Results 1 to 12 of 12
    Chain suck thingy fell off - what glue?
    Just wondering what type of glue any of you have used to glue that little silver sucker back on with .
    Thanks,
    Straw
    Ease & Flow Where Ever I Go
    Rides a Bike
    Reputation: fishboy2807's Avatar
    You could use something like araldite (a 2 part epoxy)
    Frameskin™ Bike Protection Film
    Protect your plaything!
    www.frameskin.com
    Supporting Kowalski Brothers Trailworks
    aka übermensch
    Reputation: Triple T's Avatar
    "We recommend JB Weld to install one of these beauties. You can find it at a hardware store near you." Found that info in the Ibis store.
    Any 2 part epoxy should do the trick.
    08 Ibis Mojo SL
    09 Ibis Tranny SingleSpeed
    Reputation: BitterDave's Avatar
    Nov 2007
    I used some automotive trim adhesive, but that's because I had a tube of it laying around. I've read that you can use JB Weld also.
    Ride More Work Less
    I have a nice layer of JB Weld on my frame that has taken the place of the protector as it just won't stay on. Popped off 3 times now.
    holding back the darkness
    Reputation: subliminalshiver's Avatar
    JB weld failed to work? Impossible. You're doing it wrong.
    Thanks guys I'll get some JB weld
    Cheers,
    Straw
    Before you glue anything down; you should have a look at the 3M VHB tape.
    http://solutions.3m.com/wps/portal/3M/en_US/VHB/Tapes/
    http://www.youtube.com/profile?user=...7BC924132F3283
    I do believe that it is a good alternative to the two pot epoxy method, as bonding a metal to a flexible plastic/resin surface, often result in the metal popping off/ delaminating. Do note that the tape will add some thickness to overall connection.
    Shaun.
    Dec 2005
    Quote Originally Posted by subliminalshiver
    epic fail!
    Ride More Work Less
    Quote Originally Posted by mx_599
    epic fail!
    Ok, I'll confess. I used the JB Weld quickset stuff. Seems like it still should hold though. I bought the regular JB recently to help with my cable stop repair and do plan to give it one more try to keep this thing on.
    Reputation: getbusyliving's Avatar
    After losing mine a couple times, I decided to just try tightly wrapping some inner tube around that area a couple times and tightly securing w/ few zip-ties. The zip ties and tube combo protect frame from chain, and if you break a zip tie, easily install another. This has worked pretty well, and seems to make it easier to release chain when backpedaling after chainsuck than with the metal plate.
    Not perfect solution but less annoying than clean, sand, mix glue, stick on, lose plate again, buy another, repeat.
    Turn off the TV
    Reputation: SMT42's Avatar
    Nov 2006
    +1 for the tube. Recycle it's the new in thing.
