Page 1 of 2 12 LastLast
Results 1 to 100 of 182
    Reputation: simenf's Avatar
    Nov 2008
    Biggest rear tyre to fit the Ripley?
    I am planning to use a big combo: the Syntace MX35 wheel (28.4mm inner width) and Maxxis Ardent 2.4". On P35-rims these tires measure 58.2mm. So Hans - will they fit?
    May 2005
    Hans told me a Schwalbe Hans Dampf 2,35" will fit. The Maxxis Ardent 2,4" should be smaller than the Schwalbe, so it will fit too I think.
    At the spot where the tread is usually the widest we have about 72 mm space.
    We have test fit Pergatory 2.4 and Hans Dampf 2.35 and they fit OK. We have not tested the Ardent 2.4 on a wide rim. The height is usually where you would run out of room first though and the Hans Dampf is a tall tire, so maybe it will fit. You guys really would like a 30" wheeled bike I see ; )
    H
    Nov 2008
    Thanks, Hans.
    A wider rim normally flattens the profile of the tyre somewhat, so if there is 72mm of space and a HD fits, I'll go for it with the MX35 wheels and Ardents.
    May 2010
    Just wanted to update this....
    With my I9 Torch wheels (23.5) and Nobby Nic 2.25 tires, there is only a few mm of clearance between the outside knobs and the frame. I'll take a pic later and post it up. I had to put some helicopter tape there because scratches were showing up on the frame there.
    weirwolf 2.3 on Enve AM rim is a very tight squeeze.
    Nobby Nic 2.35 on 23mm wide rim. Fits but not much room spare
    Reputation: freebiker's Avatar
    Mar 2006
    wonder how it compares to sultan or 429c?
    Reputation: Conner_Kuhns's Avatar
    I'm currently running a 2.3" specialized purgatory on the rear on Easton Haven carbon wheels, and it doesn't fit, I just can't get full travel because of the tire bottoming out on the seat tube.. found that out after I noticed some black stuff (rubber from tire) on the seat tube!
    Conner "Big Bear" Kuhns
    San Jose, CA
    I run Hans Dampf 2.35 trailstar on Syntace W30 wheels. They rub the seat tube when bottoming out. I have added some tape and it looks like it's ok.
    Nov 2008
    Thanks, Buyoen! I wonder whether the extra width of the W35 will flatten the profile enough to avoid rubbing.
    Reputation: brankulo's Avatar
    Aug 2005
    it will not. the circumference of the tire will not change.
    Nov 2008
    Quote Originally Posted by brankulo View Post
    In theory a wider rim will change the tyre profile to a a slightly less bulbous shape. How much is another matter.
    The MTB Lab
    Reputation: pastajet's Avatar
    With wide tires its the right side clevis where it will rub. You might or might not get a taller tire to hit the seat tube on full compression. I also depends on your weight, psi in the shock and whether you huck or hit big G-Outs.
    Reputation: elsinore's Avatar
    Jun 2005
    Has anyone tried the new Maxxis Ikon 2.35 on the rear of the Ripley?
    Mar 2006
    I did. It fits OK, but you get a 1-2 mm clearance from the frame
    Jun 2005
    How about a conti x-king 2.4? Has anyone tried that tire?
    Nov 2008
    Any experience with Maxxis Ardent 2.4" on the Ripley so far?
    The Ardent 2.4 rubbed against the back of the seat tube, removing the paint. It also rubs the cross piece joining the chainstays. Not sure if it really rubs or just throws more grit at that piece, but I went back to the 2.25 and don't have the seat tube rub anymore. I now run a 2.4 Ardent on the front and the 2.25 on the back and like the setup.
    The MTB Lab
    Quote Originally Posted by mtbmarc View Post
    Be sure to protect your seattube with tape. Fat tires will rub the seatstay just by the cleavis.
