Results 1 to 47 of 47
    Reputation: Lobanovskyy's Avatar
    Jan 2013
    Belief about sizing
    Hi everybody!
    Is known for all of us that Ibis has a peculiar sizing system, slightly shorter than the rest of mtb brands.
    I'm sure I'm not the only person who has had lots of doubts about which frame size should I choose.
    There is a common belief about sizing that says the next: "when you are between two sizes, you should choose the shorter one".
    Few days ago, I heard a shop assistant saying that if he wanted a road bike and he were between two sizes, he would choose the shorter option, above all for sprints, energetic requeriments and besides... On the other hand, if he wanted to buy an enduro/all mountain bike and he also were between to sizes, without a doubt, he would choose the larger size, with the shortest possible stem.
    What do you think about it?
    Reputation: sdemars's Avatar
    Mar 2011
    Good job!
    Agreed. Shorter stem for better handling - especially on the downhill. It's not so big a deal on the road, but when you're pointed down steeper stuff and taking drops it's easier to have your center of gravity centered and/or further back on the bike with a shorter stem. While you can get your weight back and down your arms are only so long and they limit this (especially if you are in a good bent arm position). Centered (as opposed to forward) mass makes it easier to get back and wheelie/manual as well. On the road the longer stem can be a bit of an advantage especially when climbing. Thus, I'd go shorter stem, larger frame. I'm 5'9" building up a Large Mojo HD with a 55mm stem. My Road/CX bike uses a 100mm stem.
    Overland : Hayduke : Hightower LT : Delirium : Piolet
    Jan 2013
    So, according to this, I should choose XL Mojo HD frame with 50 mm stem...
    I have had two Scott bikes, Scale and Genius, and both of them were Large with 90 mm stem and I rode comfortable, but now, talking about Mojo HD, I'm not sure about the size.
    I'm really lost...
    Mar 2011
    FWIW - I have a Scott Spark 900 in Medium. For my proportions I need a 100mm stem on that. I would prefer shorter but would need a new frame.
    Not making that mistake on the HD. I demoed a Large HD with a 70MM stem. Frame size was great and I knew I could do a shorter stem, which I wanted (I'll be getting 55mm).
    That's me though. What you want and how you ride are up to you. If you prefer a longer stem and a smaller frame go for it. This is what works for me and how I plan to ride the bike. ...and it's not like my Scott rides like total crap. I can still rip down a descent, but I do notice that my center of gravity is farther forward than I want it - especially on the steeper stuff).
    Jan 2013
    sdemars, look at the next pic. It is a comparison between two different L Mojo HD and between a Mojo HD and a SC Nomad, in order to check how do they fit.
    The white Mojo HD seems too short, although is the same size than the black one. And the Nomad seems also shortest than the black Mojo HD.
    By the way, I'm 6 feet. Will a XL Mojo HD be too much big for me? I don't know and I can't demo any of them.
    [put something cool here]
    Oct 2011
    Oh, you are still at it? The longer you wait, the less HD time you get ;-)
    Go XL.
    We have some things in common. Me: 1,84m, 90cm inseam (about 6'0", 35.43 inseam). I ride an HD L frame with 60mm and 780 bar, the bike feels rather short than long. I came from a 2009 Scott Genius L, where I started with a 100mm stem. I changed that to 60, because all the magazines say that shorter is modern. Didn't work.
    And I demoed an XL some months before I bought the L frame (no idea what stem), and it felt great too. I still think back and would love to demo one XL again, but there's no one around.
    Go XL.
    d-bug recommends L for that agility reason - have you seen his videos and stuff? You (and me) are not his league, sorry. From what you write in all your threads, you won't feel that extra flickability. Go XL.
    And more words from me on that exact topic, copied from an older thread:
    Quote Originally Posted by Kerberos View Post
    .... I love my bike for sure.
