Results 1 to 14 of 14
    Chain getting stuck on Mojo HD lower link.
    I've had my chain stuck between the front lower link bolt and small chain ring quite a bit. The narrow 10speed chain just fits perfectly through the space and the chain can get jammed. If I don't realize it I will bend the chain when I go to pedal.
    Just wondering if there's anything that can be put on the end of the lower link front bolt to close the gap a bit? Maybe IBIS has a fix for this?
    I'm not interested in a chain guide because I need the triple, the XTR Derailleur is too expensive, and I have the chain as short as I can get away with.
    Aug 2010
    So adjusting the derailleur range screw isn't an option?
    What about something like this?
    K-Edge Chain Catchers
    I haven't tried any of these, but it looks like it would prevent your chain falling between the small ring and the frame. There's other designs too - search for "chain catcher".
    Correct number of bikes: n+1 bikes
    Correct body weight: m-10 pounds
    Quote Originally Posted by AlsTrance View Post
    No, the derailleur is not the issue. It happens when I lose the chain on decents...
    I have ordered the Chain Catcher and will see how it does...probably get the XT Shadow Plus when it comes out too.
    K-Edge Dirt-3 Chain Catcher on Mojo HD
    Now with more slacking
    I've had the same issue a couple times on my HD. Would be interested in a good fix if you find one.
    Reputation: kiwisimon's Avatar
    Are you descending with the chain on the granny gear? How about flicking it to a bigger chainring to create less free chain.
    Quote Originally Posted by kiwisimon View Post
    No, I use the Middle or Large chain ring.
    Here's the Chain Catcher installed. Fits great and I tried to force the chain off the chain ring by hand it seems to hold it in place.
    Aug 2010
    Ahhh I see. I run a 2x9 and use the e13 Heim 2RS Chain Guide. It seems to work really well with no chance of the chain jumping in either gear.
    I run a Triple and ride a lot of XC with the bike, so I'm not interested in a chain guide. This will not stop the chain from bouncing around, it just keeps it from jamming in between the BB and the Crank.
    Reputation: skellz's Avatar
    just ordered one for my SL
    Ibis Hd3 2016-Boost frame
    2002? MountainCycle San Andreas
    edit...wasnt fitting right on my SL. changed spacers round....fits like a glove
    I'm still happy with it...no more stuck/bent chains. Works as advertised.
    Thanks Canuck. Just fitted one to my new build. Pricey for what it is but worth it to protect frame.
