Results 1 to 2 of 2
    Jan 2011
    HD 160mm - RC4 Coil - 2 1/2" stroke or 2 3/4" stroke?
    Need to change the factory 350lb spring for a 550lb one.
    Fox told me that the replacement coil requires a 2 1/2" stroke version, but was told that I could also use one that has a 2 3/4" stroke.
    What are thr pros or cons of using either version? Any difference? Thanks!
    www.derbyrims.com
    Reputation: derby's Avatar
    The shorter coil is lighter.
