Results 1 to 6 of 6
    Dropper Post Cable Routing
    Ok, love the KS i950r but not thrilled with the cable being zipped to the others. Has anyone come up with a neat,clean way to run the cable? Interwebbed for hours and have not come up w/anything yet. Ideas?
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    Someone drilled holes and attached cable routing stuff with rivets. There's pictures on here somewhere.
    Reputation: brankulo's Avatar
    Aug 2005
    i have it routed on top tube through cable holders
    Need pics, this is going on my SL and I would like it to look factory.
    If you change to 1 x9 or 10 then you can use the front derailleur routing.
    Lightly salted
    Reputation: fuenstock's Avatar
    Try some Jagwire stick on guides. I've used them on 2 diffrent frames for dropper post routing. They work really good. I never had one come unstuck. They are made of a soft metal and easliy form to the bikes tube shapes.
    Jagwire C-Clip Housing/Hose Guide > Components > Brakes > Hydraulic Brake Lines and Fittings | Jenson USA Online Bike Shop
