Results 1 to 14 of 14
    Jan 2009
    Chain Slap Help Mojo HD!
    Hello!
    I'm getting a lot of chain slap and was wondering what everyone was doing to get rid of it. Its starting to really annoy me right now.
    Would a chain guide help or maybe shortening my chain?
    Thank!
    Chainguide or clutch RD. I use an e13
    Heim 2 with a Turbocharger bash.
    Any sufficiently advanced technology is indistinguishable from magic
    - Arthur C. Clarke
    Ibis Addict
    Reputation: kidmojo's Avatar
    Re: Chain Slap Help Mojo HD!
    I use this and works very well. The weight is only 18 grams.
    Enviado desde mi GT-I9000 usando Tapatalk 2
    1 - Correct chain length, simple, but few people take the time to set this correctly.
    2 - Shadow Plus or Type 2 Drlr
    3 - Use a guide. Note: a guide with chain that is too long won't give you relief.
    my .02
    Jan 2009
    Where did you get that from and how much?
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    The cguide is pretty good. $40.
    Google will tell you where to get one.
    Dec 2010
    Quote Originally Posted by d-bug View Post
    +1 on the cguide, works great!
    Reputation: rossp's Avatar
    Mar 2005
    Do you guys find the c-guide makes it a lot quieter? Mine doesn't seem to make a big difference - have the chain as short as I think I can.
    aka dan51
    Mar 2005
    Quote Originally Posted by rossp View Post
    I had written a ton, but the ****ing forum "Reply to button" drew my attention (and mouse) instead of the "Post Quick Reply" button, so all my work is lost.
    Long story short, noise is likely coming from your front derailleur.
    See this thread, port 220 and the next few after that.
    Hey Ibis/MRP How About a Dual Ring Chain Guide for the Mojo and Mojo HD?
    Mar 2005
    I think you could be right - hadn't really thought about it too much but now I read that thread it could be the case....will investigate with a few chunks of rubber...
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Yeah, my Trek Superfly 100 Pro has the same one-bolt, direct-mount FD. Try shimming the FD out by 2mm, using a small washer behind the mounting hole.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Reputation: sdemars's Avatar
    Mar 2011
    1x10 with an XX1 crank and a Type 2 Rear der makes it silent in all but the most rough high speed trails. Still no drops even there. With the Ibis sock chain stay guard I still don't hear any chain slap but I can feel it move - not in an annoying way. It's more of, "oh, hey I guess this is moving my chain around."
    Overland : Hayduke : Hightower LT : Delirium : Piolet
    Reputation: brankulo's Avatar
    Aug 2005
    get rid of fd, get clutch rd, and narrow wide chain ring. simple setup, quiet too.
    Stupid is, as stupid does
    Reputation: spunkmtb's Avatar
    The c guide works great
    Yeti SB95C
    Carver Ti 420
    Ibis HD3
  1. Replies: 8
    Last Post: 10-18-2014, 12:31 PM
  2. Help get rid of chain slap
    By jts140 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-26-2013, 01:21 AM
  3. Chain slap !?
    By tsuful in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-08-2011, 08:56 AM
  4. need some help with chain slap on a Rip 9
    By Lucid in forum Niner Bikes
    Last Post: 05-27-2011, 08:57 AM
  5. Chain slap on RIP 9?
    By farmertan in forum Niner Bikes
    Last Post: 02-07-2011, 09:54 AM
