Results 1 to 32 of 32
    Attention Scot Nicol + Roxy Lo!!
    I had an idea while in the shower this morning...
    What if Ibis were to offer an option of applying helicopter tape (or the 3M equivalent) to its Mojo frames? There is no argument that a carbon fibre frame is better off protected in its vulnerable areas. Most of the smart and conscientious owners are already doing this right now. But what if Ibis could offer a perfectly die-cut helicopter tape kit to the buyer? It would certainly be more fun than having to do a hack job ourselves, unless one were gifted with superhuman dexterity. Let's face it, taping up a bike isn't the easiest of jobs... .
    As I see it, there could be 2 options:
    1. offer a pre-cut set of helicopter tape "stickers" to apply to the most vulnerable areas
    2. offer an option to order the Mojo with the tape already applied, at the factory
    Keep up the brilliant work!! The mountain biking community is in your debt for your offering of the Mojo!!
    Best regards,
    Trailbait
    Reputation: DH_WP's Avatar
    I would purchase it...
    Me too. Could be someone other than Ibis for that matter.
    A bicycle will take you to fantastic places....if you let it.
    Ibis fan since '08 now rolling on the big wheeled Ripley.
    Taping up an Ibis Mojo ain't easy. It cost me 8 manhours. Excluding thorough research it took how to prepare, cut, and apply the tape right the first time. Plus two days strain that immobilized my 60 yr old lower back after all bending and contortions I did just to do the job right.
    Reputation: Davide's Avatar
    Quote Originally Posted by Trailbait
    Best regards,
    Trailbait
    It took me about 5 minutes to put tape in the only place that might need it: the downtube around the BB .... just use some if you want some extra esthetic insurance !!!
    PS any frame can use help from some (helicopter) tape my spotty after 3 years had dents close to the BB and on one seatstay that would not have been there if I taped over those areas. And by the way, tape will not protect any frame from structural damage, it is there just to keep things looking pretty.
    Count me in on wanting this too!
    I am possibly too anal about protection but I spent several hours creating shapes that fit where I wanted. I would buy several of them so that I could replace them every 6-12 months.
    They could just replace the "dots" that come with the bike and put in a sheet with all of the protection. Now, some of us may still choose to add more items, but it would be a good start for those really hard curves.
    Also, There was another poster that has already done the work. If ibis wanted to save some work, they could just get / pay for the ones already designed.
    Great idea!
    Thoughts Hans!
    Jan 2005
    I would purchase the die cut tape kit also, and so would my (4) Mojo riding buddies!
    make it happen IbIs or someone!
    Oct 2007
    Hi All,
    I was thinking the easiest way is for someone with a little CAD knowledge to make up a template and save it to a PDF. You should be able to do it so it has the correct scale to print off on to A4 (some may need reference lines for going over two pages), then simply cut it out and use as a template over your strip or sheet of 3M tape!!
    Even simpler is if someone is about to stick theirs on they can scan and bingo we all have the templates.
    All we need now is to find a lucky Mojo owner knows what to do!!
    ____________________
    Ibis Tranny 2009
    Ibis Mojo 2008
    Litespeed Pisgar 2004
    Pinnarello Dogma FP2006
    Reputation: IbisGirl's Avatar
    Great brainstorm! Make-your-own template could work for some people.. Then you could customize.
    Roxy
    Rides a Bike
    Reputation: fishboy2807's Avatar
    Protective Decal Sets
    I'm sending out protective decal sets to those who PM'd me just before the end of Feb. I'm back from NZ now and whilst work is nuts, I will get these puppies done and on their way before the week is out.
    PM me your address and email details and i'll give you the total and PayPal info for payment.
    I'll send Scot at Ibis a set to play with too.
    Fish
    Australia
    The MTB Lab
    Reputation: pastajet's Avatar
    Oh my gosh it takes all of 15 - 20 minutes to do the whole bike, its fun, kid of like a little kid with scissors cutting out scraps of paper, the only tricky part is the bottom section of the rear triangle in front of the tire, otherwise its pretty easy cutting and pasting, it ain't rocket science , get the bike up high in a stand with the rear tire off and your good to go, even easier if you take the frame apart and then just put it on the kitchen table
    Hey guys, how about putting the outlines of a set of bike tape in a gif or other picture file, for people to print out and use as cut-outs? Might be a quick fix for those who don't feel confident to do a good job...
    Cheers
    Jever
    Jan 2005
    Does anyone know of a protective tape product that is transparent and has a matte finish (rather than glossy), which could be applied to the rubberized paint finish? The glossy tape does not look good along side the matte finish carbon frames.
    Slovakia (Europe)
    Reputation: PeterG's Avatar
    Mat tape
    Quote Originally Posted by buggymancan
    Does anyone know of a protective tape product that is transparent and has a matte finish (rather than glossy), which could be applied to the rubberized paint finish?...
    There is one made by BBB, type BBP-60, but only 500 x 50mm size, not available in the roll, http://www.bbbparts.com/.
