Results 1 to 5 of 5
    Sep 2013
    CCDB on Mojo HD small
    Hello folks, I am tring to install a CCDB in 7.875x2.25 on a small Mojo HD with the 140mm chips, in order to run 27.5 wheels with it. However, I found it is impossible to install the shock in the same way shown in Ibis' website. I had to flip it up side down, so the damper is beneath the stanchion. Even though, I found when the shock is bottomed out, the damper will hit the frame. So here is my question. Will the 7.5x2 CCDB work with the small HD? Can I use a 8.5x2.5 CCDB with the 160mm chips on the small HD? Many thanks!
    I'm pretty certain it is mentioned somewhere that remote resovior shocks will not fit on small HD frames. If you search the forums I think there was someone who managed to fit some remote rssovior shocks on a small.
    Sep 2013
    Quote Originally Posted by d3toid View Post
    Thank you. I searched the forums, and found that Monarch plus will fit on small HD frames. It's a shame that CCDB doesn't work out, maybe I should have bought the medium...
    Off the back...
    Reputation: pinkrobe's Avatar
    I can confirm that the CCDB fits on the HDR 650B small frame. Not much help for the OP, but might help somebody else doing a search.
    @pinkrobeyyc
    #pinkrobeyyc
    Sep 2013
    Quote Originally Posted by pinkrobe View Post
    Could you post a picture? I am curious how it looks. Thanks!
  1. Mojo HD and CCDB Air!!!
    By Rb in forum Ibis
    Last Post: 09-03-2014, 02:06 PM
  2. XPOST---MOJO HD & CCDB-Air!!!
    By aappling72 in forum Shocks and Suspension
    Last Post: 02-18-2012, 12:27 PM
  3. small mojo
    By 01tracer in forum Ibis
    Last Post: 04-14-2011, 10:18 AM
  4. Mojo HD small with RC4 coil
    By airzoink in forum Ibis
    Last Post: 03-18-2011, 08:03 AM
  5. Mojo with CCDB
    By kaku in forum Ibis
    Last Post: 01-28-2011, 06:45 AM