    Hans Dampf rubs
    Just checked after a big ride with lot's of motion in the rear and the Hans Damf rubbed the seat tube and rubbed off the I in Ibis and made a nice skid mark below that. Going to switch to a racing ralph 2.25
    Reputation: aequitas's Avatar
    Maybe we need to update the thread with: Tires that do fit the rear of the Ripley. I'm going to want something bigger than the stock ones when I go to Sedona in a month and a half and I still don't know what I'm going to use.
    Quote Originally Posted by redway View Post
    What rims are you using?
    Nov 2008
    It really pisses me off that Ibis still cannot make room for beefy rear tires. Why!?
    simenf - brainwashed by the big wheel mafia.
    Reputation: Thorin_2's Avatar
    Jan 2009
    ... and if we just ...
    Quote Originally Posted by simenf View Post
    It really pisses me off that Ibis still cannot make room for beefy...
    I really don't get you guys. Why do you need a wide tire in back? The Ripley is an XC or Trail bike - meant to go fast. A wide tire in front is all you need for max grip in corners. 2.3 or 2.4 in front with a 2.2 in rear is all you need...unless you have noob maneuvering skills. I'm sorry but this is just ridiculous. Go sell your Ripley and buy an HD or something.
    Just a warning, my friend who also owns a ripley just sent me a pic of his seattube and the first two layers of carbon shredded away by a high speed rear tire, it was a nobby nic 2.35 rear tire and the fox shock had an air pressure issue that was covered under warranty. Obviously it was an extended loss of pressure in the rear and not a quick easy bump from a bottom out, but it indeed damaged the frame. He wasn't running any helicopter tape on the seat tube like I am, that might prevent a little damage in an all out failure (not likely to happen) I'd suggest letting ALL the air out of your shocks to test clearance.
    Nov 2008
    Quote Originally Posted by Thorin_2 View Post
    The Ripley is very capable over a large variety of uses from XC-racing to light DH. To make the most of those capabilities you need to be able to run larger volume tires. 2.25" is more or less the standard size for XC-tires (and fits ok) now but 2.35" are now the trail tyre standard size with many running 2.4" (both rubs). Big volume tires lets you run lower pressure and have more grip, more ruggedness and more speed on real life terrain.
    One thing is for sure - mtb-tires are not gonna get skinnier, just bigger. No surprise. Look at rims, frame tubes, suspension travel, skis, whatever.
    And Ibis boasted about plenty of room for big tires such as Hans Dampf 2.35" in advance. Tire clearance is a longrunning issue on Ibises. It's nice to have a big front tyre, but most of your weight is over the rear and hence where you need the volume the most.
    So why not make sure you allow some extra space when you make a new bike and test it with big trail tires? For many this is actually a dealbreaker.
    And a HD is a different bike.
    "640k memory is all you ever gonna need...." Bill Gates.
    Jan 2009
    @simenf, I appreciate the politeness of your rebuttal, a skill which has become increasingly less common in this day in age.
    It would be unfortunate for the over generalization of "wider is better" to mislead riders who are new to the sport. For mechanized vehicles that generates gobs of torque, like motorcycles and corvettes, wider rear tires make a whole lot of sense.
    Mountain bikes, on the other hand, are better suited towards a front/rear tire width ratio that favors a wider front and narrower (relative to the front) rear tire width. Why? Because cornering is where traction is needed most, and all else being equal (i.e. if you were running identically sized tires front and rear), you would lose traction in the front before you lost traction in the rear.
    Thus to achieve the a balanced cornering profile you would employ a front tire that is (relative to the rear) wider and grippier, and rear tire that is (relative to the front) a bit narrower and faster rolling. Hence my recommended 2.35-2.4” front with 2.25-2.3” rear for the most balanced and sensible (less is more) setup.
    I will concede that there is one scenario where a wide rear tire comes in handy, and that is for short and punchy climbs where rear traction is at a significant premium. And I will also concede the fact that there is a trend towards ever-wider tires, even though it defies logic at some point, as weight and rolling resistance (RR) will increase proportionally to tire size (after a certain threshold, as RR is actually reduced for wide tires running low pressures over skinny ‘old school’ sized tires running higher pressures).
