Results 1 to 34 of 34
    Feb 2007
    Bonking ... not feelin' well Extralite IntegrHead 2 + Ibis Mojo
    I've bought this headset to save some weight but upper bearing doesn't fit in the frame. is there any another way plastic cups for this frame to fit this headset?
    Thanks, Yevgen
    Added later:
    That is what manual says:
    Both Mojos use the integrated
    headset based on the Cane
    Creek IS standard (aka the 36°
    / 45° or 41 mm standard). These are
    available from Cane Creek and probably
    others. On our kits we use the Cane Creek
    IS2.
    and here is the description from extralite:
    Compatible: 45° internal fitting, Campa.
    So it should be ok but it doesn't
    flow where ever you go
    Reputation: noshortcuts's Avatar
    No way for it to work, Campa is the the other "standard". Different from IS standard.
    "I must not be crazy because I'm seriously questioning my sanity"
    Feb 2007
    And what if ask from ibis guys for another type of this upper plastic cup?
    If you mean the cup currently attached to the mojo to hold the headset, I think it is built in and not meant to be replaced. Can't hurt to ask them though.
    Feb 2007
    grrr
    thanks anyway.
    will drop a line to Ibis may be there is possibility to order form them such cup
    MTB Monkey
    Reputation: Jefe74's Avatar
    Mar 2006
    Why don't you just get the right headset? Ibis is very clear on what the spec is.
    To confirm, this implies that any cane creek IS headset would fit the Mojo and SL? Including the 110 IS?
    Founder: Dirty3hirties
    Reputation: ddraewwg's Avatar
    Quote Originally Posted by etnt
    Yes, any IS standard headset will fit (assuming you buy the right size).
    Slovakia (Europe)
    Reputation: PeterG's Avatar
    Quote Originally Posted by ddraewwg
    Not sure, e.g. 41mm Hope IS standard doesn't fit too (see the picture). This is not only the question of bearings diameter and chamfer angles (Mojo is designed for 45deg. outer chamfer angle), but also depends on top cover design. The inner race is compression ring dependent so it doesn't matter, if it's 36 or 45 deg (e.g. "the Solos bearing is different than a standard IS bearing and is a 45/45 instead of a 36/45" - this is official statement from Cane Creek).
    Quote Originally Posted by PeterG
    Don't sell your Solos !!, looks like you need it.
    Are you sure the Hope you have is the (USA) Cane Creek IS and not the Camp (european?) IS ? I know it is sometimes confusing to figure it out. For instance, Cane Creek makes the IS-8 which is Cane Creek IS and the IS-8i which is "Campagnolo IS".
    I don't know the history, but it looks like both the USA and Europe have created an "IS" (international standard) but they are different from each other. Crazy, not helpful, but not surprising.
    Any Cane Creek (usa) IS should work on the Mojo and any Camp IS will not. But when purchasing, it is not always clear which you are purchasing.
    Slovakia (Europe)
    Quote Originally Posted by noshortcuts
    I got 2 Solos by mistake, so can sell one
    I've asked at Hope and Cane Creek - there is no real IS standard at all!.
    I'm sure, that Hope is 41.0mm/45deg. not a Campagnolo Hiddenset (41.8mm/45deg.). It's very easy to check this. Unfortunately neither Cane Creek nor Hope have published technical information about headsets on their web sites, so I couldn't compare the headsets before the purchase. There are also other parameters I haven't mentioned yet, e.g bearings height, that also can differ.
    P.S. For lower stack I've decided to use Hope assembly because of aluminium split crown race, that is easier to swap between forks (Pace Fighter, Fox Talas in my case).
    Attached Files Attached Files
    Feb 2007
    Why don't we make a list of headsets that fits? And which don't...
    For now i'm sure that extralite and hope doesn't fit.
    For you information Chupakabra
    Cane Creeks IS-2, IS-6 & IS-8.
    "Sharing the same integrated design as the IS-8, the IS-2's bearings also rest inside the head tube of the bike's frame, which has been specifically designed to cradle the bearings and manufactured to the Cane Creek IS worldwide standard. The IS-2 uses steel cartridge bearings and an aluminum bearing cover. Also available is the IS-2i (available in tall version only), which is designed to be compatible with the Campagnolo integrated standard. All IS headsets are compatible with Cane Creek Interlok spacers.
    IS = "integrated system." The IS design uses no cups. IS bearings rest inside the head tube of the bike's frame, which has been specifically designed to cradle the bearings and manufactured to the Cane Creek IS worldwide standard. The IS headset cannot be retrofitted to an existing bike with traditional headset cups. The IS-6 uses stainless steel bearings as an upgrade over the IS-2. For 2003 all 1-1/8" IS headsets are compatable with Cane Creek Interlok spacers.
