Results 1 to 36 of 36
    Proud bike-o-holic
    Reputation: Psycho Marco's Avatar
    Nov 2008
    Am I missing something here?
    Hello all,
    I just had my Mojo SL built so I have no experience with it so far but along with the flex issues which seem to be not an issue anymore, I have found two other subjects in which I think I need your input.
    1.- Belly protectors. Why is there a tendendy to protect the belly of the frame? I know we all want to take care of our expensive frame, but I´ve had 2 other bikes and protecting their belly was not an issue. So my questions are: Does people simply like to protect their frames just for an aesthethic purpose? or are the carbon frames affected by rocks and there is a risk of damaging the frame at an estructural point so you better protect their belly?
    2.- Chainsuck. What is that? a simple explanation about this would be appreciatted (non english speaking native here). Does everybody have to worry about this? or is it just for older models? or year of model has nothing to do with it?
    Thanks in advance.
    Marco
    1. Belly Protectors - Almost entirely aesthetic. You don't "need" one to protect the structural inegrity of the frame. Just like any bike, you could break it in a hard enough fall/impact. But there is nothing about the carbon frame that requires a belly protector versus an aluminum one. Just more people who are paranoid about a little bit of clear coat chipping on carbon frames.
    2. Chain suck - Occurs when your front chain ring picks up the chain and pulls/sucks it up between the chain rings and the chain stay so the chain is now above rather than below the chain stay. If you get it, it can be a major pain to get the chain back out because it took a lot of force from pedalling to pull it up. I have never had a problem, but I know some people have. I believe you can use spacers to move the chainrings further out which reduces the chance of the chain getting stuck when you get chainsuck.
    Mojo0115
    I really don't think that the Mojo Classic or SL need the belly protectors. The carbon down near the bottom bracket is insanely strong! I can see it on the HD to protect the cabling, but for the Mojo the cables run along the side.
    The only issues I have with Chain Suck on my Mojo are when my chain is old and needs lube or my Granny Gear teeth are worn and the ring needs replacement.
    Reputation: GuruAtma's Avatar
    here's a picture of chain suck:
    Usually only happens when things are really muddy and/or the teeth on the chain ring are so worn that they become slightly hooked and don't want to let go of the chain.
    I have a frameskin kit to protect the frame. I might consider a protector like the HD has only for when I ride places like Downieville---I'd probably remove it for my regular trails.
    功夫大师喜欢骑着他的自行车在山上。
    Happy when not-last.
    Reputation: MinskyBA's Avatar
    I got the frameskin (belly protection, as well as the rest of the major surfaces) to protect the paint. I know the bike can take the abuse, but I don't want to constantly be filling in chips in the paint.
    I'm not sure if it matters but I run 1x9 with a bash-guard. I can't remember the last time I had chain suck.
    All your base are belong to ME.
    T.W.O.
    Reputation: mimi1885's Avatar
    I agree that the frame protection is for more of the look than function needed. It does offer protection from rocks and pebbles. If you crash and hit the DT to a tree or big rock no plastic cover is going to prevent that, if the frame is going to crack it's going to happen. I don't recall that happen yet though. The frame is so strong.
    As for chain suck, it happen sometime when you shift from the middle to the granny ring on the bumpy climb or more load putting on the crank. It had not happen to me for a while now. I don't put full power or heavy load to the crank when I shift, that's all. I think you get used to it.
    I just converted one of my Mojo to 2x9 32-22 set up with stinger and bash guard and another Mojo stay triple but add the K-edge dirt catcher( more for the look) to my bike and went out for a few spin around the house. Trying to shift with pressure on the crank and so far so good. Will keep it posted.
    Proud bike-o-holic
    Nov 2008
    Ok, thanks guys for the explanations. That chainsuck picture is very informative.
    I´m going to put some frameskin on the belly (the frame´s, not mine :-) ) but now I´m glad it´s only for looks and not structural purposes.
    BTW, when you get a chainsuck, how do you return things to normal?
    Regards
    holding back the darkness
    Reputation: subliminalshiver's Avatar
    Quote Originally Posted by Psycho Marco
    Well... typically you curse very loudly at the bicycle to prepare it for what is to come.