    To conclude, I think we we can both agree that at some threshold, traction gains are offset by weight and RR. I don’t know if there is sufficient empirical evidence to determine what that threshold is. Is 2.4/2.3 F/R wide enough? Or do we really need 2.5/2.4 F/R or god forbid wider?
    Although I cannot proffer a conclusive answer, I would propose my recommended F/R ratio mentioned earlier as providing the best of both worlds, and fits the Ripley perfectly to boot.
    Nov 2008
    Thorin_2 - I try to keep it friendly :-)
    However, you seem to confuse grip with volume. Bigger volume does NOT equal higher rolling resistance; that is a old myth that has been debunked many times:
    Wider is faster! | Schwalbe North America
    source: http://www.mtbonline.co.za/downloads...llustrated.pdf
    The rolling resistance is largely from the deformation of the tyre, and more volume/larger diameter will reduce deformation and hence also rolling resistance. Most mountain biker's pressures are well within the range where lower could be better for travelling over rough ground. That, in most cases, requires a bit more volume to play with.
    In other words, more grip at the front is safe and useful, but it does not have to come as a compromise to rear end volume. A big, light rolling rear tyre (preferably set up tubeless) is my preference as it gives that combination of compliance, grip and puncture resistance, all the more pressure tuneable due to the large volume. This is even more important to larger riders that otherwise have to run higher pressure than optimal to avoid snakebites or blowing tyres off the rim with high sideways loading.
    People should be free to choose their desired rear tyre within reasonable limits, and I believe Ibis has set those limits a bit too narrowly with the rear frame of the Ripley.
    You may have a point regarding the tyre profile and riding dynamics, but that can also be tuned with different rim widths. The weight penalty of the wider version of most tyres has been getting pretty small over the last few years.
    More: Rolling resistance - Wikipedia, the free encyclopedia
    Jan 2009
    @simenf, I am well aware of the fact that RR decreases as volume/diameter increases; however what most people fail to realize is that it is not a linear progression between these two, while weight will increase linearly as diameter increases, which is why you don't see XC racers racing fat bikes!
    I must admit that I had failed to consider the needs of clydesdales as perhaps the most obvious reason for larger volume tires in the rear. At 5'10' and weighing a svelte 155lbs, I can run 20psi on my 2.25 RoRos without any downside; so I agree with your rationale there.
    In general I agree that people should be able to choose their desired tire within reasonable limits, and personally I think 2.35 is a reasonable constraint. Interestingly, some on this thread have indicated trouble even with that size (Schawlbe NNs), which is surprising, until you read that one guy had a faulty shock and the other guy was bottoming out his shock (wrong sag? clyde doing big drops?).
    In any case I think we are not so far apart in our opinions. Really it boils down to what that reasonable constraint is for the rear tire size. Should be it be 2.4? Higher? Perhaps; but truth be told there aren't a whole lot of options in that range - some Contis, Ardents, and RoRos I think. Not exactly a cornucopia of wide tire options. That is why I'm personally ok with the 2.25-2.35 as a "reasonable" rear constraint.
    Nov 2008
    OK, that understanding was not so clear in your first post :-)
    I believe we agree.
    I got my Syntace W35 (28.5mm ID) rear wheel today and will be investigating the rear tyre options in combination with a wide rim as soon as the conditions allow. I got Ardent 2.4", HD 2.35" and Specialized Ground Control 2.3" lined up and ready to go.
    Schwalbe Ice Spiker Pro in 2.25" works fine on a Crest (21mm ID), as does Rocket Ron 2.25" (an underrated tyre in my opinion). It is very close on full compression on the ISPs, but it clears the seat tube.
    May 2010
    I just want to to add to this thread.
    Knobby Nic 2.25 = No rubbing on seat tube
    Hutchinson Cobra 2.25 = Rubbing on Seat tube
    Maxxis Ikon 2.2 = Rubbing on Seat Tube.
