Results 1 to 14 of 14
    Chainring for E*Thirteen 1x11 on Ripley
    Just picked up a Ripley with a X01 kit which came with an E*Thirteen crank and 32T chainring. I'd much prefer a 30T chainring (lots of climbing here in the Colorado front range) and my LBS offered to swap it out, except that apparently E*Thirteen is out of 30T rings and has no idea when they're going to be available again.
    Are any other manufacturer's chainrings compatible? Anyone have any info on when E*Thirteen will have 30T rings available? I'd be perfectly happy with another kind of 30T chainring as long as it was good quality and worked with the E*Thirteen cranks.
    Thanks...
    mdc
    mdc is offline
    Reputation: mdc's Avatar
    I've been using a Race Face narrow wide 30 tooth on my eThirteen cranks with no problem. I have a 1x10 setup, but they are compatable with 1x11 as well...
    Quote Originally Posted by mdc View Post
    Is that a direct mount chain ring?
    mdc
    mdc is offline
    Not a direct mount. I got one of these:
    Race Face
    I've maybe dropped a chain 2 or 3 times- otherwise it's been flawless.
    Race Face
    My point was if he has a 1x11 Ripley build with the E13 crank he most likely has a direct mount chain ring. I'd be surprised if the splines match Race Race.
    Quote Originally Posted by MTBMILES View Post
    Yeah, that's my basic question. Not sure if I have other options or have to wait on E*Thirteen.
    You can buy a direct mount 30t from the e13 website, or are they out of stock?
    Reputation: Sallen4520's Avatar
    Man I would suck it up and start pedaling and when that 30 t comes in you will be a beast on the climbs
    It looks to me that e13 has them available on the store at the Hive. The store does show some things as out of stock, but the particular 30t direct mount guidering (as they call the 1x chainring with narrow/wide teeth) shows as available.
    2013 Ibis Ripley
    2012 Ibis Mojo SL-R
    2009 C'dale Rize 3
    Quote Originally Posted by DRSpalding View Post
    I just checked the site, the 30T direct mount guidering is showing as out of stock.
    Quote Originally Posted by Sallen4520 View Post
    That's what I'm doing now. It works, but for someone with questionable knees and a history of back issues, having a lower gear really helps with those long rides with a lot of climbing.
    Oooo. Yeah that 30 t will be a breath of fresh air then huh
    This is what I put on mine Guidering M Direct Mount | the hive
    went with the 28T. I ran the 30T for a while and found it was just a touch high on the gear ratio my old knees. Only issue now is the loss of top end which is no big deal enjoy your X1 setup.
    Fortes fortuna adiuvat
    Aug 2013
    You could get an e13 spider and any 30t guidering. Personally i use the 28t direct mount guidering, and i dont think going from 32t to 30t makes enough difference.
  1. E Thirteen pressed bearing problems on a Ripley?
    By RooHarris in forum California - Norcal
    Last Post: 5 Days Ago, 09:21 AM
  2. 1x11 with a non-sram chainring...
    By mhopton in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-10-2014, 05:11 PM
  3. Replies: 22
    Last Post: 01-08-2014, 11:17 AM
  4. Replies: 9
    Last Post: 06-05-2013, 01:34 PM
  5. E Thirteen XCX-ST with 34T chainring cadabra
    By nosewheely in forum Kona
    Last Post: 02-22-2012, 08:08 AM