    Then you grab hold of the chain and pull. Hard. Ouch.
    In some situations it helps to compress suspension to open up a gap between the chainstay and the chainring while working the chain free.
    Regards
    Depending on how bad the chainsuck is and how quickly you notice it, sometimes just peddling backwards half a turn will fix it. Sometimes the chain gets really jammed up between the frame and chain rings. Then it takes a little finesse and some brute strength. Having your chain grind against a carbon frame is not good. That's why they have the little metal bit there--just in case.
    But if you change your chain/chainrings when they get worn, you may be able to avoid chainsuck altogether.
    功夫大师喜欢骑着他的自行车在山上。
    Proud bike-o-holic
    Nov 2008
    OMG I didn´t see this coming!!!
    The cursing tip is a good one!. Ok, I hope I won´t ever have a chainsuck but at least now I know what to do in such case.
    regards
    _____
    If you ride rocky trails like I do then I would recommend a good belly protector/bash guard like the one for the new HD (it also fits a standard Mojo). Check out what a rock did to the bottom bracket of my six month old SL. IBIS says I need a new front triangle and it is not covered by the warranty. However, I've put several rides on the bike since then and everything feels tight
    Attached Thumbnails Attached Thumbnails Am I missing something here?-img_1291_small.jpg
    Dec 2008
    Why on earth would a rock strike be covered by the warranty? Use the crash replacement offered by Ibis and be happy.
    Also, a good belly protector shouldn't be too hard to make. Just take a solid sheet of aluminum or steel, drill two holes and then bend it to make it follow the frame tightly
    boardguru
    Go to go-ride.com, in the accessory section. Down Tube Guard. I have a diamond plate version on my Mojo. Not a problem yet in four years, plus it looks gnarlier than the Ibis plastic protector.
    It has taken some really big hits from rocks that would have made the down tube look like SiO2's.
    Dec 2008
    Quote Originally Posted by n0uD'nt
    By honoring this particular customers request, it would show that Ibis has confidence in their design. The only reason that they would not honor it, IMO, is because they expect that this will not be an infrequent occurance. Why else would they protect the DT straight from the factory?
    Given the debate about the durability of carbon, Ibis would be shooting themselves in the foot. I've put dings in an alum DT where the results were far from catastrophic. As a matter of fact I don't think I have ever seen an Aluminum frame put out of commission due to a DT strike.
    So what you are saying is that Ibis should replace all carbon damage caused by riders just to attract those who still haven't understood the benefits of carbon fiber? I really cannot understand why Ibis should be replacing a frame for free when it's the rider who has faulted.
    Lopes linkage can load up
    Ive had my SL since Nov 09 use tape, made a belly protector and fender. Dw link can load up with mud and rocks. Under lopes link carbon bump can get chewed up. Its really up to U how much protection or non at all.. Wifes Pivot mach 5 DW link also I put a small fender to keep away mud and rocks. I found attached link and modeled mine after this. Ended up useing a heat gun from work ( Industrial Hair dryer for shrink wrap etc ) to curl lower edge all th way around lower triangle covering area by serial number.
    http://forums.mtbr.com/showthread.ph...44347#poststop
    Dec 2008
    But what makes this crack any different from other cracks coming from crashes? The Mojo SL isn't delivered with a DT protector, in the same way as it isn't delivered with for example a head tube protector (whatever that would be). With your reasoning, anything that isn't protected should be covered by warranty, even if it is 100% the riders fault. I think the owner of that Mojo should be very happy that Ibis has a decent crash replacement program, so it shouldn't be too expensive to have the main triangle replaced.
    If that had been a light aluminum frame, I'm pretty sure it would be fubar as well.
    ouch!
    Quote Originally Posted by SiO2
    How exactly did you do that? What is the cost of the front triangle under the crash replacement warranty?
