Results 1 to 33 of 33
    Reputation: expatrider's Avatar
    Feb 2005
    Demo'd the Ripley
    At sunshine bikes, Fairfax, ca. Great bike. Really a beautiful frame. Tubes are huge around the top tube - downtube junction (siimilar to Santa Cruz bikes). Bike was nice and light - about 25-26lbs with Fox CTD suspension, XT stuff, and Stan's arch EX wheels. Frame felt very stiff. Suspension action in the rear was excellent, as expected, but the way the bike accelerated was way better than I expected and I think with the right build It could easily be 24lbs and would make a phenomenal race bike. It is very fast. Definitely not a super plush ride, but again to be expected somewhat given that it is only 120mm. Nonetheless, it still felt good because of the suspension action. Also it was a demo so was not dialed as it could have been. It was very impressive in the tight twisty stuff for a 29er, and is definitely a Singletrack slayer. It was a actually a little odd at times as I forgot I was on a 29er when zipping around, only to be reminded when it found stupid amounts of traction when cornering, or just getting up and over technical climbs without fuss. As a testament to this, the tires were spesh fast trak, which I have used in 26" before and hated. Fast but no traction. In 29 flavor, they were both fast and got great traction for such a XC race type of tire. I would have loved to have found out how it handled the gnar, but just did not have enough time to ride it to those trails where i could find out. I think for my purposes i might want something with a little more travel but this was an impressive bike no doubt.
    Thanks for the write up....
    "bike accelerated was way better than I expected " personally I'm looking for a fast manueverable bike for XC, so this sounds positive.
    Just curious if you're riding an ibis bike right now? HD? If so how does it compare?
    I, as well, grabbed a bike from Sunshine but got a longer time period to ride it so I was able to hit some gnar. The bike is the best all around mountain bike I've ever ridden. The only FS bike that I've been on that climbs better was an S-Works Epic but the Ripley blew the Epic out of the water when the trail got technical and/or pointed downhill in any meaningful way. I view it as an XC race bike quite a bit of travel over an all mountain bike with a bit less travel (think Blur TRc). There is definitely room for my HD 160 and the Ripley in my garage.
    Feb 2005
    Quote Originally Posted by canuck_tacoma View Post
    Maneuverable is exactly right. I am coming off a Santa Cruz Blur TRc, possibly the most agile bike I have ever ridden. So to go from the TRc to the Ripley, and find the Ripley to be almost as agile is quite a compliment. The only place where the Ripley was not as good was going down tight switchbacks, which took a little more rider input. Getting up and around those same switchbacks was actually easier on the Ripley, which was weird, the opposite of what I was expecting.
    I have never owned an Ibis. I demo'd the SL up at Downieville, and have ridden a friend's HD. I currently own a TRc and a Nomad, and always preferred the Nomad to the HD. I cannot offer a good all round comparison of the Ripley to the HD as I just did not get enough time on it in varied conditions. What I will say is the Ripley is significantly faster up hill. The big wheels also give it the edge in technical climbing. The geo seems to be much more suited than the HD to XC. I never got to ride the Ripley down any gnar, so cant compare the two there. However, my gut tells me the HD would be much better. If what you are after is a bike for XC then you can't go wrong with the Ripley. It's fast. Reminds me a little of the Titus Racer X I had a number of years ago, except the 29" wheels make it a better tech climber and give it much better cornering traction.
    Feb 2005
    Quote Originally Posted by anomaly View Post
    I, as well, grabbed a bike from Sunshine but got a longer time period to ride it so I was able to hit some gnar. The bike is the best all around mountain bike I've ever ridden. .
    Out of interest, what trails did you ride? Better than your HD?
    I climbed Pine Mtn to see how it was on the Oh **** climb and the following rock garden climb (it did very well though Oh **** is generally in the best shape I have seen it in 4+ years right now for some reason) then took White's Hill Fire Rd down and hit a couple short things off that before going into Tamarancho then back out and down Porcupine. To me White's Hill FR and Porcupine are a good enough test to get a feel for an XC bike, which the Ripley is in my opinion. The rock garden at the top, while short, will quickly let you know if the suspension wouldn't keep up on a trail like Solstice while the water bars and s-turn on the fire road give you a very good taste of the high speed handling. I got a very long and solid 2 wheel drift going through the turns with total comfort, the GC/Fast Trak wasn't nearly enough tire for how hard I was pushing. Porcupine shows you the tight switchback mannerisms plus you get a couple good turns through chunk at full speed.
    The Ripley is a great long travel XC bike similar to the SL-R. It is by no means a replacement to an HD which is built properly (I run mine with a Vengeance @170 front, Vector rear, Hans Dampfs, Flow Ex, etc) nor is it intended to be. I'll buy one and happily ride it at Annadel, Skeggs, Solstice, Tamo and some spots of SG ridge. I'll keep the HD for stuff like Oat Hill Mine, Pacifica, Santa Cruz, etc.
