Results 1 to 20 of 20
    HAS / Saar angleset for Mojo SL
    Anybody has ever ordered an angleset from Saar?
    Ofanaim.net » Head Angle Set
    Ofanaim.net » Rider's Feedback
    I emailed him, he said he is starting collecting order, and recommend me 1.5 degree for my mojo SL, 2-3 weeks.
    I emailed works component but never get any reply.
    Saar angleset has pretty good review, but I would like to hear some more input before I order one. more $$ than works component tho.
    Happy trails.
    I've been looking for a way to slack my sl for forever... Are you sure he can do one for the SL? I stopped looking when I got an HD about a year ago, but last I checked no one wanted to try to do an adjustable headset for the SL because of the carbon integrated cups.
    If you've really convinced him to try to make one for the SL tell him he's got at least one more buyer. Maybe I'd ride my SL more often instead of just always riding my HD...
    Feb 2013
    I spoke to works components a while ago about this and they said they weren't going to make angle sets for the sl because like already stated due to it having carbon integrated cups. I instead went for the option of putting some x-fusion vengeance forks on her that have been lowered to 160mm travel and I haven't looked back it has completely changed the bike. Its obviously made the front a bit light on climbs but I can live with that for the way it now feels when you point it down the trail!
    So Works would not make one for mojo SL.
    I just emailed Saar again, asking him to confirm if the angleset compatible with 2012 mojo SL.
    If you see his website on rider feedback, one of the rider has it on mojo SL, and he is satisfied.
    I will update what Saar will say.
    I emailed him yesterday and this is his response
    Hi Dave,
    I am collecting orders for the next production batch.
    They go for 600 ILS anodized and shipped.
    Regards
    So not cheap, but if they work it will be a great solution
    ok, here is his reply:
    "All Mojo HT are the same standard 42/42.
    It is the length that varies.
    I have made many of those and they were installed successfully.
    The cups are tight fit into your HT, since they are eccentric and will rotate during aggressive riding.
    Be aware that it is highly recommended to use a Loctite 690 bearing compound on the cups to prevent them from rotating.
    I plan to have them ready in a few weeks."
    pretty convincing answer to me. I may order one soon. who's interested?
    Definitely interested but may wait a little longer to see any long-term reviews - just in case.......
    i just ordered one. will update here..
    Saar has to make it. he said in a few weeks.
    Update:
    I received the angleset this week, and ordered loctite 609 just like recommended by Saar.
    Angleset is installed, pretty straight forward. ready for action tomorrow. I removed 3 headset spacer, total 15mm, to get somewhat the same bar height.
    I can feel the difference riding it around the block, more slacker, stabil, better in cornering.
    real test is coming.
    Reputation: Ramjm_2000's Avatar
    Jan 2005
    I emailed him about one too. After reading the discussion in the 650b forum about using offset shockmounts to get the 1-1.5 degree change I think I'm going that route. Its cheaper and less likely to damage the HT.
    ok, first ride on trail with new HA, very happy with it. No creak, no movement of the cups, at least for now. Climbing is about the same, cant really feel any diff. But cornering and DH, feel way better. The rock garden DH section feel so much funner.
    Cane creek and Works Componet dont make it. Im glad I found out about HAS.
    Thanks, Mr Saar.
    Reputation: hairless's Avatar
    Feb 2010
    Cups from Saar Gelvan
    That´s mine, and works really good.
    HAS / Saar angleset for Mojo SL-2013-01-07-238.jpgHAS / Saar angleset for Mojo SL-2013-01-07-239.jpgHAS / Saar angleset for Mojo SL-2013-01-07-237.jpg
    Regards
    Quote Originally Posted by hairless View Post
ID:	786768Click image for larger version.
ID:	786769Click image for larger version.
    Regards
    Bike looks great Hairless. What was the final fork angle you were able to achieve? Also, what were you charge for this?
    thanks a lot!
    Feb 2010
    Hi, msbihli. The angle was 67,5º with 150 mm fork, and it cost 128 €. It work´s really good
    Hi,
    I also purchased one of these headsets from Saar. I put it on my Mojo Sl. It is the best upgrade I have done on the bike. I am using it with a 140 Fox Talas. My impression is the that the bike carries more speed through corners and rough stuff. Great upgrade and Saar is really responsive to questions.
    I did it all for the kudo
    Reputation: Short Bus's Avatar
    I tried to order one of these from this guy and initially his response was that he was out of them for the large SL frame but he had several for the medium. So I emailed him back asking if he could let me know when he has them in stock.
    This was the response that I recieved...
    "As it seems, there is no forecast for the next production.
    Sorry"
    Anyone know what kind of upper bearing cover I should use with this. I put in cane creek 36x45 bearings and they dropped in fine but the bearing cover sits too high and there is a gap between the cover and the bearing. Any suggestions?
    Nov 2008
    Quote Originally Posted by Dan0930 View Post
    Mine has about 0.5 mm gap, using original IS2 Headset -I don't have any issues with it but its noticeable.
    HAS / Saar angleset for Mojo SL-2013-08-16-08.39.33.jpg
    Tal
    Reputation: Musicguy's Avatar
    To resurrect this thread I have a 2012 Mojo SL I'm wondering if there is something out there still for this? I contacted Ibis but they said nothing was compatible. I see here it's been done. I don't know if these are still made or somebody else might know of one?
    Sent from my SM-G935V using Tapatalk
    Reputation: DH_WP's Avatar
    you think it would be possible to manufacture something like this that will allow a tapered fork on the bike? My SL and MOJO are still in such good nic that its a shame I can't use them due to the fork issue ....
Members who have read this thread: 24
