    Brake hose length for Mojo med
    Hello. Can anyone tell me if a 125cm rear brake hose length is sufficient for a med size Mojo? I found a previous post that suggests a 130cm rear. Is the 5cm going to make a difference? Any insights much appreciated. Thanks.
    aB
    Reputation: miles wadsworth's Avatar
    Nov 2006
    I am running about 130cm and mine is a on the shorter side, No extra flopping around at the bars.
    milesW
    Reputation: darty's Avatar
    running 127cm for hope x2's and the length seems nearly perfect.
    Just put a Hope 1270 hose on a large mojo and ended up cutting it down about 5 cm. My hayes brakes had a longer hose and easily formed a kink between the top tube and where the hose connects to the rear triangle. shortening that up as much as possible seems to work much better. You should be fine with the 125cm hose.