    One other thought, I climbed back up on the HD to do work on the Flow Trail and went out Porcupine. The HD was significantly faster through a couple sections and no slower anywhere though I imagine the right stem and tires on the Ripley would have made them very close on a trail like that which is open and carries speed throughout.
    Reputation: Colin+M's Avatar
    Great Info! Thanks. Have you ridden any other 29ers that you can compare and contrast with?
    Quote Originally Posted by Colin+M View Post
    I've ridden lots of other 29ers, both HT and FS. Most recently I owned a Kona Satori which I rode extensively and raced at Downieville last year. The Ripley obviously climbed in a whole other league (very close to S-Works Epic) but didn't feel as good on the descents (quite a bit better than an S-Works Epic). It was not nearly as plush though running similar amounts of sag. From my limited time on the bike (with a 100mm positive rise stem and an XC oriented tire setup) it is an XC bike which happens to have 120mm of travel versus an AM bike which happens to have 120mm of travel. I would personally run it with a 70mm stem and some grippier tires which I think would really be able to utilize the frame.
    If you only care about going as fast as you can up a smooth trail, get an Epic.
    If you care about going fast all over the mountain, get a Ripley.
    If you care about going down hill very fast and want a 29er, get a Satori.
    If you care about going down hill very fast and want a 26er, get an HD.
    Levi Early
    Reputation: Levi707's Avatar
    good to hear some reviews. i am thinking this might be an option over the sl-r i have been eye balling
    @anomaly: You ever tried the Yeti SB95 or Intense Spider Comp and if so - how does the Ripley compare to them?
    Reputation: simenf's Avatar
    Nov 2008
    Add the SC Tallboy LTc in the mix.
    Feb 2005
    I demo'd a TB LTc which was built up a little heavier than the Ripley. I loved the TB.
    Climbing up the techy stuff, both bikes were very good. On all other climbing, I'm not sure if the Ripley is much quicker, but it felt much more efficient if that makes sense. I think this just has a lot to do with DWL vs. VPP, with the DWL having the edge over VPP in that regard in general. But also I came away thinking that this iteration of the DWL was executed extremely well. The rear suspension really is impressive. I think the 120 of travel vs the 135 also played a role here in making me feel like the Ripley was a more efficient climber.
    Like I said, I did not get to ride the Ripley down any gnar, so can't offer direct comparisons there to the LTc, but the TB felt like an AM bike going downhill, very confidence inspiring, and my gut tells me the TB would be quite a bit quicker downhill. However, the Ripley did have XC tires on, and I think with proper tires there would be a significant improvement.
    I think for an all rounder, the TB LTc is probably better. I'm leaning toward it just because I want a bit more travel. For a XC race bike, the Ripley. For a great handling trail bike, either one.
    @Danish and @Simen, I've only ever pedaled a TB and LT around for short distances, not enough to enough to get a real solid feel for either. That said quick impression is that the Ripley goes up and down better than a TB and happens to have 20mm more travel.
    How about a Niner RIP Nine RDO?
    Geo numbers are very close to the Ripley, except for a longer TT.
    Mar 2013
    I demo'd the Ripley on Saturday as well. I rode up Loma Alta - 680 - Solstice. My impressions of the bike are much the same as everyone's here. XC/Trail bike leaning towards XC. However, much of this was due to the way the bike was setup with 120 fork, XC tires, 100mm stem. I think with a 140 fork some beefier tires and an 80 mm stem ti would be different bike on the descents.
    It certainly climbed like a dream, and made the stinger sections of the loma alta fire road pretty painless.
    I am almost 6'2" and 200lbs. The bike felt small to me, and the XL would be a better fit. The seatpost (KS Lev dropper) was maxed out and I could have still used a cm or two of height. I felt overly forward on the bike during the Solstice descent, and I think the slacker angel with a longer travel fork would help significantly. The fork was doing some pretty viscious brake diving which contributed to the lack of confidence on some of the bigger sections of Solstice.
    I swapped to my buddy's C Tallboy (no LT) and it descended much more confidently than the Ripley, based upon the stock setup by Ibis.
    The owner of Sunshine is getting an XL, and I'm hoping he gets the 140 fork so I can take it out for a spin to see if it can be the all-around trail bike I'm hoping for.
    Dec 2012
    I'm currently racing a Scalpel Ultimate and have an itch for a little longer travel ("Trailish") bike. Do any of you think this would be an option?
    May 2010
    I wanted a Ripley but after waiting forever I couldn't wait anymore and last November opted for the SC TBLTc.
