Results 1 to 12 of 12
    Aug 2010
    Does the Mojo HD frame have a drain hole?
    Been riding my 2012 HD for 6 months now and it just dawned on me that every time I wash it I could be introducing small amounts of water into the frame. Anyone know if the frame has a drain hole anywhere? I couldn't find one but hey it could be hidden.
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    Huge 31.6 hole when turned upside down. But that's it.
    No...flip it over and let sit.
    Aug 2010
    Hmm time to remove the joplin and see
    DIY all the way
    Reputation: Mr.Magura's Avatar
    Aug 2010
    Throw in a goldfish, and call it a day
    Magura
    Aug 2010
    Hey now there's an idea. I wonder if Ibis can make a transparent frame so I can watch my goldfish while I ride.
    Reputation: getbusyliving's Avatar
    Haha, a while back someone posted here that they pulled their post and turned over the bike after a long winter and instantly shaved about 12 oz of (fluid) weight...
    After washing or wet riding, always remove the seatpost and flip the bike for some minutes. I've found some very rusty headsets bearings because this issue, either HD's or SL's.
    DIY all the way
    Aug 2010
    Quote Originally Posted by Bati View Post
    On a more serious note, this is very good advice.
    Carbon bits and frames, gives galvanic corrosion galore, once water is introduced to the formula.
    Steel and aluminum, will see a lot of corrosion, if they are wet and around carbon.
    Titanium and stainless steel, is not an issue.
    Anodized aluminum is mostly ok, as long as the anodizing is not broken through.
    Back when I made my first set of carbon cranks, I thought galvanic corrosion would not be an issue in reality, for at least a decade.
    After 8 years, I was proven sooo wrong, as the aluminum inserts simply fell out.
    For bearings, I would think less than a season, perhaps even a couple of months, will be enough to kill them, if in a wet carbon frame.
    Magura
    Oct 2011
    Who the hell makes a frame without a drain hole!? WTF
    From what I remember the Bottom Bracket is actually isolated from the seat tube. so the water that poors out doesn't actually hit the BB area.
    May want to confirm this with Ibis.
    Jan 2013
    My mojo c doesn't have a drain hole as well I guess that is apparent to all ibis frames. I always remove the seat post and flip it after every wash.
