Results 1 to 12 of 12
    [put something cool here]
    Oct 2011
    HD slowing down on stairs
    When I ride stairs, my HD slows down. It's the rear end that sort of brakes. Since I am satisfied with the general downhill performance, I'm puzzled by this behaviour. I'm on a large HD 160, 1st gen CCDBA with ~130psi, rider weight 77kg/169pounds without gear
    Do you also experience this? Is it a suspension setup topic only?
    Thanks for any advice.
    How much sag are you running?
    Hmm, I think I know the feeing you're talking about. I've also ridden my HD extensively with a CCDBA, as well as RP23, and Monarch+. Assuming your sag is set properly (not overly soft), off the top of my head I'd guess that some or all of the following might be happening:
    1. Rebound generally unbalanced between fork and shock. If your fork is rebounding significantly faster than your shock, it would likely feel like your rear end is getting roughly dragged down the stairs without a chance to work. Also, it could feel like your fork is pushing back into the rear end as it rebounds much faster. Fork/shock interaction sucks, and a balanced front and rear is key...
    2. Shock Rebound too slow (too many + clicks of HSR) - Causing the shock to pack down to bottom of the its stroke where it ramps up and keeps the wheel from clearing out of the way smoothly, instead smacking into each square edged hit. If the first couple steps feel good, but then it feels slow till the bottom that could be this happening.
    3. Way too little compression damping (not enough + clicks of of LSC for platform/ride height, and not enough + clicks of HSC to keep you from using a ton of travel). This would cause you to use way too much travel, and much like above get very near the end stroke where it's harsher and doesn't move as freely. Combined with Rebound too slow, your bike would feel horribly slow. Check your shock's O-ring, are you using a reasonable amount of travel given the speed at which you're hitting the steps, or bottoming like crazy?
    Hope this helps! I'm no expert, but do dork out on getting my sussy feeling good
    EVIL Uprising
    I get an hesitation too when I ride them too slow. Go a little faster and loosen up on the bike; see if that helps.
    Yup, could totally be this simple too...
    EVIL Uprising
    Oct 2011
    Oops. Looks like I need to check my setup more often. After realizing I had around 35-40% Sag (@salespunk), I attached the pump. And was surprised to have gone down to 80psi. I pumped to 130, which I noted down to be a good value a while ago. But then I reached ~20% Sag only. I ended up at around 110 to have about 30% sag. AND I will recheck with another pump.
    The opposite was the case at the fork, 180 Talas: too less sag, so I reduced pressure, plus I increased rebound after the push-bar-and-quickly-release-it test.
    I didn't check the compression and rebound setup in the ccdba now, but will do that soon. My last notes were HSC 0.25 turns, LSC 5 clicks, HSR 3 turns, LSR 16 clicks. But last on-trail adjustments resulted (@vtsingletrack/2) in faster rebound, both high and low speed.
    All that said, I had a good ride yesterday and felt fast (in my limits). Wow, science...
    Oct 2011
    Quote Originally Posted by vtsingletrack View Post
    This sounds most reasonable to me. I revisited the CC base tunes and noticed that the compression values changed a lot. In my printout from a year ago they say 0.5 HSC and 5 LSC. Although I played around a lot by that time and was especially convinced of the low HSC value.
    Yea I noticed they changed recently too... I'm thinking it was never updated on their site after they updated the air can's internals to be less progressive out of the box. Originally the CCDBA complaint was "I'm running 35% sag and not using all my travel". This was addressed with air can update. Makes sense that now we need to be running more compression if the shock ramps up less out of the box.
    EVIL Uprising
    Too Much Fun
    Reputation: benja55's Avatar
    Aug 2005
    Quote Originally Posted by Kerberos View Post
    You should be clearing the stairs.
    - -benja- -
    Oct 2011
    AW: HD slowing down on stairs
    ...I'm thinking it was never updated on their site after they updated the air can's internals to be less progressive out of the box. Originally the CCDBA complaint was "I'm running 35% sag and not using all my travel". This was addressed with air can update.
    Ok, that would mean I'd better stick to the previous values, because I own row 1st gen shock. Strange then that they don't give different setups for models 1 and 2.
    Oct 2011
    ... "go faster" ... , "clear the stairs"... -- you guys are absolutely right. Please visit my next thread "my mind slows me down" :-D
  1. Middle of season slowing down
    By MichelleB in forum XC Racing and Training
    Last Post: 10-01-2013, 02:27 PM
  2. Slowing down to enjoy the trail
    By ACLakey in forum Passion
    Last Post: 06-10-2013, 06:23 PM
  3. Slowing down aka current build
    By ncj01 in forum 29er Bikes
    Last Post: 11-01-2011, 01:56 PM
  4. Heat slowing you down, or in your head?
    By randyharris in forum Arizona
    Last Post: 05-20-2011, 11:47 PM
  5. Slowing down on a steep decent?
    By Danny P in forum Beginner's Corner
    Last Post: 01-15-2011, 05:56 PM
