Results 1 to 6 of 6
    Reputation: agleck7's Avatar
    May 2010
    Fox shim kit for HD
    Hey - only have a handful of rides on my new HD, but am noticing I'm blowing through a lot of travel just pumping rollers and corners. This is with 20% sag and in the "trail" compression setting. Doesn't seem to be bottoming out on big hits/casing jumps though.
    Does anyone have experience with the shim set? What are the pros/cons?
    I use the largest spacer.....noticeable difference.
    Reputation: Trackho's Avatar
    Fox shim kit for HD
    Most of the new HDs come with a preinstalled med spacer..might be why it's so progressive
    Too Much Fun
    Reputation: benja55's Avatar
    Aug 2005
    Fox shim kit for HD
    I put the med spacer in on my HD and it helped a lot.
    Then sent it to PUSH and it came back feeling better then anything I've ever ridden, except some coil shocks I've been on.
    Pure Velvet..
    - -benja- -
    Reputation: brankulo's Avatar
    Aug 2005
    i installed med spacer only to replace it for large one after 30 mins. of riding. dont expect miracles though.
    _____
    Large spacer vs no spacer felt miraculous to me. At least with the older rp23.
  1. To shim or not to shim seatpost?
    By kneetowaist in forum All Mountain
    Last Post: 09-20-2015, 07:03 PM
  2. which shim
    By brankulo in forum Ibis
    Last Post: 07-22-2012, 01:47 PM
  3. 28.6 to 30.9 seatpost shim
    By akazan in forum General Discussion
    Last Post: 05-06-2012, 08:02 AM
  4. Seatpost Shim 30.9 - 34.9 ?
    By maynard in forum Scott Sports
    Last Post: 12-08-2011, 11:32 PM
