Anyone Riding XX1 Yet?
Printable View
  • 12-02-2012
    Salespunk
    Now that is available would love to hear some feedback on it. Thinking about making the switch, but am nervous since I have been an XTR guy for the last 20 years.
  • 12-03-2012
    ducrider
    XX1 has been one of the most significant ride-impacting upgrades I've done to date on any of my bikes, ever. I have XX1 on a Carbine 275 and on a 2011 S-Works Epic 29er. Was riding XTR prior to XX1 and XX prior to that.
    My favorite perks:
    1) Silence - Yes, XTR Shadow Plus and XO type 2 rear derailleurs were a huge improvement over traditional chainstay-slapping versions. But even with those, you got chain strikes on the front derailleur cage causing noise. Also, the chain tension from the rear mech is much greater than XTR or XX and helps immensely. XX1 is dead silent.
    2) No left shifter and front derailleur - this is obvious but until you try it, you won't understand just how great this is. Riding in situations with quick transitions from climbs to descents or slow turns to sprints, or in rolling terrain, you are in the right gear all the time without having to think about it at all. No mixing chain ring and rear cog combos is necessary, no sticking with the wrong chainring just to avoid front shifts, no chain drops. More focus is available for shredding the trail. No large compromises either as with the missing ranges on a 1 x 10. Heck, its even easier to clean since dirt and mud do not pack into the front derailleur gaps, between chainrings or between bottom bracket and inner chainring area.
    3) Less weight!
    4) Ground clearance - with the standard 32 tooth up front, I am able to clear more logs and obstacles without grinding the ring.
    Least favorite thing:
    1) Lost some top end - in order to maintain the same low end gear ratios as my 2 x 10 setups I've had to give up the highest gears. Not by much, but enough to necessitate more RPMs on fast stretches and sprints.
    Hope that helps!
    EDIT (more info below as requested)
    Personal preference thing:
    1) Trigger Shifter ergos - I moved from XX to XTR largely because I preferred Shimano's smooth, longer throw lever ergos and push/pull trigger shifting option to the XX's short, snappy thumb-only shifting. Moving to XX1, I am back to the thumb-only shifts, but am willing to compromise here due to the huge benefits of the system overall. Actually, the shifts feel better and much lighter than XX despite the tighter rear mech spring. You can also shift up 5 cogs in one long lever push. Shifting to smaller cogs still require a single click per gear but is not much of an issue since most of this kind of shifting is done under light loads on the drivetrain, and can be done in rapid fire.
    2) Gripshift ergos - Thought I wouldn't like gripshift since I didn't back in the 90's. I do now. Controlling the entire gear range of the bike in one twist of the wrist is very cool and after a couple of minutes, becomes completely intuitive. The action is also much lighter than I remember old gripshift to be. What I didn't like are the really long and hard grips provided. Because of the gripshift mech and the still longish right grip provided, the right brake gets pushed very far inboard effectively narrowing your bars when you compensate by holding onto the grips further inside. There's a matching left grip, also long. I took a box cutter and a Dremel to the right grip of a pair of Ourys and now have a much better feeling setup.
    3) Confidence - yes, knowing very little can go wrong with the drivetrain is great. The rear mech's horizontal-movement design eliminates ghost shifts on the rear and the single ring front eliminates chain drops, which by the way never happens even on the harshest terrain. I initially wanted XX1 after reading about it a couple of days after dropping my chain and miss-shifting the two-ring set up on my S-Works Epic yet again on a short-course race. After trying out XX1 on the race bike, I immediately saw potential benefits for trail riding, put it on the Carbine as well, and have been a happy camper ever since. My old drivetrains now feel obsolete.
    Weights:
    Someone asked about parts weights. Yes, I did incidentally weigh almost everything as I unboxed the stuff:
    Crank (BB30 166 175mm w/ 32-tooth) - 548g
    Crank (GXP 166 175mm w/ 32-tooth) - 566g
    Rear Derailleur - 240g
    Cassette - 266g
    Trigger Shifter - 110g
    Sram BB-92 GXP Bottom Bracket with Wave Washer - 90g
    Sram PF30 Bottom Bracket - 82g
  • 12-03-2012
    Iwan
    From what drivetrain did you migrate to XX1?
  • 12-03-2012
    mtb-ripper
    Read his post much?
  • 12-03-2012
    redmr2_man
    Originally Posted by ducrider View Post
    3) Less weight!
    great review! I recently saw two XX1 builds that were very similar to my XX race bike, and I was surprised to see that the groupsets are very close together! You gain some weight on the cassette, and the cranksets are about the same weight too. Did you happen to weigh the full group, or each part individually?
    ps, post pics. It's monday morning, we need some bike pron!
