    Reputation: philstone's Avatar
    Mar 2011
    HD chain line and MRP guide..
    Hi all,
    Been running my HD for a few weeks now but I'm not happy with the chain line. My setup is SRAM bb, 2 spacers on drive side lopes guide, then X0 DH crankset. I think ideally I need to only run one spacer on the drive side but then the lopes guide catches on the main pivot. Is there another guide that has a slimmer plate that won't catch the main pivot? Or should I dremel the plate so it clears the pivot?
    Phil
    #bleedblackdieevil
    Feb 2012
    It may sound counter-intuitive but the drive side spacers do not modify the chainline on SRAM GXP BBs. The spindle floats on the drive side BB bearing. If you want to modify the chainline, add/remove spacers on the non-drive side, that moves the whole spindle/cranks in or outboard.
    Although it may visually resemble Shimano's Hollowtech 2, the GXP is entirely different; drive side spacers do really nothing but move the bearing.
    Mar 2011
    Really? Surely changing from 2 spacers on the drive side to 1 spacer will move the whole crankset closer to the frame?
    #bleedblackdieevil
    Feb 2012
    Quote Originally Posted by philstone View Post
    Take a closer look at what happens when you remove one of the spacers on the drive side - the gap between the cup and the crank will get bigger but the crank will not move a bit. Chainline is adjusted on the non drive side instead where the step in the spindle is rested against the bearing. The drive side bearing is not loaded. You might find some good topics about GXP in the Drivetrain forum.
  1. Bionicon C.Guide V.02 Chain Guide + Fuel EX 8?
    By DBackRider08 in forum Trek
    Last Post: 09-23-2013, 04:03 PM
  2. Bionicon chain guide - use on upper chain line?
    By phazeshifta in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-23-2012, 12:39 AM
  3. Issue with 1x9 chain guide and chain line
    By akacoke in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-31-2012, 04:11 PM
  4. Replies: 100
    Last Post: 03-20-2012, 02:50 PM
  5. rohloff chain guide or other guide options???
    By nicolian in forum Nicolai
    Last Post: 05-22-2011, 02:06 PM