    I weigh 140lbs, and the shock is set to 150psi.
    Nov 2008
    Thanks, mcgong. Which rim is used?
    May 2010
    I have the I9 Torch Wheels.
    Reputation: slow ridr's Avatar
    May 2012
    I can run a Continental Trail King 2.2 on an Arch EX.
    The Trail King 2.4 rubs seat tube and drive side of triangle.
    Has anyone run 35mm wide rims on the Ripley yet?
    Jan 2009
    Ripley Rear Tire Fit Updates?
    Bumping this thread by providing a summary of findings so far. It would be great if each new post could include the below list with added/modified/removed entries where applicable, so that newcomers can browse the last post and get a complete list of tires that fit or failed to fit.
    YES: Continental Trail King 2.2 on Arch EX rim
    YES*: Maxxis Ikon 2.35 (yes but 1/2mm clearance only)
    YES: Maxxis Ardent 2.25
    YES: Schwalbe Hans Dampf 2.35 on Syntace W30 (rub seat tube when bottom out (apply tape))
    YES: Schwalbe Ice Spiker Pro 2.25 on Crest (21mm ID)
    YES: Schwalbe Rocket Ron 2.25 Crest (21mm ID) and Easton Haven Carbon rim
    YES: Schwalbe Nobby Nic 2.25 on I9 Torch (few mm clearance)
    YES: Schwalbe Nobby Nic 2.23 on 23mm wide rim. (NOTE: 2nd report says no but due to shock failure so not a proper test)
    YES: WTVB Weirwolf 2.3 on ENVE (although tight squeeze)
    NO: Hutchinson Cobra 2.25 on I9 Torch (rubs on seat tube)
    NO*: Maxxis Ikon 2.2 on I9 Torch
    NO: Maxxis Ardent 2.4 (rub seat tube)
    NO: Continental Trail King 2.4 on Arch rim (rubs on triangle)
    MAYBE: 2.3 Specialized Purgatory on Easton Haven (bottoms out on seat tube) (Note: contradicts Hans 2.4 claim)
    *Contradictory claims. One says 2.35 fits (barely) while another says 2.25 does not. Difference in rims?
    May 2010
    NO*: Maxxis Ikon 2.2 on I9 Torch (rubs on seat tube)
    Updated the Contradictory claim for the Ikon 2.2. Fits width wise, but rubs on seat tube.
    Nov 2008
    UPDATE: HD, GC and ISP. Moved some to MAYBE. Please specify rim when making updates!
    YES*: Maxxis Ikon 2.35 (yes but 1/2mm clearance only).
    YES: Maxxis Ardent 2.25.
    YES: Schwalbe Ice Spiker Pro 2.25 on Crest (21mm ID).
    YES: Schwalbe Rocket Ron 2.25 Crest (21mm ID) and Easton Haven Carbon rim.
    YES: Schwalbe Nobby Nic 2.25 on I9 Torch (few mm clearance).
    YES: Schwalbe Nobby Nic 2.25 on 23mm wide rim. (NOTE: 2nd report says no but due to shock failure so not a proper test).
    YES: WTB Weirwolf 2.3 on ENVE (although tight squeeze).
    YES: Specialized Ground Gontrol 2.3 on W35.
    MAYBE: Maxxis Ardent 2.4 (rub seat tube) Update: On W35 they rub only a little. Probably OK if you tape up and run a lower pressure.
    MAYBE: Schwalbe Hans Dampf 2.35 on Syntace W30 (rub seat tube when bottom out (apply tape)) OK. W35 (ID 28.5mm) fits, but only 1 mm space on RHS. Probably not useable. Forgot to check if it rubs the seat tube, but as it fits W30 it is probably OK there. Needs to be tested on the trail.
    Updated with 2.35 Nobby Nic on Light-Bicycle carbon trail rim: (YES):
    YES: Schwalbe Nobby Nic 2.35 on Light-Bicycle carbon trail rim.
