Results 1 to 41 of 41
    HDR options 140mm
    I really want the new HDR frame.
    I want to order a size large, but would like to know if I can get the 7.875"x2.25" rear shock ? I assume this will give me about 140mm in the rear. I am Looking to put the new 35mm stanchion Pike fork on it in 150mm travel.
    This bike would basically be the bike I have right now, but updated to front and rear 650b wheels opposed to my front only 650b.
    My current bike is a Mojo (2008) with 650b front wheel, Float 150mm fork and stock 140mm rear shock running 26" wheel rear.
    I am long over due for a new bike.
    How can I order this bike ?
    Do I just have to get the rear shock on my own and put it in or ?
    This seems reasonable, I would love to see Ibis list this option and discuss it a bit more.
    Thank you.. I am ready to go.
    Oct 2007
    HDR options 140mm
    Sounds familiar! Seriously, call the bike company (bikeco.com). Ordered my HDR from them and have been talking quite a lot since about suspension and other build options. I'm also going with the new Pike 150. I plan on running a 7.875x2.25 shock as well. They will ensure that there aren't any clearance issues and get the bike dialed.
    They are one of the main Ibis distributors and know their stuff. Lots of real world race experience (their main man is Lopes' mechanic) but more importantly they seem to be more concerned with matching components to fit you rather than just pushing what we all think is the new hotness (sometimes one-in-the-same, lots of new hotness to choose from). Also, they have custom tuned so many forks and shocks for people, especially for mojos, and for a damn good price. With most other shops or online dealers, you would have to order the frame with a stock shock as well as the desired replacement, then try and make some money back.
    Have fun!
    Reputation: TahoeBC's Avatar
    Edit: Never mind
    Thanks for the info. I will call them and see what I can get going. !
    Any idea if a 2.35 Hans Dampf will clear with the 7.875x2.25 shock?
    Oct 2007
    HDR options 140mm
    @ mattoid - the 2.25" stroke would require some amount of shimming for such a big tire. I will be using 2.25 or 2.36 HD in the rear with
    Oct 2007
    HDR options 140mm
    Oops...
    ...with that size shock. Not sure how much it will need but I'm just about to give the shop a call. If they haven't already tested that combo, then they will be as soon as my frame arrives : )
    Keep us posted what you find out. You might be the first one ordering this bike.
    I will probably run 2.25" in the rear, so it might be ok.
    Not sure if frame size makes a diff, but I will be ordering a Large HDR frame.
    What is your goal in running the shimmed 2.25" shock if it won't achieve more travel than the stock 2.00"? The added flexibility of using the unshimmed shock with a 26" wheel or smaller 650b tire, or is it being able to add shims to squeeze every last mm of travel allowed by your tire/rim combo?
    Oct 2007
    HDR options 140mm
    Yeah thats the funny part lol. I really just intended to run it as designed at 140 front, 130 rear. I don't necessarily want the extra travel for most of my riding.
    However, most of the components that I am considering dictate otherwise.
    Shocks - Vector air and custom Roco tst r come in as a tie for me and both are 2.25" stroke.
    Forks - Really wanted to buy an X-Fusion sweep but it won't meet my deadline (big trip/race in Moab in September). Yes I have considered Fox but the short answer is no. Really digging the new Pike just wish there was internal travel adjust. I could go with the DP air version and crank it down to 140. But once again, I think availability is not there yet (and it looks like it will only be available in white?!).
    So that's kind of where I'm at. Any other options/thoughts?
    Agreed, I'd partly hate to buy a CCDBa in 7.875x2.00, it just seems like such a hard size to use down the road or resell.
    I wonder where the geometry of a non-650b HDR with a shimmed shock to ~140mm using a 1 degree angleset would end up with 650b wheels?
    Looks like BikeCo is doing what we want
    The Bike Company - Powered by ironfly internet
    The HDR is shaping up to be a very versatile frame !
    Oct 2007
    HDR options 140mm
    Aww yeah, those are the specs I have been discussing with them. It's getting closer!
    Glad to see that they are clearly listing the different options so that people (like me) aren't losing so much sleep wondering what could be. I'm opting for the short(ish) travel 27.5 option, 147mm rear 150mm front. Should be plenty of bike for me!
    I am ordering mine on Monday and it will be the same, 147mm rear and 150mm front, Latge Blue !!
    Should be a sweet build.
    Now have to sell my old Mojo after 6.5 yrs for a little extra cash.....
    I can't wait !
    Reputation: pmanfred's Avatar
    Quote Originally Posted by conekilr View Post
    Are you going with the Pike or the custom tuned Fox fork and what was the the word from Bikeco on running the Hans Dampf with the rear travel @147 ?
    Not sure yet on fork and shock/tire options as we are going to discuss details Monday.
    I will post back what I find out. I am only really looking to run a 2.25" tire in the rear and my goal is 140mm or more travel back there.. I can live with a little less than 147mm if need be.
    Jul 2013
    I'm seriously considering this build as well. Any idea what the difference is between the long shock 147mm and the short shock 147mm?
    Also do you know what the HA turns out to be with a 150mm Pike? Trying to decide between the 150mm and 160mm Pike.
