Results 1 to 5 of 5
    Dec 2004
    float x2 settings on hd4?
    Any opinions on the suggested settings in the ibis manual for the x2 shock?
    How accurate do you think they are? I only ask because they are way different than how my shop set up my x2 on my new hd4.
    Aug 2015
    Ive played a lot with the settings. Even had it with all high speed open. Currently went back to settings in the manua and seems fine. I'd suggest starting with the settings in the manual.
    Sent from my SM-G930V using Tapatalk
    Reputation: Creg's Avatar
    Nov 2014
    Unless I'm looking in the wrong place, the setup guide settings are just the fox standard settings. My settings are quite different, so find what works for you. Starting with all the dials in the middle is a good place to start.
    aka bOb
    Reputation: bdundee's Avatar
    Not HD4 specific but when dialing in rebound on the x2 I turn the HSR all the way slow and just use the LSR for tuning. If you can't get it fast enough which I doubt you can't back out the HSR some.
    Dec 2004
    I will figure it out with time that is not a problem. I just found it funny how my lbs set it up so completely different than what is in the ibis manual. I would have figured it would have been close
  1. Ibis HD4 sighted
    By Crossmaxx in forum Ibis
    Last Post: 2 Weeks Ago, 09:16 AM
  2. Ibis Mojo HD4 Vs Pivot Firebird
    By Trail7Surfer in forum 27.5
    Last Post: 07-17-2017, 11:55 AM
  3. HD4....what changes would you like to see?
    By Tally Ho in forum Ibis
    Last Post: 05-13-2017, 05:22 AM
  4. Enduro Specific Rig? HD4 maybe.
    By alwayslivingthedream in forum Ibis
    Last Post: 11-19-2016, 01:17 PM
  5. Replies: 2
    Last Post: 03-28-2006, 11:42 PM
Members who have read this thread: 36