    That said, I demoed an XL some months earlier and was quite happy with it, too. There were some issues with wrong tires and too firm shock setup, which added to the overall feel, but it still felt great.
    I finally chose the Large, because I wanted to have that extra agility - although that's more I read about than I feel about. My skills are ok, but I am not that super technical rider reaching the limits of the HD.
    I still think of the XL from time to time. The longer wheel base gives you even more confidence on descents. And on the XL you will want to use a short stem as 40 or 50, especially with a wider bar like that 750. And that shorter stem again helps you in cornering a lot. Put your saddle as far to the front as you can, use a straight post without setback and you're fine. I'm sure you will love your XL!
    Go XL.
    Jan 2013
    I totally agree with you.
    I have never demoed a XL Mojo HD so I don't know how does it fit. Because of that, I'm horrified when I imagine buying a XL Mojo HD and regreting later...
    Besides, they are expensive bikes and I can't buy it basing on oppinions (of course with the best intention), I need test them and the problem is there aren't XL demo bikes in my country, and this is the reason why I have a lot of doubts...
    I apologize for being boring with this matter...
    Mar 2011
    Little lesson - long post
    I assume this is you in all of these images. If not it's a moot point
    Even so I can't do a lot other than agree with you that the white Mojo does "look" smaller. However, it's hard to tell many things from these images -stem length, saddle position, Bar width, and the exact angles of your body. A more true test of fit requires that all things are equal except for the one you're trying to determine (frame size). If you're asking for a recommendation I'd be reluctant but also want to know how tall you are and what your inseam is (measured for a bike fit, not jeans).
    A little bike fit basics: There are three points in space you have to work with: 1) the bottom bracket location, 2) the location of the saddle, and 3) the location of your hands.
    1) BB is fixed so you can't change that.
    2) Saddle. 90% of a bike fit is determining the appropriate distance (vertical and horizontal) the saddle should be in relation to the BB. (Note: this is slightly impacted by crank length) How far up and back from the BB you are depends on your personal geometry (leg length) and the geometry of the bike (a really slack ST angle and short legs may force your saddle forward, whereas long legs and an upright STA may put you on a setback post).
    3) Hands. Hand position dependent on how you ride and personal preference. Wider bars will increase the angle you lean fwd as will a longer stem. They also move your center of gravity (COG) forward some.
    You cannot control leg length. You cannot control frame design (i.e. ST angle). Which doesn't matter much as these don't really help you determine frame size (though they may help determine frame design). It's pretty unlikely you'd get a frame so large that you can't stand over it, or you'd have to slam the seatpost.
    You have complete control over how you want your cockpit set-up. You may want to be a bit more upright. You may want the handling of a shorter stem. You may want wide bars or narrower ones. The best advice I can give you is to KNOW THIS BEFORE YOU DECIDE on frame size. This in large part determines frame size.
    EXAMPLE: In most bikes I'd ride a medium. Because of the geometry of the Spark and the fact that I have slightly shorter legs and a longer top, I needed a straight post and the saddle slammed forward. The bike was designed with a set-back post and a centered saddle. I moved 20mm forward based on fit. This meant I had to swap the 80mm stem for a 100 if I didn't want to be cramped. On an XC bike I also use narrower bars (~650) which puts me more upright and also helped me need a longer stem. If I knew both my dimensions and how I wanted the cockpit set-up better I would have selected a large ...or a different bike.
    Time to get a mojo. I know I wanted wider bars (~710) and I knew I wanted a shorter stem (50-65mm) so I had to select a frame that would allow me to do that without being cramped. For me a large frame works.
    Know yourself, both your dimensions and how you want to feel in the cockpit. Then go look at the frame to make a decision. Ask questions. Learn as much as you can. Ask the shop for help. Ask if they can do a fit. Then make the best decision you can.