  • 12-03-2012
    mikemikemike
    Thanks for a great review - everything you say is what I would expect and why I'm excited about this group (not that I can pony up for it anytime soon).
    Curious: why did you go back to XTR after XX? (if I'm reading this right).
  • 12-03-2012
    ducrider
    Mike & RedMR2, I've updated the original post with the details and weights
  • 12-03-2012
    redmr2_man
    Thank you. Interesting that the cassette is only 70g heavier than xx 11-36.
    That bb30 crankset weight is 120g under what i've seen, that is great news!
  • 12-03-2012
    Trashcanmike
    Great Review. Thanks
    What did you do about wheel systems? This seems like the biggest impediment to changing over.
    Salespunk- what will you do with your EC90's? Is there a conversion?
  • 12-03-2012
    ducrider
    The carbon Rovals on the S-Works Epic 29er use DT Swiss internals. On the Intense Carbine, I have a set of Enve AM 650b wheels which also use DT Swiss 240 hubs. It took all of 30 seconds to swap each of these to the new DT Swiss XX1 hub bodies, no tools needed.
    Right now, if looking to use your existing wheelset, best case would be that you have either Sram or DT Swiss rear hubs which have readily available XX1 compatible hub body replacements available.
  • 12-03-2012
    Salespunk
    Easton is working on the new cassette body for the M121 hub, which is the late 2011 update. The older M120 will not have the ability to upgrade. Really interested in trying the XX1 though. I like the gear spread and not having to run a chainguide.
    Awesome feedback and thanks for the datapoints.
  • 12-03-2012
    timex99
    XX1 would be a very nice upgrade coming from a 1x9 setup. The biggest draw back, though is you have to change your rear hub just to accommodate their cassette. I hope shimano is working on something that would not let you change the hub just for you to have a new drive train.
  • 12-04-2012
    Jamenstall
    Nice write up Ducrider. Just for the record Hope has a cassette body available also.
  • 12-04-2012
    Trashcanmike
    Sweet!
    Loving XO with gripshift and type 2 RD but the FD mount has issues (not perfectly straight) so this is worthy of consideration next year!
  • 12-04-2012
    Salespunk
    Shimano will not be able to run a 10t in the rear without a redesign of the cassette either. It is a physical limitation based on the diameter of current freehub bodies. Without a 10t they will not be able to get the same topend. What I like about the XX1 is that a 38t up front gives a similar low gear to a 28/36 which is my current low and a high gear similar to 40/11. I am switching to 1x tonight with a 32t up front and will probably go to a 34 before the end of the month.
  • 12-04-2012
    unclekittykiller
    156 Q-factor
    Anyone try the narrower q-factor XX1 cranks on an Ibis Mojo or HD? Wondering if the arms will clear the chainstays without problems
  • 12-04-2012
    timex99
    Wow didn't know that hope has one. Do you have any idea how much is the cassette body?
  • 12-04-2012
    myitch
    XX1 is a great concept. But I too prefer Shimano. What I'm more concerned about over losing top end is the low end. I hate climbing so I currently run 22t granny and 36t rear. Call me old fashioned but it makes climbing less painful for these tired legs and lungs.
    Going 32t-42t is still not low enough for me. Guess I'm sticking with my current setup. That's good. I need to wear this one out before I blow another wad of cash.
  • 12-04-2012
    Jamenstall
    I haven't been able to find any online, but I would assume/hope they would be around the same price as their standard bodies.
    I did although speak to Hope USA and they were placing an order for them. That was about 3 weeks ago.
  • 12-04-2012
    ducrider
    BTW, there is a 28-tooth XX1 chainring available which will get you the equivalent of 24 front, 36 rear. Pretty close to your setup.
  • 12-04-2012
    Salespunk
    You might try pushing a bigger gear. I have found that it lowers my heart rate and breathing considerably. Doesn't make me faster though
  • 12-05-2012
    Maverick005
    Hans confirmned my frame is shipping to me today yay, My XX1 has been lonley in its box, I dont get the fasination with losing gears, Ive been on single rings for years, ran 11/36 x 33t up front still rode up everything everyone else did, was it harder yes, but still no issue, with XX1 it will be a doodle, why do people knock what they haven't tried.
    The rear d is heart of XX1 that I find sexy, the cage does not need to go forward and back it just follows each cog, quite amazing, I cant wait to get it on my HD.