    The tape is ca. 0.6mm thick, but very flexible (even better if hair dryer is used) and super adhesive. The surface is not smooth, but wrinkly, see below packaging, surface detail and application on Mojo bottom tube. DIY "rock guard" is mounted over the tape.
    Slovakia (Europe)
    Once again, higher resolution.
    Rides a Bike
    Quote Originally Posted by PeterG
    Wow, that's a tough looking rockguard protector! I guess you've 'adapted' a mudguard or something? Looks good though. The textured film looks good too.
    I'll be posting up more detailed pics of my protective decal kit and protective rubber strips tonight so people can see what they've ordered (and where it's supposed to go :0). The rubber strips are to protect the frame from chain slap and reduce noise.
    Cheers - Fish
    Frameskin™ Bike Protection Film
    Protect your plaything!
    www.frameskin.com
    Supporting Kowalski Brothers Trailworks
    Slovakia (Europe)
    Quote Originally Posted by fishboy2807
    Yes, that's right. Front rockguard protector is adapted from rear Zefal Classic Mudguard by jigsaw and hot air gun. Adapted front Zefal Mudguard will be used for seat tube/rear triangle mudguard. Zefal Classic mudguards are the best option for adapting.
    Wow, thanks for showing your Mojo SL in high resolution, the engineering work is remarkable. Soo pretty
    07 Giant Anthem 2 (Int'l Edition) | omartan.co.cc
    Im a MOJO Fanboy
    Reputation: Carbon Ken's Avatar
    Mar 2005
    I'm sorry but I just don't understand what the fuss is over custom made die cut plastic protection.
    You have to realize a few things :
    - The tape is nearly invisible when applied. You really have to look for it.
    - The tape will most likely be covered in dust or mud making it even harder to see.
    But most importantly... the tape is simply a means of protection! It isn't meant to accentuate or compliment the frame. It'll accumulate scratches and dings to the point where it'll be replaced... much like a bra on a automobile.
    As for myself, I bought a $30 roll of plastic film from findtape.com and spent an hour slapping it onto my bike. I even had enough left over to cover my crucial areas 3 times over.
    Just my humble opinion of course!
    MPI
    MPI is offline
    Reputation: MPI's Avatar
    Hi PeterG!
    Thanks for the great input about that plastic downtube protector. Zefal is hard to find atleast here in Finland but SKS 26" Hightrek is same I think. As you said very easy to do with hotair gun.
    MPI
    Slovakia (Europe)
    Quote Originally Posted by MPI
    Hi PeterG!
    MPI
    Have a look also here for rear fender idea
    http://forums.mtbr.com/showthread.ph...44347#poststop
    Dec 2005
    Quote Originally Posted by Carbon Ken
    i think just ease of use. pre-cut should be a little less work.
    MPI
    MPI is offline
    Hi again!
    I have already looked it. Nice work as usual! I wonder what´s your rear tire size. I sometimes use 2.4 Fat Albert´s and I might have a clearance problem with fender. But all in all very nice job.
    Greets
    MPI
    Slovakia (Europe)
    Hi again!
    Greets
    MPI
    I use Schwalbe Nobby Nic 2.4" front and 2.25" rear. No problem with the clearance, fender can be removed easily, if necessary. According to my experience with Stumpy, if there is a sticky mud, it doesn't matter, if there is a fender on bike or not, the wheels can't turn anyhow.
    Peter, maybe a noob question, but can you use a regular hair drier instead of a hotair gun?
    Rides a Bike
    Yep, a hair dryer works just fine.
    Fishboy
    www.frameskin.com
    Cool, thanks!
    Rides a Bike
    Hi all
    I have a bunch of protective decal kits in stock ready for dispatch
    Included with the main decal kit are instructions on what shapes go where and how to best install them. There's also dots and such with no fixed location so you can pop those anywhere you think you need them. I have uploaded pics of the kit here Die cut protective tape for a Mojo? NOTE: the decals are clear, even though a couple of pics show white prototypes.
    Optional Extras
    Sheets of Protective Dots of various size/shape (210x100mm sheet)
    Protective Decals for 07 XTR crank arms
    Protective Decals for 08 XT crank arms
    Protective Decals for Fox fork legs
    Protective Decal for downtube (spare)
    High Density Rubber strips with adhesive backing (enough for top and bottom of RHS chainstay and underside of RHS Seatstays
    PM me for more info.
    Fish
    www.frameskin.com
    Slovakia (Europe)
    Quote Originally Posted by elmaco
    If you mean fender adapting - no, the air from regular hair drier is not hot enough to soften plastic that is fender made of.
    Yes, I meant the fender. Aha, that's too bad...
    You don't happen to make the same kind of kit that Fishboy is producing, only for the fenders?...
    Slovakia (Europe)
    Fishboy is doing his own business, he has technology for decals. Fenders are handmade adapted, so labour intensive, thus quite expensive + bulky for shipment too. And finally, I'm earning money in another job...
    Too bad, I'll have to do that by myself then
    Btw, Fishboy, I got your kit, it's brilliant! Just waiting for my Clear regular Mojo frame now... COME ON ALREADY!!!