    FWIW - saddle position isn't usually considered quite as critical on a trail bike where you generally log fewer miles and move around a lot. When you're cranking at 80-90 RPM for hours and hours then even the most minute problems in saddle height or cleat position can lead to problems. However, being too far forward throwing off your COG can ruin your day if you like to point it downhill a lot. Weight forward makes it easier to endo or land the front tire - not guaranteed, but it's easier to screw up in these ways and harder to be in a good bent arm weight down position. The less you're actually sitting in one position pedaling, the less important it is to find this exact right position and the more flexibility you have selecting between two frame sizes. Smaller frames have shorter wheelbases (generally) and may seem slightly more maneuverable or more flickable. OTOH a longer frame may feel more stable at speed.
    As always YMMV
    Sep 2012
    HD's seem to run a bit small to start with... Id go xl with a shorter stem... Im on a xl with a 70mm stem right now.. Im 6'2"-- but even if i was 6' i cant imagine going to a L .. My seat post is pretttty far out... If i was around 6' id still get a xl and go with a 50mm or 60mm stem..
    Also-- where are you from-- if your in the states-- why not buy the bike from competitive cyclist? They have a 100% satisfaction guarantee... If you get the bike and it doesnt fit-- send it back and they will send you the right size.. Creates a win situation for sure..
    Reputation: Yody's Avatar
    Like I told you in the PM, those bikes look too small for you.
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    Pick one, either will be fine.
    Regardless of what you get, you will always wonder if you got the right size.
    When I got the XL, I did so mainly because everyone said I should get it. I ran it with a 60mm stem and 725mm bars, it was fine. It never handled like I wanted though.
    Now I'm on a L with 70m stem and 750mm bars, and it's a frickin dream on the DH. I do feel slightly cramped ONLY when standing and pedaling.
    On the XL I tried a 45mm stem to shorten the cockpit, and it was the worst handling bike ever for me. It was plowing turns and the front wheel felt too far ahead. I had to intentionally move my body weight forward to feel properly balanced. Going down steep stuff it was great, but that's about 1% of my riding.
    A L with 70mm stem will fit exactly the same as an XL with 50mm stem, assuming all other parts are equal and bars are at the same height from the ground.
    The XL will feel better on steep DH.
    The L will handle better due to better weight distribution and shorter wheelbase.
    When I was making the move from XL to L, I had it in my head that if I ever need an 80mm stem for proper fit, I would stick with the XL and 60mm stem. purely because I *thought* an 80mm stem on that bike would be fking lame and not cool. When I tried the 80mm stem with the 725mm bars, I had the BEST test ride ever on it. I thought, how could this be?! It is supposed to suck with such a long stem. I was torn between the cool/trendy factor of shorter stems, and the fact that the bike did frigging AWESOME with an 80mm stem. I decided riding is what is important, so went with the move to the L.
    I have since gone to a wider 750mm bar and shortened the stem to 70mm. Not a single ride goes by where I think I should have stuck with the XL.
    BTW, I also run a straight seatpost and have the seat pushed almost all the way forward, that's just where I like in in relation to the cranks.
    Bottom line, you should demo both, again and again and again. We can give you tons of opinions and experiences, but those will not directly translate to you.
    Still working on getting those pics...
    www.derbyrims.com
    Reputation: derby's Avatar
    Quote Originally Posted by Lobanovskyy View Post
    The white HD is not a Large. Maybe a Medium. The seat tube is shorter on the white one.
    BTW, I'm 6'0. The Large HD handles tight, rough and rocky great with 70mm stem and 750mm bars. Nearly all my trail bikes in 30 years have had near this TT length or slightly shorter when short stems were 100mm. The trend is longer TT now, and is more stable, but of course less nimble.
    I'm also 6'0, on a Large HD with a 70mm - bars are cut at 740mm. The only time I feel cramped, like d-bug, is when I'm standing and pedaling...otherwise the bike feels absolutely spot-on, especially on the downs when I can drop the seat and let the bike move freely underneath me.
    ride, eat, sleep, repeat
    aka dan51
    Mar 2005
    Here are the pics of me on my bike for comparison.