    Thanks for the list and updates. Bummed out on tire size with this bike! backcountry riding in Montana is hard on big tires. don't know if i will keep this frame? bummed
    prefers the wide stance
    simonf - How are those W35s? I'm liking that option for either a Ripley or a 2014 Horsethief. I have Dually's with 2.4 Ardent on my Jones SS and the volume and grip is like nothing else.
    Nov 2008
    @demondan: I see what you mean as conditions around here are rough too. Just remember that those wider rims give more volume to smaller tyres.
    @xbrian: haven't tried them yet due to the white stuff outside!
    Just fitted Specialized Purgatory 2.3 Control on my Arch Ex wheels, and there is still approximately 5 mm distance between the tire and the seat tube when I release all the pressure in the shock. Frame is a medium Ripley. Off the top of my head that should allow a rim that is up to 12,5 mm wider than the Arch Ex 21 mm internal width, i.e. a 33,5 mm rim, and still leave one mm to spare at full compression.
    not the circumference of the rubber part of the tire, but the practical circumference is made up of the rubber tire and the internal width of the rim. you can easily demonstrate this by taking a strip of paper and change the distance between the ends to simulate different rim widths. the change in diameter equals the change in circumference divided by pi, i.e a rough estimate is that every 3 mm increase in rim width increases diameter by 1 mm.
    I had mine in May of last year and sold it in August. I tried multiple tyres on the back and could not get the clearance i needed. Ardent 2.25 did not fit on my large frame. Same with a nobby nic 2.25 and a bontrager x4. I found it real hard to get a tyre that was fit for purpose and did not rub so I sold it on. I do miss it a bit was a great bike super fast but grew tired of anticipating the noise of it hitting my seat tube. I am pretty hard on my bikes so this did not help but also those measuring the clearance need to remember that if there is 5mm or less clearance it will hit on a big impacts due to flex in frame and bigger forces involved as opposed to just pushing/sitting on the frame to test.
    Quote Originally Posted by m_t_b View Post
    Hello Forum!
    If a 2.25" tire is not clearing there is something wrong with the frame.
    Just contact us and we'll help sort it out.
    Hans
    Jan 2009
    I am running a 2.25 Nobby Nic in the back and it fits with room to spare. Even the 2.35 appears to fit (albeit with little room to spare), so long as you don't bottom out your shock. My current NN rear and 2.35 HD in front are the perfect combination of grip and low RR.
    Quote Originally Posted by hanssc View Post
    Hello Forum!
    Hans
    I did email and then call, ibis techs tried to help by suggesting other tyres nothing else was forthcoming at the time. I would of loved to of sorted it out as I loved the bike but I went to see fox here in the uk and they could not work out why it was happening and I left it with a shop for a while who tried different set ups. Either I had a faulty frame or the tolerance between rear tyre and seat tube was too tight to begin with. Like I say I would of liked to of sorted it but at the time felt I had exhausted my options.
    Hans Dampf 2.35 on Nox Composites XCR
    Frame size Medium. I'm running a Schwalbe Hans Dampf 2.35 on a Nox Composites XCR rim at 30 psi with no issues. Ride tested with full shock compression resulting in no rubbing on the seat tube. Photos are of the seat tube area, shock air released for full travel, and the right forward chain stay area.
    Attached Thumbnails Attached Thumbnails Biggest rear tyre to fit the Ripley?-chainstay.jpg
    Nov 2008
    Hans,
    Which tyres are you running?
    Not HD?
    Hans,
    Not HD?
    I am running Racing Ralph 2.25 in back, Knobby Nick 2.25 in front both tubeless with the tougher snakeskin sidewalls. That is our stock spec and I find it a very predictable and fast rolling set up.
    H
    Reputation: rockman's Avatar
    H
    For Santa Cruz riding, perhaps? If one wanted to get a bit more aggressive with the Ripley and put a Minion 2.5 up front with a 140mm fork, a 2.2 Racing Ralph is a bit underwhelming in the rear.