    Maybe next week by time it lands goes through customs get her built up, so excited, nit been so excited about a frame and drivetrain for years.
  • 12-05-2012
    myitch
    Yeah, but I prefer to spin vs. push. And I'm not a big roadie either but I feel it's more effecient. Don't get me wrong, though, this XX1 has me very tempted but dang, gotta change the whole drivetrain AND freehub body. I just bought my new 10spd goods too.
    I bet in about 1-2 yrs Shimano does something similar and maybe even better. Without getting into a Shimano vs. SRAM debate, Shimano has just been better for me. Like disc brakes and suspension forks did, the technology will improve and come down in price. I'll wait for better carbon wheels/rims, and now this 1x11 concept too.
  • 12-05-2012
    skidad
    Perfect, that's my current setup on 2x10. 30T might be and option to try also.
    Hadley will have a freehub available in January and I9 is already shipping theirs.
  • 12-05-2012
    conekilr
    I recently e-mailed Ibis about this and he gave me the thumbs up:
    "Yes, a 156mm q-factor SRAM crank will fit on the HD. Clearance is tight, but it does work just fine. We specced 156q cranks in our XX kit for years and didn't have any issues."
    You might consider the size of your feet and how they are positioned on the pedals though.
  • 12-05-2012
    Salespunk
    I am/was a spinner too. Just went to a 28/40 XTR 2X and was surprised how much I liked it and adapted to it. My last ride I did not go above by 28/28 and felt really good. Going to a 34 1X today, but I do like the idea of the XX1. Hopefully Shimano will have a solution soon.
  • 12-05-2012
    SJDude
    Shimano will not be able to run a 10t in the rear without a redesign of the cassette either. It is a physical limitation based on the diameter of current freehub bodies. Without a 10t they will not be able to get the same topend. ...
    Might be misunderstanding you but I have 07 XTR wheels/freehub with 0h 12 two by ten. No prob. Do you mean Shinamo wheels can't fit an 11 tooth with the current spacing? That would be a deal breaker to me. I want hubs I can O/H in 10 minutes with $10 woth of tools on the floor of a hotel room at 2 am. Shimano or bust there. If the 1x11 would fit XTR wheels I'd consider it for sure...
    OP do you ever find the XX1 shifter tripple clicks down on you when you only wanted one gear? My X0 used to do that to me all the time especially on bumpy ground like say in the mountains. Want one gear...get three. :)
  • 12-05-2012
    Salespunk
    Correct, Shimano hubs cannot fit the XX1 rear cassette. The diameter of the Shimano freehub is too large to fit ANY 10T cassette. Might want to check out the SRAM wheels, but it sounds like you are refusing to run any wheels that have sealed bearings which is really limits your choices.
  • 12-06-2012
    unclekittykiller
    I did make a quick call to Ibis and they also confirmed that the 156q will work for the Ripley as well. I have small to medium sized feet so I'm not so much worried about heel rub, but the narrower q-factor should help with pedaling for my short ass legs.
  • 12-07-2012
    kalkhoffpink
    Wondering if there is/will be a bash guard available for the XX1. Otherwise it would be very painful to break some tooth of the chainrings or even damage the chain or the carbon crank while accidently hitting some rocks on the trail....:skep:
  • 12-07-2012
    Maverick005
    An MRP XCG BB mount might work, the cranks themselves can't take a bash guard as std they only have the one ring mount, unless you can remove replace the spider as you can on XO cranks.
  • 12-07-2012
    kalkhoffpink
    Is the design of the XX1 crank a lot different from others? Normally it is no problem to just add an outer bashguard and lock it with longer screws to the original spider/chainring?!
  • 12-07-2012
    skidad
    I also would like to have a bash option. Living in New England I know I could find a way to smack the single ring.
    It's still so new but I'm sure someone will come up with a solution(s)
  • 12-07-2012
    kalkhoffpink
    Well I found this one:
    MRP Responds To SRAM XX1 With Three New Chainguides - Eurobike 2012 - Pinkbike
    But I would prever a solid outer ring instead of a flimsy chainguide solution.
  • 12-07-2012
    Maverick005
    Yes but is that compatible with the IBIS dw link?
    Doesn't say its BB compatible?
    Edit, I found this thread answer from Noahcolorado cheers
    It is BB compatible sweet, may look at one of these myself.
    http://forums.mtbr.com/ibis/mrp1x-et...hd-821924.html
    Kalk. Ski, the XX1 crank like the rest of the system has been designed ground up each component is not like any other component before it so you cant compare to what you have been used to.
