travel to 160mm (it was suppose to be 150mm but their mechanic accidentally did 160mm instead) by removing the spacers. The BB now measures 14.1" so there was an increase in 0.4" of BB. The bike now weighs 30.2 lbs so an increase in 0.4 lbs. The front end felt significantly higher and wallowed on steep sections up Cholla so I lowered the handlebar 0.5" by moving the headset spacers above the stem, but otherwise the bike is unchanged. I've only had a chance to ride this setup around Laguna so no knarly downhills or big jumps as of yet.
    I can say I feel significantly higher on the bike. My crotch hits when I'm saddling the top tube now and I have a 29" inseam. As for climbing, the bike feels heavier up steep slow sections on Cholla, Mathis and Mustard and the front end wallows a bit so it's harder to keep a straight line on steeps probably due to the increase weight and slacker head angle.
    On cornering, there is the slightest difference in quickness initiating turns. But once in the turn or coming out of berms, it's the same. Like I said this is barely noticeable. I always have my seat dropped and these scenarios are more dependent on my seat height anyways.
    On rocky downhills, there is a huge noticeable difference of the bike. Whereas before, the bike was mediocre on downhills it now shines… rock gardens on Rockit, drops on 5 Oaks, ruts on T&A, sketchy shit on Carwreck… all feel easier to ride. I really feel like floating atop these sections. The shock is so much better than the stock Fox in terms of not stacking and maintaining it's plushness throughout its travel no matter if it's the first or last ride of the day.
    The same can be said for the front shock…it is so much more plush on the rocky downhills. I've yet to have gone through all my travel and have only used about 140mm even with big drops and jumps. I think 160mm is overkill for my weight and style of riding so will probably go back to 150mm soon.
    So all in all, the new setup with increased travel is better at my intended purpose…to rock the downhills. But it does suffer a bit on the steep climbs and cornering initiation… a small price to pay in my opinion for the increase fun!
    Quote Originally Posted by budgie View Post
    About 4mm. Doesn't sound like much, but the mud/dirt in North Vancouver is pretty clay free, so mud never sticks to the tires. I don't hear anything hitting the stay or the seat tube.
    This sort of affirms what I personally feel are the best setups for the HDR (or converted in my case). My biggest AHA! 650b moment was my converted 650b HD 140 with offset bushings, fork at 130-140, and--faster rolling tires--. Even riding the North Shore here in North Vancouver, all of the redone trails and new XC trails (bc XC still, the 650b is an absolute blast. I GET IT. But! On the more traditional Shore trails, in which a lot of them are run in the Shore Enduros, the traditional 26 with full 160 travel and sticky tires is far and a way a faster setup. I Know I've raced the HD160, a 29er (Satori), and a borrowed Altitude. When the trails are constant 2-3 foot shelfs (a lot of these shelf/drops on switchback corners no less) and really rough, travel DOES make up for the questionably lack of 'roll ability" of the smaller wheel. It's wheel control (suspension) bike control, and commitment that perform on these trails. The Satori was fast. I actually one an event on it. However the heaviest/roughest stage was also one of the more fall line runs, so not a great comparison. And I didn't fall Most other events were full of very very steep tight corners. The HD was consistently faster over the series. The altitude felt like it had less travel, and it does I think. It wasn't bad, but the wheels didn't do too much to be fair is was borrowed.
    So yah for me, the sweetspot is short travel 650b for smoother terrain, long travel and 26 for gnar. Or I guess in the future a long travel 650b for the gnar.
    I think the whole Enduro thing is getting nuts with the thinking that a bit larger wheel but with 20-30mm reduction in travel is the same thing. 'More efficient use of travel' perhaps? Maybe the marketing machine should have ridden Whistler EWS Stage 5?
    Great post. So what are your thoughts on a 275/150+ bike like the Mach 6?
    Mtb Guide
    Sep 2012
    Ibis should make a new model dedicated 27.5" 150mm bike not mess around with the HDR, dedicate a design and committ to building a real improvement imo and I might consider it one day, other than internal routing for a Steath Reverb, not much more Id want altered to the current HDR.
    But its time to ADD to but not drop the HDR ( the HDR can still be the 130mm 27.5" or hardcore 26" bike it is)
    Committ to building a dedicated 150mm 27.5" Enduro model with a new name and identity! jMO fwiw!
    Id call it the Mojo Predator!
    I agree, IBIS should be 100% on board with a 150mm 650b bike by now. I have the HDR built with the BikeCo 147mm rear shock and 27.5" wheels using a Pike 150mm fronk fork. although the bike is awesome, I feel a bit high in the perch and the tight rear tire clearance would be a nice change. The bike itself handles very well and is flickable and a superb downhill technical bike. Climbing is a bit compromised, but not bad. I am enjoying it and will ride it for a few years, but with so many 27.5" 150mm bikes popping up.... who knows. Just the fact I had to go to a custom rear shock to get the 147mm rear travel is a bit disconcerting and this should be a factory option.
    Reputation: wilks's Avatar
    Isn't the bikeco shock a 7.875 x 2.25 ? I have a spare one lying around. Would I get 147mm of travel on my HD? and if I slapped 27.5 wheels on my regular HD (Bos Deville fork has clearance for 27.5 tires) would I not have a poor mans bikeco HDR ?
    Just a follow up on the offset bushings with the 8.5 x 2.5 shock and 160 limbo chips. Only one bushing works with the rear tire almost contacting the seat tube. I'm only getting a max of 53-54mm of stroke. Hardly different than the 140hd 650b setup with two offset bushings. 13.8 bb with a 140mm 650b forkk-not an ideal setup for me, considering a Pike or Fox 34 will bring the bb around 14. I'm better off at 26" with my fox 36/Avy, carbon havens and big sticky tires for certain conditions.
    I'm trying to wrap my head around the magical bike co. setup. It's higher, with just a few mm more stroke available. Unless the new moulds give a lot more bottom out clearance giving more travel than what I'm getting, I'll stick to the 130/140 setup, and a shorter fork. The 130/140hd with offset bushings is REALLY GOOD. It's pretty slack for the travel, the bb is low, it makes sense:-)
  1. Replies: 5
    Last Post: 06-07-2012, 10:18 PM
  2. Replies: 27
    Last Post: 03-17-2012, 09:44 AM
  3. Replies: 6
    Last Post: 10-22-2011, 08:13 PM
  4. Niner Jet9 RDO "vs" Ibis Mojo SL-R for 5' 4" rider
    By ollllllo in forum 29er Bikes
    Last Post: 10-19-2011, 08:17 AM