    I measured my height last night for the first time in years, apparently I am taller than I thought. I'm 6'2".
    Reputation: getbusyliving's Avatar
    To your original question, I firmly agree that when in doubt on that bike, go up. I did the reverse originally on a standard mojo, and was trapped with longer than desired stem. So ended up getting the bigger size, and have been much happier ever since.
    Everyone is different. There is a myth that a smaller bike handles better, but that is not necessarily the case. With a large, I cannot get the weight distribution to feel right (while riding the bike) and, as a result, it does not turn as well as a XL at the limit. With the XL, I feel comfortable sliding the front and/or rear in a turn with my feet on the pedals. And, it is a monster in the berm. I guess my point is that the best way to tell is to ride them both. What works for you is probably determined in part by how you ride (your riding style -- not the type of riding you do).
    P.S. If you think in terms of extremes, imagine riding a pixie bike. Its smaller, but I guarantee you that it won't handle very well. Obviously a giant bike won't either, but don't assume that the smaller(or larger) size will necessarily have the same advantages for you as it does for others.
    Jan 2013
    sdemars, thank you very much for your explanation. It is very useful.
    Quote Originally Posted by derby View Post
    The two Mojo HD showed on the pictures were Large, at least in the sticker of the frame I read "LG" in both of them.
    d-bug, thank you very much for your pics. I think when you are stand up on the pedals, the bike seems a bit tiny under you, but when you are sat on the saddle, it seems better. The only think I don't understand is if you are taller than me, why your Large bike looks better under you than the Large bike I demoed.
    To sum up, I agree that the key is testing both sizes. I hope to meet a guy with a XL Mojo HD in order to draw conclusions...
    Thanks to everybody for giving your opinion.
    Reputation: Trackho's Avatar
    Belief about sizing
    Usually you can find an XL SL to demo the sizing is really close, the SL has a slightly longer steering tube.
    I'm the same height, had same dilemma test rode an L -too small got the XL no regrets. Fits me way better than L. But I do have long arms
    6'2" with a 34" inseam, all torso. XL with a 70mm stem and 750mm bars. Bike still feels small to me. Tried riding it with a 50mm strem. While I could ride it, and adapted. It put me way too far forward over the front end, made cornering awkward. Made small errors much more punishing when jumping and cornering. If you didn't get your weight back just right you felt all over the frontend. Couldn't pump/push on the bars as hard either. I can only imagine being as tall as I am and on a Large. Must be awful on long climbs.
    Dan, you make that bike look freakin tiny! Way too upright and not stretched out enough for doing long climbs. I'm sure you make it work tho. I just don't know how
    aka dan51
    Mar 2005
    Quote Originally Posted by Yody View Post
    Funny thing is I often feel too hunched over and it leads to tightness in my neck muscles. But raising the bar height = poor DH handling. Longer cockpit would make the feeling worse for me. I don't see how you can ride that tank of an HD around, it's huge! I'll order up a bus steering wheel for you to put on it.
    Well were both on the same boat of not needing super short stems, overated
    I'm 6'0" on a Large with 70mm stem and 785mm wide bar with a dropper post. I've been on an XL in a parking lot test. So happy with the Large with wide bars and dropper.
    One quick comment, I think people got into the super short stems to feel confident about not going over the bars, make the front easier to lift etc. but dropper posts have dramatically changed the situation. Now some of the fastest guys I know are lowering the bars and running longer stems trying to get MORE weight on the front wheel to increase the front traction and get more pulling force out of your arms.
    When the dropper post is down it changes everything. You're probably not going to go over the bars because your stem is 2 cm longer since your whole body is about 5" or more lower. Of course they climb nice when set up that way too. The short stem trend has a lot of momentum and might have overshot the sweet spot for all around riding set up.
