Results 1 to 6 of 6
    Feb 2005
    Anyone running X-Fusion O2 @ 650b?
    So far, all of the 650b "conversions" I've seen on Mojos are using Fox rear shocks. Does anyone have any experience using the X-Fusion O2?
    screamer
    Reputation: budgie's Avatar
    Yep. Replaced my pushed RP23 with a stock O2 RCX, running an HD140 w/650b. Still getting it dialled in, but so far so good. What info are you looking for?
    On heavy rotation: White Lung: Deep Fantasy
    Feb 2005
    Quote Originally Posted by budgie View Post
    Did you have to modify/shim the O2 to work with 650B? I'm looking at possibly trying the "tweener" wheels on my Mojo SL and run an O2 in back.
    screamer
    No, it's a 7.875x2.0 shock which doesn't require shimming on the HD140. Not sure if you'll need to on the SL, but it's easy to check. Just mount the shock, install the tire you want to run, and check clearance @ full travel with shock deflated. Add washers/shims as necessary until you don't get any seat tube contact. I think for the SL you won't need that much shimming --if any-- to prevent contact.
    Good luck!
    Feb 2005
    Cool. Thanks for the help!
    Oct 2007
    Good info! I'm also interested in this shock. There a 4 settings with different compression tunes, correct? Could you describe how it performs?
  1. Is the X-Fusion Slant a 650b fork?
    By OldManBike in forum 27.5
    Last Post: 10-04-2013, 10:52 AM
  2. Replies: 1
    Last Post: 12-10-2012, 05:43 PM
  3. X Fusion Velvet 650B - less travel?
    By GFWD in forum 27.5
    Last Post: 06-13-2012, 08:18 PM
  4. X Fusion Slide 29 650B conversion
    By cgcharlie in forum 27.5
    Last Post: 05-30-2012, 04:09 PM
  5. X-Fusion Enix RL 650b?
    By NH Mtbiker in forum 27.5
    Last Post: 01-28-2012, 09:07 PM