    That said, so stoked to be building up a Ripley and the RR and NN is a pretty dang nice spec and one place most manufacturer's cut corners. Can you say Nevegal? Bleh.
    May 2012
    Has anyone tried a Maxxis DHR II in 2.3 or High Roller II in 2.3 on rear of Ripley?
    Quote Originally Posted by slow ridr View Post
    Yep running LB 35 hookless with Ardent 2.25 front & Ardent Race 2.2 rear. Clearance in rear is fine but it does have more volume (as expected).
    Biggest difference is off camber grip. Prob due to combo of less rim flex, slightly lower psi & the side knobs being pushed out to engage.
    MSH
    MSH is online now
    Reputation: MSH's Avatar
    Jun 2005
    No issues so far on my Ripley running Ikon 2.35 on Light Bicycle 23mm inner width rims
    I'm running 35 mm carbon rims with no issues.
    Quote Originally Posted by alias33 View Post
    How's that working for ya with no tires?
    Reputation: mossterioso's Avatar
    Has anyone tried the new WTB tire, the Trail Boss?
    Anyone tried a WTB wolverine 2.2 or Weirwolf 2.3 on a Stans Arch rim?
    Good job! Light Bicycle Hookless Rims w/ Specialized Purgatory 2.3"
    I did a test fit of a 2.3" Specialized Purgatory S-Works tire on a Light Bicycle "Bead hook-less" rim with 27mm outer / 22mm inner widths.
    The fully-seated tire pumped up to 60+ psi with a tube clears the rear triangle with a pinky finger gap at the chainstays. I will take photos once I get it setup tubeless.
    Reputation: IntenseJim's Avatar
    ...I will concede that there is one scenario where a wide rear tire comes in handy, and that is for short and punchy climbs where rear traction is at a significant premium.
    Everybody starts out as a noob and some folks like yours truly are relatively new to the sport. Additionally, the 'scenario' described above describes a lot of the trails that I regularly ascend. And being 6'2" and190 lbs buck nekked....
    Hence my desire for a larger or certainly grippier rear tire than the stock Ripley rear tire, Racing Ralph 2.25" Snake Skin tubeless on my Ibis 928 wheels.
    I had a Schwalbe Nobby Nic, 29x2.25 TL Ready Evolution Folding on my Giant Trance X29er 0 which I perceive to have provided better traction.
    I think I'm gonna take the Nobby Nic that came spec on the bike, put that in the rear, and put a WTB Vigilante on the front. The Racing Ralph is a little too light weight for where I ride.
    Reputation: MSU Alum's Avatar
    Quote Originally Posted by rockman View Post
    No rubbing!
    The MTB Lab
    Quote Originally Posted by mossterioso View Post
    They fit fine (refer to Grams Light Bikes - Mountain Bike and Gear Reviews, and News: First Look: New WTB Breakout, Trail Boss and Nine Line Tires ):
    "For a 2.25" tire, they were overspec for width, with a 2.3" casing and a 2.28" knob span."
    May 2012
    Updated to add YES: Maxxis High Roller II on Arch Ex
    YES: 2.35 Nobby Nic on Light-Bicycle carbon trail rim
    YES: Maxxis High Roller II 2.3 on Arch EX
    So I guess Ibis are expecting to run 2.25s on their new 40mm rims.
  67. #67
    2.25 ardent race on 35 rims is a sweet setup.
  68. #68
    Reputation: manchvegas's Avatar
    Mar 2011
    Updating list for 2.4 Continental X-kings buzzes seat-tube at full compression on Archex so saying NO. I have since switched to LB carbon rims 30mm external, 23mm internal width and seems to be better, but still buzzes but seems ok with helicopter tape so I'm putting as a maybe. Have helicopter tape and it hasn't rubbed through it. Got about 400 miles on them. Thinking of trying 2.25 ardents next.. traction on the nobby RR sucks for our wet new England weather..
