    Reputation: mojo_man's Avatar
    Fox 34 (160mm) on an SL-R?
    Im thinking about a new fork for my SL-R and the Fox 34 has caught my eye.
    The question really is would the SL-R be ok with a 160mm fork? would it change he head angle much?
    www.derbyrims.com
    Reputation: derby's Avatar
    Quote Originally Posted by mojo_man View Post
    Compared to a Fox 32/140 the added 20mm travel of a 34/160 will rais the head tube the same, 20mm, and slack the frame angles 1 degree, and raise the BB close to 7mm or 1/4 inch.
    Lower your bars nearly as much as the added travel, and bump the seat forward about 1/4 to 1/2 inch and up slightly to maintain leg reach and seated weight balance over the crank and wheels as previous with the 140mm fork.
    Reputation: getbusyliving's Avatar
    One great thing about that fork is Fox has a spacer that is easily installed that lowers the travel to 150, which is perfect for the SL-R IMO. I've been riding an older carbon mojo w/ a 32-150 fork for years, and just build up a new SL-R with the 34 @ 150, and it is night and day. The 1/2 lb added w/ the 34 fork pays back many times in stiffness and plushness. You can run 160 too (in fact I encourage you to try it before installing the spacer), but I just think 150 is a more balanced fit for this frame.
    Note: I'm specifically talking about the Fox Float 34-160, lowered to 150.
    Reputation: neilether's Avatar
    Do it. I am running the 34 in 160 mode. I thought I may end up adding the spacer to reduce it 10mm, but 6 months in I see no need. I love mine the way it is.
  1. Downsizing rotors from 185mm/160mm to 160mm/140mm
    By xterrafreak in forum Brake Time
    Last Post: 02-26-2013, 12:03 PM
  2. Fox 36 RLC or RC2 160mm
    By demarp in forum All Mountain
    Last Post: 06-17-2012, 07:25 AM
  3. Fox 36 with 160mm on a 575
    By agabriel in forum Yeti
    Last Post: 12-20-2011, 07:28 PM
  4. Fox 32 150mm or fox 36 160mm
    By Bowhuntmaster in forum All Mountain
    Last Post: 06-24-2011, 11:33 AM
  5. Fox 36 160mm van?
    By tigerkai in forum All Mountain
    Last Post: 02-06-2011, 05:38 PM
