Results 1 to 8 of 8
    Reputation: sdemars's Avatar
    Mar 2011
    HD Fork - RC2L or DH
    Building an HD and I'm sort of new to the longer travel forks. I'll be using it for general trail riding, lift riding and Enduro racing. I have an XC bike for all day fast stuff with loads of climbing. I want this for my increasing love of air time and flying downhill. I'm sold on the Lyric, but need to decide on the RC2L or RC2DH. As a noob to this fork category my decision is speculation based on reviews.
    From what I gather the RC2L provides the height adjust option, which might aid climbing. Some people seem to use it all the time, some rarely. I've never had this option so I have no idea how often I'd actually use it. Especially since I'm less interested in uphill performance (although I don't want it to completely suck since I'll be pedaling to the top more often than taking the lifts )
    On the flip side, what I get from the RC2DH is no height adjust, but without the floodgate the DH damper is a bit better at small bump performance and a bit more responsive overall. It also comes in 170mm. I don't know if I'd actually be able to detect the performance difference, or if I'd miss the height adjust.
    Thoughts? Do you use the travel adjust much? If you've ridden both could you tell the difference?
    Overland : Hayduke : Hightower LT : Delirium : Piolet
    Jan 2009
    Get the rc2DH. It blows away the other damper, and for what you're using the bike for, will be perfect.
    If you really want a heigh adjust, you can drop a coil u-turn into it or the two-step. Fwiw, The coil is by far the best choice, If you want height adjust.
    Jan 2009
    As per your question about height adjust, it depends in what you ride. We ride fire road climbs, to fast flowy pnw goodness. We only use the travel adjust on the climb 50% of the time.
    DH and don't look back. You won't miss the travel adjust. I've owned and ridden both extensively and the DH is far better for what you've described. That's not to say that the RC2L isn't a good choice but if you have the option., DH is the way to go. I run mine at 170 with a -1 degree Angleset and still find it to be a great climber.
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    Get the DH. I never miss travel adjust on my rides.
    DH, no question. I ride mine at 170 up steep climbs and don't miss travel adjust at all.
    Mar 2011
    Wow! Quick consensus. Thanks so much!
    Pix whenever it comes together...
    Mar 2011
    White Mojo HD with blue links arrived in the shop yesterday
    Picked up a new 2012 Lyrik RC2DH in White this morning off CL
    Stoked!!!
  1. 2011 Lyrik RC2L Rebuild questions
    By yohyat in forum Shocks and Suspension
    Last Post: 05-07-2013, 10:28 PM
  2. Difference Between Lyrik RC2DH and RC2L?
    By IntenseMack10 in forum Shocks and Suspension
    Last Post: 09-09-2012, 01:40 PM
  3. Lyrik RC2L vs RC2DH (or maybe Talas 180/140)?
    By monkei in forum Downhill - Freeride
    Last Post: 03-24-2012, 05:34 PM
  4. Lyrik RC2L won't get full travel
    Last Post: 02-26-2012, 09:02 PM
  5. Rockshox Lyrik RC2L
    By kuksul08 in forum Shocks and Suspension
    Last Post: 04-04-2011, 04:49 PM