    The cranks spider as std has no recesses its only one is for the chain ring, longer bolts will do nothing, this is to optimise the chain line I would say.
    Like other Sram cranks you maybe able to replace the spider, I would look but all my parts are at the LBS waiting on the frame for installation.
    The MRP XCB should def be compatible anyways.
  • 12-07-2012
    Maverick005
    Found this pic, first in this link, looks like the spider is removable so in theory you could mount a std Sram spider to allow for bash ring compatibility.
    SRAM XX1 Review
  • 12-07-2012
    kalkhoffpink
    SRAM XX1 Review
    I am not the best engineer in the world but the chainring on the XX1 is easily removable to swap the chainring to another size. IMHO it should be no problem for what company ever to invent a simple bash guard with the right holes and dimensions to fit the xx1 like any other bash to be attached with longer spider-screws...
  • 12-07-2012
    Maverick005
    You are missing the point, maybe read some XX1 articles thoroughly you don't need to be an engineer just read it, this is not a standard spider on the crank arm.
    Ive run single rings for years with bash rings I know what you're assuming, they're is no way a standard bash ring can mount on that spider, read my earlier post about the removable spider then yes a std bash and ring will fit.
  • 12-07-2012
    kalkhoffpink
    Hmm, I didn´t get it. From my point of view I see no problem. Heres a pic:
    To me the crank with the spider and the chainrings look like on every other crank.
    Maybe the dimensions are a little different. But why should a bash with longer screws not fit on this one? And I do NOT mean an existing one it hast to fit the XX1 dimensions of course. Where is my mistake?
  • 12-07-2012
    skidad
    Well you could probably jury rig longer bolts and spacers but there will be no shoulder edge for the bash to mount on. Totally supported by just the bolts which I don't like the idea of.
    This thing is so modular that there will be a good solution in short time for a full outer bash ring like for example this spider assy from North Shore Billet for XO and X9 cranks arms that allow the use of 104BCD rings (for those stuck with the 120BCD cranks)
    2 x10 104BCD Spider for SRAM X0 & X9 Cranks « North Shore Billet
  • 12-07-2012
    unclekittykiller
    The four bolt holes on the XX1 spider are not equidistant from each other. The 76 BCD on the spider requires the two holes along the crank arm to be spaced further apart in order to get an allen key in there. There aren't currently any bashes on the market with this configuration.
  • 12-07-2012
    skidad
    Anyone know if the crank arm removes from the spider or is it integrated or bonded or whatever? Looks like it might be removable?
  • 12-07-2012
    NoahColorado
    It is removable. It is a splined interface - same as X0, X9, and Truvativ AKA. AFAIK the XX1 arms are the same as X0. I am using an XX1 spider and ring on my X0 crankarms.
    One of the reasons a bashguard won't fit on the standard XX1 setup is that the spider is has no surface to mount one on.
    An MRP XCG will keep you protected - or an MRP AMg will keep you protected AND ensure you never lose a chain.
    Cheers :thumbsup:
  • 12-07-2012
    Logover
    Another wheel options would be Industry Nine. They have a freehub that fits it also.
    Industry Nine SRAM XX1 Hub and XC29 Carbon Wheels | Mountain Bike Review
  • 12-07-2012
    29ermaniac
    Any chain drops with XX1 crank?
    Is the crank reliable enough not to use a chain guide or something like that?
  • 12-08-2012
    dwt
    Ah, the old high vs. low gear argument. I thought it was generally understood at this point that spinning lower gears is more efficient than pushing big gears - which tires out your quads faster and strains your knees. It's not wimpy to prefer lower gearing. Use what feels right to you. If you like to grind, go for it
  • 12-08-2012
    Salespunk
    If you had read my entire post you would see that I used to spin small gears. I don't believe it is wimpy, I was encouraging people to try new things. I have gone from a 22/32/42 triple to a 28/40 2X to a 35 1X in the last 60 days and felt better on the climbs each time. Try it, you might like it!
  • 12-09-2012
    kalkhoffpink
    Congrats to your strong thighs, but I do not see how this should work with normal bikers. At the moment I am riding a 22/36 2x combination and on my tours I am often very happy about the 22 front, 36 rear combo because otherwise I would not be able to climb a lot of parts of the trail.
    Thinking of switching to 34 in front and 42 (XX1) in the rear within 60 days would be a miracle. How should this work without month of training? I would definitely start with the 28 front 42 rear combo at first...
  • 12-09-2012
    marcoton21
    Well, the whole thing about XX1 is that you can pretty easily change the front ring. Buy 2 or 3 and change them out whether you ride trails or mountain stuff.