    Quote Originally Posted by hanssc View Post
    Bingo. For geometry discussions, we should pretty much have separate forums for those with droppers and those without.
    well dont forget everyones running wider bars too so the shorter stem evens it out. ibhave a 95mm stem on my xc hardtail with 28" haven bars and it almost feels weird. anynlonger of a stem and id need narrower bars.
    That's why I like my HD better than the Enduro I used to have. The HD's top tube length, which many say is short compared to other brands, allows me to run 785mm bars with a 70mm stem. So the top tube is a part of the equation too.
    _____
    Hans - What range would you consider a sweet spot when it comes to stem length for technical all-mountain climbing and descending? 50mm-70mm? 70mm - 90mm? What length stem does Brian Lopes and ACC run on their HDs?
    Jan 2013
    If we talk about technical trails with rocks and high steps, what do you think is better for an enduro bike, a long wheelbase or a short one?
    It's really the weight distribution of the rider on the bike and the relationship of the rider's center of gravity to the pedals and front contact patch that you feel. The same result can be gotten in a lot of different ways. It's not really possible to give one target stem length for everybody. In general they will probably be longer for taller people, shorter for smaller ones though.
    It's hard to say without details like how steep, how large of drops, straight or with corners, switch backs etc. Rider skill has a big effect as well. Many times a bike will get you a few seconds in one area and give them up somewhere else. A longer wheelbase is probably better in that situation generally though.
    80mm Stem - Better seated climbing, feel a little more in the bike when cornering hard, can get nice and low, less traction standing.
    70mm Stem - Better feel jumping, better traction standing, need to be more aware of front end weight in corners.
    There's no perfect setup.
    Jan 2013
    Hi Hans,
    According to your signature, I suppose you are an Ibis employee.
    I'd like to suggest an issue: I miss on Ibis's website a chart where users can check the recommended rider's height for each frame size, as the rest of brands do.
    Maby, there is a reason for not including it, but I think it could help a lot of people who don't know wich size choose (like me) and it is a common doubt.
    Congratulations for your bikes!
    Good idea, we'll do it.
    H
    Jan 2013
    H
    aka dan51
    Mar 2005
    Hi Hans,
    He's not just an employee, he's one of the guys there that can be called "the man".
    Interview: Hans Heim And Tom Morgan Of Ibis Cycles - BikeRadar
    Oct 2011
    And so you did, it's already there. Great!
    I'd like to add another wish: Please add Stack and Reach for the HD in the geometry charts (I realize they are available for the Ripley).
    I wonder if my researched numbers are correct, because currently I am trying to translate my different position feelings on two of my bikes to numbers.
    Jan 2013
    H
    Wow! You have been so quick! I'm sure this information will be useful for a lot of people.
    In my case, I'm 6'0" so, accoding to this, I'm between L and XL. I need to demo a XL in order to draw conclusions...
    MSH
    MSH is offline
    Reputation: MSH's Avatar
    Jun 2005
    Like you I'm right at 6' tall. I'm all legs with a near 35" inseam. I was dead set on the XL when Ibis released the Geom details back in March. I normally wouldn't look at any bike with a shorter TT than 24", but what I wasn't considering is that I'm going to run way wider bars than I have ever used in the past. Other than being a little high for my taste I loved the wide 740mm riser bars on the Ripley demo bike which had a 90mm stem.
    In the past I have run 625mm bars on my hardtail and 660mm on my Titus RX29 (both bikes with 24" TT and 130mm stems). I ended up getting some Ritchey flat Carbon 710mm bars to run on the Ripley. Anyways, with the wider bars I'm shortening stem length, so by my math I will be perfect on the Large with the 710mm bars and a 100mm stem even with the slightly shorter TT than my current/previous bikes.
    I would have liked to demo the XL just to be sure, but (as you probably know) XL's aren't available yet. Hopefully you will get the opportunity to try both to determine which size works best for you. Good luck!
    Quote Originally Posted by MSH View Post
    ...what I wasn't considering is that I'm going to run way wider bars than I have ever used in the past.