    Construction: The IS headset is compatible only with specially machined head tubes- manufactured to the Cane Creek IS worldwide standard. The IS-2 utilizes bearing steel grade cartridge bearings. The IS-6 steps up to stainless steel cartridge bearings for longer lasting durability.
    Who rides it: This new headset innovation is limited to IS-equipped bikes."
    From cane creek website: http://www.canecreek.com/integrated-...-headsets.html
    Any others available?
    Interesting, "IS" is NOT "international standard", but an "integrated system" that CC calls a "worldwide standard".
    ADD Cane Creek "Solos IS" to the list.
    ADD Cane Creek "110 IS" should be good also.
    ADD "TOKEN Omega C1"
    ADD "TOKEN Omega T1"
    There are FSA headsets that are Cane Creek Integrated worldwide standard compatible, but I'm not sure which ones.
    The MTB Lab
    Reputation: pastajet's Avatar
    Bummer...it doesn't fit and they are very expensive in the US, think it's $162
    My Cane Creek Solo IS that came with the Mojo pops in just perfect. And no issues with it so far. Just had my Mechanic switch out the crown base to install the Manitou MRD that I am testing. 2 years of tough use and still a great headset.
    that token ti one is sharp..........thinking about it
    Cool the list goes on!
    Will make do with my Cane Creek IS-2 until I can afford to WW my Mojo SL arriving soon...
    Matt Scott
    MOJO BICHU
    Reputation: bichu du matu's Avatar
    My semi-integrated headset it`s from PRO ( by shimano). works great.
    Reputation: Irrenarzt's Avatar
    Yeah I had the same thing happen when I first built up my Mojo last year. I received a campy style IS6 and obviously these do not work. Gotta get the non campy style.
    Post up a link to the Token Ti one.
    Dec 2005
    hope doesn't work?
    Quote Originally Posted by mx_599
    hope doesn't work?
    Sounds like it. Faith still works for some people.
    Dec 2005
    hahahhaha
    Anyone got picture of Token headsets, never heard of them before.
    07 Giant Anthem 2 (Int'l Edition) | omartan.co.cc
    Im a MOJO Fanboy
    A bunch of pictures and price here: http://cgi.ebay.com/TOKEN-TITANIUM-I...QQcmdZViewItem
    If it does not work, just search Ebay, there is alway one on the USA Ebay site from procyclingdiscount.
    Slovakia (Europe)
    hope doesn't work?
    Depends on what do you mean. It works (the bearings fit Ibis frame correctly), but the top cover is designed for deeper frame reaming, so ugly gap between head tube top and headset top cover is a result. Btw, I'm going to use Hope bottom assembly (bearing and crown race), because Hope crown race is made of aluminium and split, so forks can be swapped easily (I have Fox Talas and Pace Fighter, so would like to test both).
    Slovakia (Europe)
    Quote Originally Posted by wheelhot
    Please find below manufacturer's web address
    http://www.tokenproducts.com/05htm/products.php
    You can always purchase extra crown races for different forks (split or not split). You could order new ones or local bike shops usually have many extras taken off other bikes if you can find one with the correct angle for the bearing. I prefer crown races that are not split for a better seal to keep more water and dirt out.
    When you use the bottom assembly, isn't the bearing going to stick out like it does on the top? I would consider Hope "not working" because that unsightly gap would lead to quick problems with water and dirt.
    Slovakia (Europe)
    Maybe in the States, but not here in the Slovakia I'd prefer original crown race, because there a more aspects to consider - bevel angle, bevel height, outer diameter, overall thickness. I had to order my Solos in the USA, in Europe there was no chance to get it (in red). I haven't found spare crown race in EU e-shops. Of course I have one spare headset, but would like to sell it rather then use crown race only.
    It's no so clearly with the sealing as you have stated. Anyhow there is unsealed area/gap around the crown race. If you know standard Hope headset (with press-in cups), it has seals around the crown race (2 O-rings), so this is another cup of tea. I think standard Hope is the best sealed headset I've ever seen/used (incl. Chris King) and nice designed too.
    When you use the bottom assembly, isn't the bearing going to stick out like it does on the top? ....
    No, bottom assembly is OK and fit well - Hope bearing is standard 45/36deg - 41mm dia.. so must fit OK.
    Dec 2005
    well now that's retarded.
    so do we have a list of hs that are "gapless"?
    there are several listed in this very thread. I list several for instance.
    Dec 2005
    yeah, but i didn't know i had to worry about gaps too. that is sad the hope doesn't work
    does anyone know if the CC 110 comes with a compression "star nut"?
    thanks
    Slovakia (Europe)
    thanks
    Did you look at CaneCreek's web page first? Don't be lazy...
    Dec 2005
    i looked at cc, right after i was done scoping out the ccdb. i still couldn't tell