    Only a monster could crank up a hill in the alps with 34/42. On the contrary on those trails you harldy need a big ring going down because anyhow you don't need to pedal to get speed.
  • 12-09-2012
    dwt
    As my entire post said "ride what you like"
    I still have my 26" SS. If I want to grind a big gear climbing, I can. I put "a normal" sized ring on my 26" 1X9 (32T) for the greater efficiency while climbing in a lower gear. On the other hand, while hammering, I rarely spin out the 32:11. On my SS, I frequently spin out 32:17
    Everybody is different. I have been in many arguments with "pedal harder" 29'er folks who insist they have no problem riding bigger hoops with gearing designed for smaller hoops.
    Not me. Whatever floats your boat.
  • 12-09-2012
    canuck_tacoma
    Get a cadence meter...best thing I ever did. 90-95RPM is a good target for endurance. Then when you hit a big climb there's gas left in the tank for more power.
    Sorry for hijacking.
  • 12-09-2012
    techfersure
    After being with SRAM for about 10 years have become smitten with Shimano again,and have now converted most of my bikes back after dismal results with brake dependability derailleurs are fragile and need more constant care then Shimano overall.although am tempted by the XX1 and support innovation and can get it at cost I see know real advantage or need to alter the gearing range I currently enjoy for all of my needs,38t-26t Xt triple with bashgard 11x36 cassette.
  • 12-09-2012
    Salespunk
    No worries, it's all good. I am definitely not the strongest rider out there, just forced myself to do it.
  • 12-16-2012
    Jamie_MTB
    Its bloody good
    That 42t on the rear is a get out of jail card on the climbs :-)
    Its sooooooooo quite, also loved moving the reverb to the left and under the bar.
    It's funny at first; when you'd normally switch from granny to middle, you automatically go for the left trigger, but now it's a couple of clicks on the right.
    goes to 11 by jamesfergie, on Flickr
  • 12-16-2012
    skidad
    Toons101 that's a killer bike/XX1 combo. What chain ring you running up front?
    Ibis soooooo needs to make a dedicated 650B triangle for the HD.
    I've put the bug into the ear of North Shore Billet to make an XX1 spider that you can attach a bash guard to. They're slammed with stuff through the end of the year but I'll follow up with him in January.
  • 12-16-2012
    skidad
  • 12-16-2012
    Jamie_MTB
    It’s better with the CCDB
    30t up front
    I also tried the RP23 shim but its still pants compared to the CCDB
  • 12-16-2012
    Maverick005
    I have a 32t currently, too easy Im used to single rings been running 10spd 33t x 11/36 all year till the XX1, going to go to a 34t up front, def nice to have that 42t rear, the speed and precision of the shifting blows me away, Ive run every gen X0, ridden every gen XTR and this is incredible, Ive been able to change and instantly put the power down which also seems to suit the HD and just take off, so much is the confidence in the drivetrain and speed and that was from the first ride session which lasted a good 3hrs.
    Also the one piece cassette is insanely stiff and stunning.
  • 12-16-2012
    Salespunk
    Awesome builds. I have mine on order now, but it is out of stock at the distributors until mid January. Love the fact that I get more top end speed with some climbing gears and still 1x!
  • 12-17-2012
    Maverick005
    Just FYI
    XX1 comes as std with a 32t front ring, so if you want a smaller or larger you have to get another, might be different in other countries, but they don't swap out here, so looks like another $150.00 nzds in the New Year.
  • 12-17-2012
    timex99
    How much is the entire xx1 drive train? I believe that doesn't come with the rear hub right?
  • 12-17-2012
    Maverick005
    Mines in NZD currency, $1650 I think mine came i at.
    I had to buy a new rear hub, my CK was not XX1 driver hub shell compatible so it cost me on top of that for a DT 240 rear hub, and wheel rebuild.
    I needed a new drive train anyway complete so her even if I did do a new group set, cranks etc I wouldn't have saved much so apart from the hub and rebuild it was easy to justify, after riding it it's even easier.
  • 12-17-2012
    fuenstock
    I'm really interested in the xx1 setup. I'm currently running my HD as 1x10 xtr with the Ibis hd specific mrp chain guide. I wonder if the xx1 would work with my existing xtr cranks and chain guide? I still want to run a chain guide since I tend to bash the guard a lot and need the protection for the chain ring? I would want to save money and keep my cranks and guide if possible. Any one try this?
