Results 1 to 8 of 8
    Oct 2012
    head-tube insert becoming unglued on mojo HD
    Hey guys, any of you ever had the aluminum (are they alu?) "cups" that the headset is attached to fall off?
    after removing my fork today the bottom headset cup just came apart from the frame, while still in the aluminum insert that's not supposed to come out.. :| anyone experienced that? is it fixable? or does this mean i have to get a new front triangle of the frame?
    thanks guys
    here's a picture from the web that shows the part im on about
    http://www.sicklines.com/gallery/dat...d_detail31.jpg
    Call Ibis directly. I am sure they will take care of you immediately. Never heard of this happening before.
    Oct 2010
    I actually had this happen to my bike when the shop was putting it together back in 2010. Ibis said it was probably safe to ride but went ahead and warrantied the front triangle. You should email or call them, as Salespunk has said.
    Yep, the upper insert came out of my HD when I was attempting to remove my headset cup. IBIS wanted me to send the frame back but I begged and they sent me a replacement insert and epoxy.
    Reputation: Dibbs_'s Avatar
    Speak to Ibis, they will sort you out.
    Oct 2012
    well guys, since i live in Israel, its usually not that easy to get direct service from the manufacture. so i went to my LBS which sells ibis (and are the official ibis dealer around here) they told me that a similar thing had happened to them in the past, and reassured me that its OK to just epoxy glue a new insert instead of the old one.
    so all in all, everything seems to be OK now thanks for the help!
    P.S, id like to thank Ibis for their overall great customer service, even though i haven't had a first hand experience, ive seen them help a lot of people around here on the forums, which is not a common sight in the MTB business, or any business really.
    Quote Originally Posted by haravovadia View Post
    thanks guys
    I had the same problem, except it was my upper headset cup and the lower front link tube that came unbounded. I just epoxied them back into place and they've been fine so far.
  1. mojo hd insert bonding failure
    By julians in forum Ibis
    Last Post: 04-21-2013, 05:35 PM
  2. Reynolds 853: 44mm head tube, 30.9mm seat tube
    By butasan in forum Bike and Frame discussion
    Last Post: 04-07-2012, 10:30 AM
  3. 2012 Air9 Head tube / head set questions
    By Nooge in forum Niner Bikes
    Last Post: 12-27-2011, 03:51 PM
  4. E2 head tube ?
    By raleigh5 in forum Gary Fisher
    Last Post: 11-14-2011, 07:14 PM
  5. Head tube-down tube weld question
    By namelessontrail in forum Frame Building
    Last Post: 03-26-2011, 02:05 PM
