Results 1 to 19 of 19
    Creaking noise when I'm putting power down.
    So I can't duplicate the noise when I'm off the bike so I'm not sure what it could be. The noise only happens when I'm seated and I'm putting power down up steep incline. No noise when I'm off the saddle or when I'm just spinning while seated on lesser grade of incline. I can trackstand and bounce on the suspension with no noises. So I'm out of ideas where it's coming from....
    clean your cable housing ends.
    Reputation: GuruAtma's Avatar
    I had the same problem. It turned out to be a dirty seat post. I took it out, wiped it down and all the creaks went away. I love easy solutions.
    功夫大师喜欢骑着他的自行车在山上。
    Happy when not-last.
    Reputation: MinskyBA's Avatar
    Check the seat post and the seat rails where they meet the clamp on the seat post.
    All your base are belong to ME.
    Reputation: bedell99's Avatar
    Had the same problem. it was my cable furrells.
    Erik
    Fragglepuss The Chaste
    Reputation: slcrockymountainrider's Avatar
    I had the same problem once and it turned out to be the hose to my colostomy bag rubbing on the seat tube mounted triathalon water bottle holder.
    Either that or you're low on shifter fluid.
    Another less obvious but fairly common one is the rear wheel, specifically the freehub or cassette.
    Pedals, especially ti spindle ones, BB cups, chain ring bolts, tighten the rear QR and see if it changes.....
    H
    Check where your rear shifter cable meets at the base of your seat post. I was getting a squeak from that area but not when my rear shock was locked out.
    www.derbyrims.com
    Reputation: derby's Avatar
    Under power... I used to get that only while cranking hard with quick release rear hubs on my Mojo. Since going to 10mm bolts that creak is gone, except recently I forgot to tighten one side up real good and the familiar creak returned until I checked that.
    Could be a loose cassette too.
    Slothful dirt hippie
    Reputation: verslowrdr's Avatar
    I'd reef on the seat, change it, wipe it down, etc. I've had hecka creaking off and on from the seat post. Fortunately my hearing is bad and my 'ignoring harmless noise' skilz are good... 16 years married this year, what can I say.... :P
    "...Some local fiend had built it with his own three hands..."
    Reputation: getbusyliving's Avatar
    Another idea: Depending on your saddle design, lube where the rails enter/attach to the saddle. After a couple years my Fizik Aliante developed a nasty squeak the next ride after wet rides. I lube where the rails enter the plastic at rear of the saddle and voila...silence.
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    If it only happens when putting down the power it could be your knees...
    Well..the noise is gone. I tighten the seat clamps, the rear wheel QR and wipe down the whole seat post.
    RPG
    RPG is offline
    I have the same issue, but i know it is coming from the rear brake. When I am off it, the wheel spins freely, but when I'm cranking hard on a turn or in general, I can hear the rotor squeak against the pads.
    I tightened the qr, what else could it be? Do I need to replace the pads? SOrry to highjack, but this falls under the same topic.
    Ryan
    Quote Originally Posted by RPG
    Ryan
    Your pads are possibly contaminated if they're making noise like that. I'd suggest replacing them and check to be sure your rotor is as close to dead-center between them as possible.
    Church of the Wheel
    Reputation: mtb143's Avatar
    Ryan
    Check your hub bearing adjustment. A small amount of play can allow the rotor path to change just enough to rub when cornering or applying an uneven side load to the rear wheel.
    "I thought you'd never love me without my Mojo." -Austin Powers
    Ride More Work Less
    I'm convinced the clicking noise I have is coming from the XTR rear hub. I've done everything else to isolate it and it only happens during the steep, slow, seated climbs. LBS has taken it apart twice but see nothing wrong. I have one year left of warranty and will somehow convince LBS (or Shimano) to replace under warranty as it has happened from the very first ride.
    Reputation: miles wadsworth's Avatar
    Nov 2006
    Quote Originally Posted by avam
    Have you tried putting another wheel on with the same cassette?
    milesW
    Ride More Work Less
    Quote Originally Posted by miles wadsworth
    No, but I have swapped an entire rear wheel and the noise disappeared.
