I'd love to see pictures of what you all did to protect your carbon frames from chain slap and other common hazards. I've got the frameskin kit, but I'd like to see other solutions too.
Along with fishboys' frameskin kit, I used an old tube, wrapped in framewrap, (framewrap.com) and then put on the Ibis logo'd chainstay protector. I also use an old Lizard Skins chainstay protector for the seat stay to keep the chain from slapping against that.
I've done basically the same thing as TTT, but still get a lot of noise from the chain slapping the chainstay near the chainrings where the Ibis protector doesn't cover....I've seen pics in this forum of folks gluing on pieces of velcro or innertube cut to fit this spot...need to do the same myself. When that chain's slapping bare carbon, it's LOUD!
Today I wrapped the chainstay in an old tube and put the lizard skin thing on top of it (the tube covers more of the chainstay). I put a few layers of electrical tape on the inside near the cassette. Maybe I'll try velcro or the framewrap thing.
It certainly would be nice if the bikes came with these things--or even as an extra option.
Pre frame-wrap I used to make a product out of closed cell foam and adhere it to the frame along the top and underside of the chainstay, and on the underside of the seat stay. Pretty dodgy looking but functional... some early pics here http://forums.mtbr.com/showthread.ph...38259#poststop
Framewrap works great but if the noise is still not to your liking, add a layer of closed cell foam under the framewrap (topside and underside of chainstay) and it works a treat.
Al
Frameskin Bike Protection Film
Protect your plaything! www.frameskin.com
Supporting Kowalski Brothers Trailworks
The down tube cover in the HD looks like a good idea someone should make and aftermarket one for the Mojo - such a simple idea, bolts on the water bottle boss - a use for them at last!
Here's what I have now.
It's basically tennis racket tape. It eventually wore through, and in a rush I threw on some black duct tape over it, which has been rock solid for 4 months now. I have no plans on removing it until I need to.
I had one of the cable guides get ripped off on the seat stay during a road trip to Whistler. I replaced the 2 back sections of housing with one long piece, and wrapped the tennis tape around it. Holds the cable in place, and protects the frame. I just need something at the junction between seat and chain stays. It's gotten pretty badly chipped from the chain. That's a hard area to protect IMO.
What chain guide is that? You running a single now? Oh and clean that filthy beast lol
It's an e13 DS. Still running a 2X9.
That is clean! It looked like this after Boggs last weekend.
When I got home I weighed it, and the mud added about 3lbs.
The polycarbonate down tube protector on the HD will fit on the Mojo. You just have to use something like double sided tape to secure the top portion of it, since the Mojo does not have the bolt at the top that the HD does.
you guys need to go to pricepoint.com and buy Bonk! It's a clear film/tape that can be applied on all areas of your bike and does a great job of protecting the frame from cable rub and chain slaps. I've used it for a month and a half and nothing has been able to cut through it or mark it up.
thats a waste of cash, bought 3M film for 5 bucks directly through the 3m website a while back (minus bonk spray, which isnt anything necessary)
if your spending 30 bones, might as well buy the precut fishboy kit
I seem to like to slide out on the left side and take it out on my rear tri. The "high mod composite" lettering is not looking so good. Rock vs carbon is not a fair fight. It will be getting some copter tape and some tire rubber glued to the tape. It seems to be a problem with the rider. I will hit the bike with some rubber to protect and dampen chain slap while i'm at it.
I cut a strip of neoprene from an old wading sock and taped it to the bottom of the frame using double-sided tape. After that I wrapped it with an old inner tube and zip tied the ends. This really cut down the chatter from chain slap and doesn't look too shabby either.
Just bought my Ibis and noticed the same problems and had the exact same concerns as everyone else. This post has been great! It's answered all my questions. Love this forum.
Thanks everyone. Happy riding
