    Reputation: jaymo's Avatar
    Disc's on cromo Mojo?
    Has any one had brake bosses put onto the older Cromo Mojo frames? If so were they brased on or did you have it done? And could you post pics if you have had it done.
    I guess no one has done this. I really this bike but would like to have the stopping power in the mud. Moving to Ashville next week end and am wanting to up grade. If any one has ideas I would apriciate it.
    Asheville has the best mountain biking in the world. You are moving to heaven on earth....
    I looked into adding disc brakes to my 1993 mojo a few years ago, but didn't follow through. It was also a 1 inch head tube which would need to be replaced to get a new front fork. We talked about changing cable stops to accommodate the hydraulic lines and changing the headtube angle to slacken it up a bit for a 100mm fork. It also needed to be repainted. I think it was going to be close to $1000 (but I could be wrong - it was several years ago). The cost was just too much for me.
