Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 76 to 100 of 125
  1. #76
    Fabricio, you are right. XX1 should be OK for Ripley. I just received the Hope XX1 freehub for X12 version and it does come with an end cap that looks like the one on the hub.
  2. #77
    Mar 2006
    Cool you are lucky, I had my freewheel came with the QR, so I had to modify my old 142x12mm end cap.
    Well enjoy your ride dude.
    Cheers.
  3. #78
    Been running my HD140 with XX1 for several weeks now, no need to file, no rubbing issues whatsoever. Enves AM's laced to DT240s hubs. I can't see my self ever buying a 2x or 3x again, pull the trigger, you wont regret it.
  4. #79
    Jan 2005
    Hans i am in on the spacer hanger for (2).
  5. #80
    Mar 2006
    Caution;  Merge;  Workers Ahead!
    Hans I'm in with two of the XX1 hangers too, nice support!
  6. #81
    Mtb Guide
    Sep 2012
    And me x2
    Spacers work, but not when like me in such a hurry to jump on my bike and ride, I drop my spacers on the ground.
  7. #82
    Mar 2006
    Quote Originally Posted by Maverick005 View Post
    And me x2
    Same to me jajajaja... But at last it is a fast solution for go out and ride without damage the rear of the bike
  8. #83
    Reputation: cmarshack's Avatar
    Hans-I am in for a hanger as well...just waiting for my I9 wheels to get here...
  9. #84
    Mtb Guide
    Sep 2012
    Dam need this soon lost my spacers a number of times now real pia
    always in a rush then drop them mainly lacking up so next ride I screwed
    XX1 innovation n design award
  10. #85
    I9 wheels are here and installed and I have rubbing in the 10tooth...any word on the timing of a new hanger?
  11. #86
    Quote Originally Posted by cmarshack View Post
    You're probably already aware but a pedal spacer will get you by for the time being.
  12. #87
    Jun 2010
    What frame are you using?
  13. #88
    Quote Originally Posted by vamaro View Post
    Mojo HD.
    I decided to lightly file away the paint (no carbon) and still had significant rubbing. I then took my cassette back off the hub, greased the splines and threads, reassembled and now I have very minimal rubbing. Still might want a small spacer but at least it's not pushing the chain into the the 12 tooth any more.
  14. #89
    Reputation: sanjosedre's Avatar
    Add me in for a couple of XX1 hangers, I'm running easton havens with rub only on the 10t cog.
  15. #90
    Reputation: saxen's Avatar
    so will the xx1 work with a 135x12 rear? im running newer Easton havoc wheels
  16. #91
    I'm not sure you could find an XX-1 135x12 axle adapter, but then the next level of potential problem is that the chain probably would not have sufficient clearance to the swingarm.
    It does fit on the newer bikes Ripley, HDR etc. We also have a hanger in the works to improve the clearance on the HD for XX-1 using the 142 x 12. We should have it in a few weeks.
    H
  17. #92
    Probably not much progress due to Interbike, but do you have an update on the hanger?
  18. #93
    I think they will be here soon, maybe within 10-15 days.
    H
  19. #94
    Hans - Can I use the new hanger with the Gen 1 12x135mm HD?
    -Shane
    Quote Originally Posted by hanssc View Post
    H
    Any sufficiently advanced technology is indistinguishable from magic
    - Arthur C. Clarke
  20. #95
    Quote Originally Posted by seleniak View Post
    -Shane
    Sorry, it is not compatible with the 135 mm version.
    H
  21. #96
    Any update on a new rear HDR style triangle for the HD then
    H
    - Arthur C. Clarke
  22. #97
    We are still shooting for year end. We will probably build to order and paint them to match the original colors and graphics 1:1 with the orders.
    We'll post here when we are ready to take orders with a webstore listing and go from there.
    Cheers!
    Hans
  23. #98
    Too Much Fun
    Reputation: benja55's Avatar
    Aug 2005
    And this is how you build customers for life.
    Well, that and making bikes that ride like a dream.
    - -benja- -
  24. #99
    Fantastic news! I look forward to getting this,
    Then it is just to order enve rims/wheels! Should hold for many years for me :-)
  25. #100
    Reputation: manchvegas's Avatar
    Mar 2011
    Hans.. can you give a ballpark figure for the retrofit swing arm as far as price? If not I understand, but I'm very curious.. Thanks
    determined to put the "mountain" back in "MOUNTAIN BIKING!!!" "HIT IT!"
    2012 MOJO HDeeeeeeee!!!!
    2010 scott CR1 comp