    The one thing I'll recommend to anyone who gets the Ripley and likes to ride some steep gnar is to look into the angle set. Imo, the Ripey and TBLT are way too steep and slacking the head angle down to 68 or less completely changes the bike. It doesn't surprise me that Ibis offers the CC angle set as an option, I think they know it could be slacker. In my case I went for the Works since the CC AS gimbal design has quite a few complaints. Regardless, the slacker head tube made the bike unbelievely more stable on the fast steep stuff and I can't recommend it enough.
    BTW, the Ripley looks like a beautiful bike and I don't think you can go wrong with it. The geo is very similar to the TBLT and I'm enjoying the TBLT with the slacked off HA.
    Of course the Ripley is already a degree slacker than the LTc, so it will probably already be an improvement in that regard. Although I must say that the LTc felt more slack and stable than the numbers would suggest.
    Yes. Plus it holds a water bottle in the correct spot on the bicycle frame. Game over SC LTc.
    May 2010
    Ripley is 70 and TBLT is 69.5. The Ripley and TB are pretty much the same in terms of geometry. The rear linkage is where they diverge. Like I said the Ripley is a really nice bike but for AM it's too steep. I predict a bunch of threads in the Ibis forum regarding angle sets in the near future.
    I'm more of a dog person
    Reputation: unclekittykiller's Avatar
    Feb 2006
    if you spec them with the same 140mm fork the Ripley is slacker
    with a Fox 34 140mm fork: Ripley 68.5, LTc 69.5. With a 120mm fork the LTc would have a 71 degree head angle. Not to mention the Ripley has shorter chainstays and a shorter wheelbase.
    I do agree that 68.5 is steepish for all mountain, but I don't think that this bike is even in that category to be honest nor is it being touted as an all mountain frame as far as I know. Neither is the LTc, Intense Spider Comp, Yeti SB95, RIP9 RDO etc, etc for that matter. I would call them trailbikes (Santa Cruz even calls the LTc a trailbike on its website). If you want all mountain in 29er you're gonna have to look towards Lenz Lunchbox, Banshee Prime, Specialized Enduro 29, Niner WFO etc.
    I would say that the main things the LTc and Ripley have in common are 29 inch wheels and carbon. Not that it means one is significantly better than the other.
    May 2010
    Quote Originally Posted by unclekittykiller View Post
    Yes indeed the 70 HA is with the 120mm fork.140mm is 68.5. The 140mm will handle pretty nice then. Why couldn't Ibis have gotten this to market 12 months ago? smh...
    No kidding Hopefully it will be worth the wait. The LTc is a bomber bike though.
    How does the Ripley wheelie? I have a Jet 9RDO and can only get the front wheel up a few inches. On the Mojo HD I could pop that front wheel as high as I wanted it to go. That to me is the true test of a bike's handling
    Reputation: miles wadsworth's Avatar
    Nov 2006
    Quote Originally Posted by donkeyrider View Post
    How does your donkey wheelie?
    milesW
    Quote Originally Posted by miles wadsworth View Post
    Poorly!
    I found the Ripley to be easy to wheelie and manual. It wasn't as easy as my Satori was, but that isn't surprising given the stem length and the longer rear end. That said I can wheelie pretty much anything...
    Reputation: mazspeed's Avatar
    I was able to ride a ripley albeit in the parking lot of trailhead cycles in SJ. It is a very snappy bike for sure. I ride a med in the slr and HD but the large felt good on me. It is very quick and tracks well, for the limited time 10 min i was on the bike, but it felt really good. Great fit. I would be curious on how the bike performs downhill with a 140 fork, but its a nice fit for me.
    Quote Originally Posted by mazspeed View Post
    Just curious how tall are you? Do you recall what length of stem they had on it?
    Short stem, maybe 50mm. I am 5'10 228lbs 32 inseam.
    I did a parking lot/road/stair demo as well, the L I was on had a 90 stem, flipped neg 5degrees and the 120fork.
    the numbers with the 140, dimensions and amazing pivot design and cable routing made me order. I was looking at spider 29comp, jeckl 29 (which I also rode, and it was sweet, just not a elegant and light), and spesh fsr29. i felt i was between on many of the companies sizing for where I wanted to be, but ibis L was just right and oh so sweet.
    at 5 11, 33 inseam, I ordered it w/ the 140, and an 80mm stem.
    they say 4 to 6 weeks...
    cheers,
    Holiday
  1. Replies: 31
    Last Post: 08-31-2015, 03:12 PM
  2. Ripley - believe it or not, it's here!
    By doismellbacon in forum Ibis
    Last Post: 04-17-2013, 06:19 AM
  3. Any Updates on the Ripley?
    By nevermiss in forum Ibis
    Last Post: 02-26-2013, 03:07 PM
  4. Ripley SL?
    By westin in forum Ibis
    Last Post: 12-24-2011, 11:37 AM
  5. Demo'd an Ellsworth today
    By Colo Springs E in forum Colorado - Front Range
    Last Post: 05-09-2011, 11:51 AM
