Results 1 to 5 of 5
Thread: Help please
    Oct 2012
    Help please
    Ive got a 2012 Mojo SL with a X-Fusion O2 RCX shock fitted from factory.
    I'm on the verge of buying a Kashima RP23 but was wondering if any you fine people knew if the fitting hardware that came with the X-Fusion will fit the RP23?
    Cheers in advance
    Ibis Mojo SL with DT Swiss XMC130 fork
    Pace RC300 with Pace RC39 C-Type fork
    Pace RC200F8 with Pace RC36 ProClass2 fork
    screamer
    Reputation: budgie's Avatar
    Both shocks use the same hardware.
    From the Department of Unsolicited Advice, going to the RP23 from the RCX is a step backwards. I have two RP23s (1 of them Pushed) and the RCX is superior. Less wallowy (better midstroke support), better compression damping, useful full range of rebound adjustment, gets full travel @ appropriate pressure... The Pushed RP23 might be better on small stutter bumps, but that's about it. XFusion comes out on top, IMO.
    On heavy rotation: White Lung: Deep Fantasy
    Oct 2012
    Thanks for the reply
    Lightly salted
    Reputation: fuenstock's Avatar
    I would save your money and stay with the Xfusion O2 you already have. Like Budgie said, the rp23 would be a downgrade.
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    Quote Originally Posted by fuenstock View Post
    But it has kashima and better marketing...