  • 12-17-2012
    Salespunk
    I don't believe it will work with your XTR cranks because of the specific chain which is matched with the front chainring. The magic in the setup is that the width of the front ring teeth alternate with the thickness of the chain. Might be worth a shot though. For most applications (read as us) a chain guide is not required, but I can understand the bash guard. Jerome Clements did ride a guide for the Mega Avalanche race, but claims he has never dropped a chain without it either. My plan is to only use my e13 for racing and run it without the rest of the time.
    Price in the US is $1250 without the rear cassette and it can only be ordered with the 32T front ring. Spare rings run about $100.
  • 12-17-2012
    Maverick005
    You guys really need to read these threads properly, yes you can use a guide but not any guide, XX1 is ALL designed ground up its not compatible really with any other brand or components, thats defeating what it is about, just need to read the info, this group is not about cost saving up front, I believe it will save costs in the longer run, time will tell, did when I went 1x 9 and 1x10.
    Cheers.
  • 12-17-2012
    skidad
    Here, read through this linked info. Works with some other setups.
    http://forums.mtbr.com/sram/sram-xx1...ed-818475.html
    The clutch spring is so dam strong on the XX1 you don't need a guide (at least with the proper XX1 ring). A bash would be very nice however. I've been in touch with North Shore Billet about this issue and he had an XX1 crank on his desk today. I would expect to see a replacement spider from them that has a provision to mount a bash ring in the not to distant future. Maybe Sram will do it also at some point but do they really think people wouldn't want to protect that $$$ ring/chain combo even if it is really small and less likely to be hit? I'd figure out a way for sure to smack it. Give me a bash please.
  • 12-22-2012
    Vegard
    No rear hub included with the group, you'll have to sort that out yourself.
    I paid $1001 for my full XX1 (BB30/Q168/170MM/Trigger) groupset on ebay a couple of days ago.
  • 01-03-2013
    trenchDiggr
    Looking into this upgrade. I have the 1st generation HD with the 135x12 rear thru axle (later HD's have 142x12). I cannot find a DT Swiss XX1 conversion kit for 135x12. All I can find are 142x12, 135x10, and 135 QR kits. The kit contains the freehub body and the drive-side end cap, so it seems I would need a kit with the proper end cap for 135x12.
    Anyone using XX1 on the 1st generation HD with the 135x12 thru axle?
  • 01-03-2013
    saidrick
    Hmm, just finished reading Decline magazine's review o this product. They think its awesome. I am still learning and loving. My new 2x10 to think about switching.
    However, what I found interesting about the magazine article is this: they quote SRAM as claiming the special chain for the system will last FOUR times as long as a traditional chain.
  • 01-03-2013
    Maverick005
    The benefits to a single ring drive train will become more clear once it trickles down to X0, X9, XX1 must have exceeded all Srams sales expectations, its mind blowing how good this is.
    Having run single ring for years and dual rings before that, Im blown away by the range, Ive been pedalling up breaks that normally bore me to tears and drain my will like life sucking vampires, now I find myself doing 4 or 5 runs up these breaks to reach my fav single tracks and barely breaking a sweat doing it, I kid you not.
    This has put the P in my E for Enduro, the hole setup is so stiff its incredible when you drop the hammer how it responds so stiff, I put this down in part to the HD as well, I could easily feel flex in my X0 10spd setup with chainguide on the same tracks on another carbon frame, that frame did not flex either, but the drivetrain didn't quite match it like XX1 does.
    Imo if you have a good drive train now either 1x10 or 2x10, 9, 8, 7 whatever the I don't think you need to upgrade to XX1 unless you can self justify it, is it worth it imo! yes for me, but I also had to buy a complete drive train anyway so it was a no brainer being a single ring fan anyway, I just hate FDs.
    I dont miss my chain guide but a bash would be nice at some stage, will see what options develop from the players.
    You have to understand this also has allowed the big ring to move to the rear where its less vulnerable protected in the inside of the cluster at the wheel allowing a smaller ring up front. Ive sorta got used to the 32t for now, Im not so sure about running a 34t so will hold off for now.
    XX1 :thumbsup:
  • 01-15-2013
    manuel.vivar
    Hi, I'm Manuel from Chile, I have a bike Ibis Mojo HD 160 and I want to install the Sram groupset XX1,
    Wrote to Ibis Cycles and they said
    "Hello Manuel,
    For XX1 the crank clearance is the same as with XX. So 156 or 168 Either will work. However, there is a clearance issue with in the 10t cog XX1. The chain will rub on the frame in That gear. We have not received any groups yet XX1. So it is hard for me to offer you specifics, but quite a few People Have Their frames modified to Work with XX1. The two methods seem to be adding a spacer Either on the end of the hub axle to spread the drop outs a little, or filing a small notch in the coal where the chain hits.
