Results 1 to 9 of 9
    Lev
    Lev is offline
    You Guys Riding?
    Reputation: Lev's Avatar
    Which chain guide do I want?
    Hi folks,
    I'm going to make the jump to 1x10. Was curious which chain guide will work best for me.
    I have a Shimano SLX crankset with the 22/36/bash combo. 11-36 in the rear. Planning to go 32 in the front. Thanks for your input.
    mountain biker
    Reputation: slyfink's Avatar
    would help to know what bike...
    continuous growth is the strategy of a cancer cell.
    Lev
    Lev is offline
    You Guys Riding?
    Quote Originally Posted by slyfink View Post
    Sorry. Mojo HD
    Lightly salted
    Reputation: fuenstock's Avatar
    This one, It's made specifically for the HD. Buy it direct from Ibis.
    http://store.ibiscycles.com/ibismrp-...o-hd-p111.aspx
    Lev
    Lev is offline
    You Guys Riding?
    Quote Originally Posted by fuenstock View Post
    Thanks man. That's the one I was checking out. Wasn't sure if I wanted the Lopes guide instead
    Sent from my Galaxy Nexus using Tapatalk 2
    Jun 2005
    I'm about to switch to a 1x10 setup on my HD. I'm running the XTR Shadow + rear derailleur so I'm going to run without the chain guide to start but if it becomes an issue I'm going with the HD specific one from ibis.
    Reputation: Geeze6700's Avatar
    I am running a 32T 1x10 with an MRP 1x guide and a shadow plus on my Tranny. No more dropped chains/suck.
    I have been running the XTR Shadow plus on my HD with the Ibis/MRP G2 guide with the lower roller/guide removed. The drivetrain is pretty quiet and I have had no dropped chains. I like this setup because you don't get the perceived drag of the lower roller when climbing for an hour.
    The only reason I wound up with this setup was because my chain lube of choice ate through the plastic of the lower roller guide. OOOPS!
    Jan 2011
    I'm running a 1x10 with a 34t chain ring, Shadow Plus med. rear and E.13 1X direct mount chain guide and I've dropped the chain twice - I'm going to the Lopes MRP guide. Hopefully, that'll keep my chain on.