    This is a good point to remember for sizing in general. Since going to bars that are 60mm wider than prior (which I love BTW), I am way more bent over. I knew I was going to feel more forward, but I underestimated the extent. I wish I knew some sort of rule of thumb formula for how many mm shorter your stem (or top tube) should be when going wider by Xmm--to achieve the same torso angle.
    MSH
    MSH is offline
    Jun 2005
    Quote Originally Posted by getbusyliving View Post
    ...I wish I knew some sort of rule of thumb formula for how many mm shorter your stem (or top tube) should be when going wider by Xmm--to achieve the same torso angle.
    I read a couple of threads here on mtbr and some folks seem to feel the 2:1 (20mm wider bar = reduce stem 10mm) ratio is pretty accurate. I tried to quickly look for those threads just now but need to dig deeper. There is this Crank Collective article which pretty much states the same thing...
    Wider Is Better - The Wide Bar Debated : Mountain Biking News, Mountain Bike Trails, Mountain Bike Forums
    4 paragraphs down..." Ive heard, as a rule of thumb, that bar width to stem length is a 2:1 ratio, meaning that if the bars are 20mm wider, this creates a more forward leaning position equal to adding 10mm to your stem. I played around with that theory a little and it seemed fairly accurate as much as I could quantify such a thing."
    I read a couple of threads here on mtbr and some folks seem to feel the 2:1 (20mm wider bar = reduce stem 10mm) ratio is pretty accurate. [/B][/I]
    Thanks! Wow, 2:1 seems pretty extreme (I was thinking more like 3:1), but certainly seems like a decent place to start.
    Didn't mean to derail the original topic, but still probably a relevant sidebar...
    mountain biker
    Reputation: slyfink's Avatar
    I'm going to resurect this thread to see if I can get Hans to comment on the elements of proper fit and position on their bikes.
    You'll see I've posted a comment and started a discussion over on Vital.
    I'm 5'9", with a slightly less than 30" inseam. So short legs and (I suppose) a long-ish torso (proportionately). I'm on a medium HD. I don't think I could have gone larger because stand-over would have been compromised. I started off with a 70mm stem with a 6 rise (carried over from my previous bike). It worked fine for me, but I wanted to be more "with the times", so I bought and installed a 50mm 0 rise stem last summer.
    At that time, it seemed like steep, technical climbs were the only time I had troubles. I would bash my knees on the stem. But then I also had a few mishaps in the fall where I washed out cornering and smacked my knees on the bars again. (at this point, I was standing)
    Another thing to mention I think is that I have my saddle pushed up all the way forward. It's like that so I can have my knee cap as close to being over the spindle of the pedal with the pedals level (3 o'clock and 9 o'clock). I don't know if that old road biking approach to bike fit still applies to trail bikes and specifically to Mojo sizing (which seems to be bucking the current trend of super-long front ends and short stems).
    So Hans, if you're reading this, is there a correct position for the saddle on your bikes, and is it true that you design your bikes to work better with a longer stem? Are there rules of thumb to getting positioned properly on your bikes?
    continuous growth is the strategy of a cancer cell.
    aka dan51
    Mar 2005
    Ride with a stem that makes the bike handle good for you instead of being "with the times". I've found shorter stems (60mm or less) pretty much suck for general riding, though many will say differently. So if things were better with the 70, stick with it. If not, I have a 45 and a 60 I'll sell you . Lowering the stem, or inverting the 6degree could also help with the washing out.
    The SA is pretty slack at 71degrees, and is likely the reason you have your seat slid all the way forward. Don't concern yourself with where the seat is on the post. If it's comfortable, then that's where it should be.
    I went through all the same things you did. I started with an XL and a short stem, thinking it would be best and also because of recommendations from others. The front when always felt too far forward and had little traction when cornering due to lack of weight on it (longer TT and short stem). I was also concerned with seat position on the post.