    Good Luck! "
    You had this problem? can help me with the solution?
  • 01-15-2013
    manuel.vivar
    Has anyone had this problem? serious? or can be solved easily without changing much the frame?
  • 01-15-2013
    Maverick005
    Ive not had this problem I regularly check my bike pulled the wheels off pretty reg as Im pretty anal about bike maintenance.
    Apart from some cosmetic scratches no different to any bike Ive had my XX1 has been deadly silent and rock solid not even a tune after being installed and Ive ridden nearly everyday, done a few guided tours, and ramping up that side so both are going to be subjected to allot of regular abuse.
    My LBS setup my XX1 they had installed quite allot of XX1 systems on customers bikes before mine so know what they're doing.
    Certainly would not be filing any part of my frame down at any stage, spacing if required,
    If it is an issue I would get some moto tape, clear roll of tape film 3m or something for protection.
    Got an Enduro nnext month and a Gondala mini downhill race as part of our Bike festival week so will be another test for the XX1 and HD 140.
    Cheers
  • 01-15-2013
    Maverick005
    Just thinking about this some more!
    HUB selection could be quite critical to this problem, not all hub flanges are spaced the same for a given width, this was an issue with a few 150mm spaced hubs with DH bikes a few years back, Chris King being one, I see they are updating they're 150mm hub.
    I use a DT 240s, this is hard comparison be because unless your wheel is built to the same exact stds, rim spoke etc it could affect some and not others, more likely less a frame issue and more a hub issue.
    Many hub manufactures will be trying to release a XX1 hub driver compatibility as I think even they realise they are behind the eight ball with its popularity to date and if a X9 XO version is released many will be left wanting.
    But if its not engineered properly then this will be a common issue on any bike imo.
  • 01-16-2013
    marcoton21
    Good to hear that the 240s are working fine. My XX1 is due next week. Hope this time the date is exact.
    Maverick: could you tell me how long your chain is? I.e. how many links you took off?
  • 01-16-2013
    Pelly_NH
    So far, only seeing HDs using this. Anyone with a Mojo SL running XX1?
  • 01-16-2013
    Maverick005
    240s are awesome, Im converted to DT hub, wont be going to Kings, love Hadleys but after these not sure Id use anything else now.
    Will have to check cant remember how many links we took out, but change length is def a crucial component.
    :thumbsup:
  • 01-18-2013
    marcoton21
    @maverick: Thanks already. That would save me quite some hassle as all HDs with XX1 should be same.
  • 01-19-2013
    Vgrmax
    Attachment 754423My Sl clear the 10t w very very tiny clearance .
  • 01-19-2013
    Maverick005
    Is that a small frame, what hub brand are you using?
  • 01-19-2013
    Vgrmax
    My Sl is a small sized
    Industry 9 w XX1 freehub
  • 01-19-2013
    Maverick005
    Hub choice is going to be interesting with the rush for manafactures to gear up for XX1 some will have it right others not so much.
    Was riding with another HD rider today he was on a 160 and flying but I could hear his drivetrain bouncing all over the place from behind, mine deadly silent I would think with chain and rear d making that much noise it would be more of a concern for chainstay seatsaty bridge than XX1 just another point.
    Also got me thinking maybe 140 is limiting me even though the lesser trails 140 should be better, but he accelerated like a cut cat on a flowy rooty grade 3 called Dragons tail some kiwis here will know it some may have sampled her fire, I was a little tired but still ha.
    Im not a fan of i9s never owned one never will just never taken me, I dont like proprietry products, Ive seen to many rims pulled apart by theyre spokes, and hub failures, mate of mine just went to the Trans Andes race, replaced rim late last year, spokes replaced front n the front and much play in the rear hub, it failed 3 days before he left for Peru after new bearings installed, riding a Hope now as couldnt get a DT 240 in time.
    Havent checked if Sram have speccs for XX1 width for hub and chainline, but to me this is not a frame issue but hub adaption / execution for the new driver body issue.
    Some will be lucky some wont depending on hub you have chosen or already have that has been adapted to fit the XX1 driver body.
  • 01-22-2013
    Salespunk
    My XX1 ships from disti today!
    On the 140 over 160, Hans commented in another thread that they did some impromptu testing on climbing. He stated that the 160 setup was just as fast as the 140 going up. Made me question why even bother with 140?