    NO: Continental X-king 2.4 on archex (rubs seat tube)
    MAYBE: Continental xking 2.4 on wider carbon rim 23mm internal 30mm external LB carbon rim. Couple layers of helicopter tape hasn't worn through yet. But still rubs.
    Full time rider part time racer...
    See my adventures here..
    https://www.instagram.com/projectnortheast/
  69. #69
    Mar 2011
    I should say there was only one reason I steered clear of the HDR and it was tire clearance.. Have since bought a carbine 27.5 and run 2.4 Mountain king 2's front and rear and it's tight in the rear with tubes, tubeless it has a couple extra MM clearance. I'm sure running small volume tires in the rear of bikes is great for most riding in Cali etc.. but out here on the east coast with a lot of rocks, roots, and mud a higher volume tire is a lot better, pretty much a lot of our trails have those quick punchy climbs that you would want the extra traction..
  70. #70
    mdc
    mdc is offline
    Reputation: mdc's Avatar
    I'm running a Bontrager XR4 Team Issue 2.3 Front and XR3 2.3 Rear tire, on a LB 35 mm rim on my Ripley with no problems....
  71. #71
    Reputation: DrewBird's Avatar
    Quote Originally Posted by manchvegas View Post
    I'd put Ardent 2.4s in the "no" category on normal rims. I've run them on Roval Carbon rims (23mm internal) and they definitely hit the seat tube at full compression.
  72. #72
    Apr 2013
    I just rode D-ville with a High Roller II mounted on a Derby rim with no issues...
  73. #73
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    Specialized Captain 2.2 on NOX AM29 fits fine but has signs of rubbing the seat tube on bottom out. Looks like a light rub. Pretty sure that happened with the OEM Stans rims too.
  74. #74
    Jun 2010
    Any photos?
    Quote Originally Posted by aequitas View Post
  75. #75
    Quote Originally Posted by atekt View Post
    Any photos? (... of the 2.3" Specialized Purgatory S-Works tire on a Light Bicycle "Bead hook-less" rim with 27mm outer / 22mm inner widths...)
    Good timing - I just started tearing apart the rear triangle to do some maintenance. When I get the shock back on, I'll air down and take some photos.
    I will say that without the shock and clevis in the bike, the tire will hit the seat tube. I also dropped a bunch of weight off the bike.
  76. #76
    I realized I miswrote earlier. The 2.3" Purgatory fits on the front no problems (no surprise).
    I have a S-Works The Captain 29x2.2" on the rear on the Light Bicycle hookless 27mm outer/22mm inner rim. Here are photos of the clearance with all air out of shock and fully compressed. No rubbing, but I did have a little bit of rubber on the inside of the swingarm/rear triangle on the right side where it is closer. Must have been from before I had the Gnarcore in the bike.
    S-Works The Captain 29x2.2" by jasonleeferrier, on Flickr
  77. #77
    This has been mentioned on the DB Inline thread, but the Ripley-specific DBInline has a 2mm shorter stroke than the OEM Fox. This gives you ~2mm more ST clearance at bottom out. For example, Ardent 2.4s hit the ST pretty hard with an airless Fox on the bike, but barely graze the ST with the DBInline.
  78. #78
    Nov 2008
    The Ripley rear suspension has a distinct end progression. Even after trying to bottom it out (no big drops, though) with recommended 11mm sag, I haven't contacted the seat tube yet. And running an Ardent 2.4" I would have noticed...
    The limiter on the DB Inline would probably not be noticeable for me.
  79. #79
    Jun 2010
    I have been running a specialized ground control 2.3 with no issues. Clearance is great all around.
  80. #80
    What rims do you have? This is also important.
  81. #81
    Jul 2014
    Got a couple updates here
    Both a 2.25 Ardent and 2.3 DHR2 will fit and clean no problem on 941's with Inline
  82. #82
    Jun 2010
    They are on the narrow side... roval control sl. I will mount up some wider wheels to see how the fitment changes and report back.