    I have since moved to a large. My seat is in the same place, but I have a longer stem and a bike that handles better for me. Cockpit is roughly the same size, but the shorter TT brings the front wheel closer to me, and the longer stem puts more weight over it. No regrets and I am much happier.
    Quote Originally Posted by slyfink View Post
    I think that you can get proper fit on most bikes that are close to the right size through the variability of the seat for and aft position, seat height, bar height and stem length / bar width. If you have a longer top tube you need a shorter stem to get the same fit. If you have a slacker seat tube angle, you will need to move the seat further forward to get an efficient pedaling position.
    In my experience, bikes can ride equally well in most conditions with a longer or shorter TT and all the parts adjusted to put the rider in the same place.
    In the case of a bike with larger wheels, very long top tubes can result in a very long wheelbase which can become a problem for tight corners.
    Very long top tubes and shorter stems are more stable and made it less likely to go over the bars before wide use of dropper posts completely changed the game. Running a dropper post allows you to have a secure position way behind the front tire contact patch without using a high bar and or short stem position.
    Getting a little more weight on the front wheel actually gives better front end traction and sometimes power output if you started out too far behind the pedals and moved forward.
    Fitting is a book, not a paragraph or two on MTBR, but here are some very rough fitting guidelines to get in the ballpark, This is similar to what a good bike shop would probably do for a demo ride:
    seat height - 1 cm clearance between the pedal and your heel at the bottom of the pedal stroke.
    Adjust saddle for and aft such that the nose of the saddle is about 50 mm behind the BB or drop a plumb line from the bony knob on the side of the knee down and shoot for getting it within an inch or so of the pedal spindle (probably behind it by an inch or more)
    Start with a 1.5" - 2" drop from seat to bars if possible for all around use. If the front floats on climbs or you don't feel you are getting power out of your arms standing, try lowering the bars. If you have trouble lifting the front, raise the bars.
    You can adjust the stem length to get a comfortable angle between your torso and upper leg. Most very fast XC riders have a lower / longer position and most very fast AM riders have a more upright position that is better for moving the bike around under them. This really gets into personal preference and I see people ripping either way.
    There are a lot of people suffering with ill fitted bikes (of all brands) right now due to stem length somehow becoming a strict fashion rule. The tail is wagging the dog.
    Stems are easy to change and we often give people a few to try and let them return the ones they didn't use. Don't be reluctant to swap stems around and check out the changes until you are set.
    Hope this helps a little!
    H
    Reputation: jon123's Avatar
    slyfink: First off, thanks for resurrecting this. Great thread.
    I'm your height (maybe a 1/2 inch shorter) and just bought an HDR. I run a really short stem and went with a large.
    The standover difference between medium and large is almost non-existent -- 0.1 inch. But everything else (wheelbase // TT // reach) is much preferable in the large and pretty much the same as many other brands' current mediums.
    For example, I'm coming off a medium Yeti ASR 5C, and its numbers are very similar to the large HDR.
    hanssc: Regarding seat height, when you say there should be a "1 cm clearance between the pedal and your heel at the bottom of the pedal stroke," do you mean an actual gap of about 1 cm between your heel and the pedal?
    Thanks.
    Sep 2017
    Ha ha
    That is exactly where I am right now after selling a large and buying a medium. 😀
  1. Sizing on V10
    By Swell Guy in forum Santa Cruz
    Last Post: 09-07-2011, 10:27 PM
  2. Help with sizing?
    By norwish in forum Apparel and Protection
    Last Post: 07-28-2011, 03:03 PM
  3. POC sizing help
    By juan pablo in forum Downhill - Freeride
    Last Post: 04-30-2011, 10:32 AM
  4. ?? about sizing ??
    By hags707 in forum Trek
    Last Post: 04-27-2011, 11:03 AM
  5. 429 Sizing Help
    By JFR in forum Pivot Cycles
    Last Post: 04-25-2011, 11:52 AM