  • 01-22-2013
    fuenstock
    I used to run my HD at both 140mm and 160mm. I didn't really feel any difrence going up if I was just to swap shocks and keep everything else the same. When I did notice a diffrence was when I would switch to 140mm and also used my lighter wheel/tire setup. I think the lighter wheel/tire set I used in 140mm mode was much more noticable than the reduced travel.
    Im very interested in the xx1 setup, post pictures and report once you get some rides on it.
  • 01-22-2013
    Maverick005
    I agree guys def doesn't seem to hinder acceleration or climbing, saying that its hard to gauge comparison, in my ride the other day I had already done a fair few miles before hooking up with the Mojo 160 rider, I do allot of miles, have ridden allot since Xmas, just had a enforced 2 day lay off haha.
    Ideally Id prefer to run in 160 mode but steeper ha lighter fork means I can run all day, when I finally run 160 as an option I will probably wish Id done it sooner, fact is 90% of my riding while technical I can easily handle with less travel, the 10% keeps me excited and on my toes, I run pretty light tires as well, 2.25 Ardent/ 2.2 Icon locally our terrain again while plenty of smack also is pretty buff.
    I like my forks setup pretty stiff which also gives me a bit more punch for the harder stuff this makes up a bit for less travel, Ive actually not found the rear to be holding me back, Im the limiter haha
    Enjoy the XX1 when she arrives, what hub you running it with?
  • 01-22-2013
    Salespunk
    DT 340 as a hold over until Easton releases their body
  • 01-27-2013
    Salespunk
    Got my first ride in yesterday and all I can say is O M G. This setup is unreal. Will post a full review later, but it was a major mudfest and the XX1 was flawless.
    I will qualify this by saying I have been a Shimano XTR bigot forever. Started on the first generation of XTR and have run every iteration since then.
  • 01-28-2013
    Maverick005
    Just wondering what chainline you guys are running?
    is this a home install
    or LBS install?
    Ibis uses an 68mm BB.
    Some full speccs here may or may not be helpful
    BB setup guide
    Frame fit specifications
    :thumbsup:
  • 01-28-2013
    Maverick005
    Hubs being produced or available, note some interesting details further down re each manufacturer.
    DT Swiss: Our XD driver is compatible on any DT Swiss Star Ratchet drive hub or wheel set. Currently the XD Driver is only available as a separate purchase. Moving forward, DT Swiss will have XX1 compatible wheels and hubs in our line-up.
    There are just a few exceptions that your readers need to be aware of though. Due to different internals, our DT 340 hubs or any of our pawl-based wheels/hubs are not convertible to the XD Driver. OEM wheels built from DT components, may or may not be convertible – it’s best to check with your local bike shop prior to purchasing parts.
  • 01-28-2013
    DRILLINDK
    I have my XX1 components. Now I'm waiting on my frame and fork to come so I can start my build.
  • 01-28-2013
    wilks
    I'm waiting on my I9 wheels!
  • 01-28-2013
    Pelly_NH
    Did you opt for the new Torch hubs/wheels or the originals?
  • 01-28-2013
    wilks
    I went with the originals. Just in case they have any early teething problems. I have learned the hard way that being an early adopter can backfire.
  • 02-09-2013
    squiby
    Any word on an outer ring bash guard yet??
  • 02-11-2013
    groundskeeperwilly
    Just a quick note to say that I have been running the XX1 Chainset with Type 2 X9 rear mech, 10 speed cassette and chain and it is working 100% well! No dropped chains yet on some very rough and muddy rides in the UK. Might be an option for those waiting for new hub bodies etc for the 11 speed cassette.
  • 02-11-2013
    skidad
    No way to attach a bash guard to the existing XX1 spider. North Shore Billet is aware of this and hopefully they will have an accessory spider that will handle the double duty chores.
  • 02-11-2013
    skidad
    Or if your hub wont be XX1 compatible you could always try this LEONARDI RACING KIT MODIFICA PACCO PIGNONI 11/40 SRAM
    Attachment 770866
  • 02-11-2013
    chuckb77
    Attachment 770866
    I just ordered, came to $185 shipped, now time to upgrade the front chain ring and clutch derailleur. I figure all in, it will still be under $500 which is a heck of a lot chaper than XX1. I'll post up once converted to the 1x10.
  • 02-11-2013
    skidad
    Just exchanged a few emails with North Shore Billet and he said hopefully in a few weeks they will have a accessory spider available for the XX1 with a removable rock ring which will come in a few different sizes. Good news to hear!
  • 02-12-2013
    mazspeed
    I don't know if this is really on topic, but how much lighter is the xx1 than a 3x30 xtr setup?