  83. #83
    ehn
    ehn is offline
    Jun 2014
    Does anyone have experience with Schwalbe Rock Razor 2,35 as a rear tire on the Ripley?
    It seems like the side nobs is a little bit bigger than what it is on the Hans Dampf. And the Hans Dampf fits with only a few mm clearance on both sides on my Syntace W30 rims. I have run the HD the whole season with a strip of heli tape on the seat tube with no problems.
  84. #84
    Quote Originally Posted by ehn View Post
    Just tried a Specialized Slaughter 2.3 Control on an Enve AM rim. The wide knobs clear the seatstays with ample room except for the upper right portion of the seatstay where there is a sharp bend. Clearance here is down to 1 cm, but I suspect this is true for most 2.3 tires on the Ripley. In use, there is no rub however.
  85. #85
    Jul 2013
    Just put a Spesh Purgatory 2.3 Control on Enve AM rim with DBInline. It clears with the shock fully compressed, no rubbing, by only by microns. Plenty of clearance on the sides.
  86. #86
    Aug 2005
    First ride on my Ripley today. 2.35 Nobby Nic (not 2015 version) on I9 Torch wheels hits the seat tube, but not the swing arm. Bought an Ardent 2.25 to replace.
  87. #87
    All bike, all the time
    Reputation: BikeIntelligencer's Avatar
    Sorry what's the width on the Torch rims?
    Quote Originally Posted by rb_daniel View Post
  88. #88
    Aug 2005
    28mm outer, 23.4mm inner.
  89. #89
    Nov 2008
    I lost track of this thread now; has anyone tried the On-One Chunkey Monkey 2.4" out back on a wide rim?
    Simenf
    Brainwashed by the big wheel mafia
  90. #90
    Nov 2008
    Nobody?
  91. #91
    Guess it's on you to report back
  92. #92
    Reputation: Colin+M's Avatar
    Nobody?
    I had a Maxxis DHR2 2.3 on a 30mm inner width rim and it fit, but barely. I don't know how the Chunky compares in regards to size, but I doubt it would fit with rubbing not to mention mud clearance.
  93. #93
    Nov 2008
    Quote Originally Posted by Colin+M View Post
    Barely, as in Ardent 2.4", is fine with me. I'll order both the Trail Extreme dual compound as a front, Enduro single compond and Smorgasbord (2.25") for the rear.
    Simenf
  94. #94
    Jul 2014
    2015 nobby nic 2.25 clears on an Xl frame.
    Fox shock, stans flow ex rims 25.5/29mm, tubeless
  95. #95
    Nov 2008
    How about Nobby Nic 2.35"?
    Simenf
  96. #96
    Jul 2014
    I can't say for sure. That pic is at full compression.
  97. #97
    WTB Wolverine 2.2 on Stan Arch Rim hits the seat tube on full compression.
    Evil The Following MB 2017
    Canondale Scalpel Team 2015
    Kona Raijin 2014 SS
  98. #98
    WTB Wolverine 2.2 full compression picture
    Biggest rear tyre to fit the Ripley?-10354139_10153246582924874_8180615491319235689_n.jpg
    Kona Raijin 2014 SS
  99. #99
    Reputation: jrock831's Avatar
    Jul 2013
    Do you guys think the wtb new trailblazer 27.5+ would fit in the rear???
  100. #100
    The MTB Lab
    Quote Originally Posted by jrock831 View Post
    I am still waiting on a set to test, but I very much doubt it. Just not much width back there at all.
  1. biggest rear tire to fit a '10 Enduro
    By newking in forum Specialized
    Last Post: 11-12-2014, 02:40 PM
  2. Replies: 0
    Last Post: 08-09-2012, 06:17 AM
  3. Biggest tyre on the back of a Durance?
    By markyboy1980 in forum Maverick
    Last Post: 04-06-2012, 12:15 PM
  4. Any reason not to run the biggest front tyre possible?
    By beanbag in forum Wheels and Tires
    Last Post: 03-19-2012, 08:41 PM
Members who have read this thread: 97