    Get the Pike and don't look back. There is a great writeup on Bike Rumor right now and I had the exact same impression after riding it for a few days.
    Ok, I finally pulled the trigger and got my HDR 650b on order. Went with BikeCo 147mm option and decided to stay with the Fox front fork (150mm) as with the BikeCo ProTune, it is a completely different fork.
    Once I get the bike, I promise to to an extensive review !
    Quote Originally Posted by dcpowpow View Post
    What did they say as far as a date u can expect the HDR by?
    Quote Originally Posted by pdqmach26 View Post
    +1, i think i ordered mine around the same time. did they give you an ETA?
    Jul 2013
    Quote Originally Posted by Fuller View Post
    I ordered mine on 7/11, I was told first week of August.
    I was told mid August.
    Quote Originally Posted by kibosh View Post
    ok, i ordered mine on the 12th so hopefully i get mine beginning of august too. what size did you get?
    Jul 2013
    Large reverse vit P.
    May 2013
    Anyone get their bikes yet? Considering the bikeco route as well.
    Reputation: cryde's Avatar
    Oct 2007
    Yes Yes Yes.......ride reports please. Especially in regard to the 147mm BikeCo shock option.
    You gotta Get Up to Get Down!
    Ride report HDR size large with 147mm rear using BikeCo pro Tune shock (TST)
    650b front and rear wheels
    150mm front fork Fox Float
    Bike total weight with Dropper seatpost about 28.9 lbs
    This bike is stable.. Holds a line perfect. Handles angles and landings with no flex. Seemingly bottomless rear shock.
    Clibing is great. Still has a nice crisp feel to it. The descent is unreal. Very flickable bike and wants to be placed more than just ridden. Don't get me wrong, you can ride it smooth but it is so fun to flick around it just seems to demand it.
    The finish on the bike is great. Clean cable routing and Ibis does such an awesome job.
    I can probably shave the weight of this bike a pund or so with a lighter wheel set, but right now, I am not worried about it as the wheels (Novatec) are very solid.
    The bottom bracket height seems to be a non issue and with this much suspension you actually are very happy it is not a loow rider in the big rock gardens.
    Overall, I have my all mtn bike and daily ride bike with a hidden full on descender packed inside.
    How much is did BikeCo charge for the 147mm option? Sounds like it may be worth it but I'm still on the fence.
    I am not sure what the 147mm option costs as I ordered a complete bike from them.
    Give them a call, they are super easy to work with.
    Anyone who did the BikeCo rear shock have a chance to measure the eye to eye and stroke lengths? I'm super curious how they got that thing up to (basically)150mm while keeping a low BB height.
    They're using the 160mm chips, so a shock that's around 8.25" x 2.25" should get it done, but I'm curious to hear an actual measurement as well.
    Feb 2010
    Any pictures of tire clearance from the 147mm bikeCo rig ?
    27.5? (650b) Ibis HDR ? 147mm Travel by BikeCo.com
    HDR options 140mm
    What is your bottom bracket height? And could you measure the eye to eye of your shock?
    [QUOTE=mtbbiker;10954413]What is your bottom bracket height? And could you measure the eye to eye of your shock?
    I am curious also as my 2012 HD with the 160mm 8.5*2.5 shock was 14 1/4-14 3/8 BB with 650B Hans dampfs 2.35. It felt tall and that was with a fox 36 lowered to 535 A-C, 150mm travel. (yes the fox 36 cleared the Hans Dampf 2.35)
    Only two ways to get that BB down and get 147mm travel. reduce the shock E to E from 8.5 to 8.25 (or so) as stated previously or run the 140mm limbo chips with a 7.875 2.25 stroke shock and check for fit with tire rub on the seat tube.
    does anyone know the exact numbers on the bikeco roco mod yet? is 8.25 x 2.25 about right?
    I think Bikeco must have their customers sign a non-disclosure agreement.... either that or they don't know what eye to eye means...or how to work a tape measure?
    Ya no doubt. Help a brother out.
    Reputation: Ramjm_2000's Avatar
    Jan 2005
    I went with option #2...love it. (7.875x2.25")
    Quote Originally Posted by Ramjm_2000 View Post
    This is on a HDR w/ the 130 limbo chips? If so, more deets please!....
    What does the seat tube bottom out clearance look like? What rear tire are you running?
    Jan 2005
    "run the 140mm limbo chips with a 7.875 2.25 stroke shock and check for fit with tire rub on the seat tube" on my 2013 HD. I thought Hans mentioned way back that the 140 chips on an HDR was a no go.
  1. 140mm forks with straight 1-1/8" steerer options
    By yogiprophet in forum 29er Bikes
    Last Post: 03-30-2015, 11:20 AM
  2. Replies: 4
    Last Post: 01-28-2015, 12:16 PM
  3. Replies: 8
    Last Post: 05-06-2013, 05:37 PM
  4. Replies: 10
    Last Post: 11-13-2012, 12:34 PM
  5. frame options in the 140mm / 5.7 nieghborhood
    By dimitrin in forum All Mountain
    Last Post: 06-21-2011, 09:07 AM
