Results 1 to 6 of 6
    Reputation: brankulo's Avatar
    Aug 2005
    hd with 40mm rims, do i need new rear triangle
    have hd with 650b wheels. thinking to get nextie 40mm hookless rims. anyone runs 40mm 650b rims using old rear triangle? not sure how much wider tires get on these rims. my preffered combo is neomoto 2.3 rear and hd 3.35 front. looks like i still have decent clearance on the sides at yoke
    Not sure about the Neomoto's, but when we test fitted my friends bike it was not happy with the Rock Razor rear even in the new rear end.
    Aug 2005
    wow, bummer. ibis site says 3-5mm tire width increase for their rims, which would work with neomotos i think. rock razor seems to come in 2.35 only which if it is the size of hans dampf 2.35 would be quite bigger than neo moto
    Feb 2012
    I have the 1st gen frame with 135mm rear spacing and I run the 40mm wide Derby rims. Neo Moto 2.3, Honey Badger 2.2 and Spesh Purgatory Control 2.3 all have enough room in the rear triangle (although the HB and PC are quite tight), the seat tube clearance is a more limiting factor with these tires. If Neo Moto 2.3 is your go to tire, no need to get a new rear triangle.
    Feb 2012
    Aug 2005
    thanks man
  1. Replies: 1352
    Last Post: 01-30-2017, 09:11 AM
  2. Replies: 13
    Last Post: 12-22-2012, 10:21 AM
  3. 40mm rims?
    By bulerias in forum Wheels and Tires
    Last Post: 12-02-2012, 06:40 PM
  4. Hope Dirtrag is right about Syntace 40mm rims
    By Slow Danger in forum 29er Components
    Last Post: 09-27-2012, 09:09 AM
  5. rims, rear triangle or weight...........
    By qkenuf4u in forum Ibis
    Last Post: 02-21-2011, 10:34 PM