    I hate to see that, it makes my stomach turn
    _____
    My riding area in the Phoenix Mountain Preserve is covered entirely by rocks and lots of them. It makes the surface of Mars look like a golf course. I never have to worry about mud because there is no soil on the trail, just sand an rocks. It is very hard on bikes. Check out the down tube from an old steel frame I rode for years. I am recommending that people who ride rocks and own a high end bike get a down tube protector, regardless of the frame material. I am new to carbon and ibis and full suspension bikes. I carry a lot more speed with full suspension then I ever did on my hard tails. More speed = more energy = more force from the rocks hitting my down tube. I am learning what is required to properly armor a FS bike for my specific riding area. Will I buy a new ibis? Yes, but with a strong down tube guard.
    http://gallery.mtbr.com/uploads/mtbr...1337_small.jpg
    Mal Ad Osteo
    Reputation: somsom's Avatar
    I didn't say ALL did I?
    This particular instance should be warrantied. Especially since they are now offering DT protection as a stock "accessory".
    So only you should be getting it replaced
    _____
    Quote Originally Posted by jimmyj1973
    I get rock strikes all of the time from the loose rocks that litter my trail. Every once in a while my front tire will hook one just right and throw it into my down tube. I don't give it much thought because it happens so often. I found this one when I was cleaning my bike.
    A new front triangle under crash warranty is $450 plus tax and shipping.
    Proud bike-o-holic
    Nov 2008
    Hey, sh$t happens. I wouldn´t expect Ibis to warranty all frames under any crash circumstances.
    BTW, that is a fugly hole in your frame!, but I would happily pay 450 + tax and shipping to get a new one. THat doesn´t sound too bad IMHO.
    Getting the DT protector sounds like a good idea though
    Regards
    Slothful dirt hippie
    Reputation: verslowrdr's Avatar
    Quote Originally Posted by boardguru
    Can you post up a pic of your lashup? Sounds interesting.
    JMO: while I'd love to get a free front triangle if mine looked like that, I don't know if I could blame Ibis for wanting some $$$ for a replacement. From here it looks like a head-on collision with a rock at pretty high speed. And FWIW I'd think an aluminum frame wouldn't have fared well with a hit that hard either... but... I'm no expert. Anything is possible I suppose.
    "...Some local fiend had built it with his own three hands..."
    aka übermensch
    Reputation: Triple T's Avatar
    Maybe I'm missing something here, but I thought the point of the polycarbonate downtube protector on the HD was primarily for the purpose of protecting the exposed cables, and secondarily to help protect the paint from rocks kicked up by your front tire.
    I don't think it's been mentioned anywhere that this downtube protector will keep your frame from being damaged during a crash.
    I bought one for my SL because even though I have Fishboy's frameskin kit, I like the idea of additional paint protection in that area, not because I expect it to keep my frame from being damaged from a high impact crash.
    08 Ibis Mojo SL
    09 Ibis Tranny SingleSpeed
    Church of the Wheel
    Reputation: mtb143's Avatar
    Quote Originally Posted by Triple T
    Exactly right. The plastic protector on the HD is NOT a downtube protector. It is there expressly to protect the cables that run under the downtube. It is a cable guard. Anything beyond that is a bonus.
    "I thought you'd never love me without my Mojo." -Austin Powers
    gnuH
    Reputation: kiwirider's Avatar
    Quote Originally Posted by mtb143
    Why do you need a cable guard? They are pretty robust themselves.
    A green bird with a red body. We could look it up in a book. Or we could look up
    Church of the Wheel
    Quote Originally Posted by kiwirider
    Cables aren't as robust as the frame. Downhillers and similarly crazed riders have a tendency of mooshing the downtube cables between the frame and rocks/logs/other immovable objects.
    I have no need of a cable guard, but others might.
    Feb 2005
    Quote Originally Posted by verslowrdr
    I don't think they would actually make any $$$ on a crash replacement, the idea is they basically sell it to you at their cost to get you going again.
    At $450 + I think that is very reasonable given the price of a new frameset.
    If they gave it to you for free, not only would they be losing money, but it would mean that they would also have to open up for any customer that has caused damage to their frame to have it replaced for free.
    Given it isn't a manufacturing fault, a crash replacement is the logical and generous solution, and that's awesome that they can offer you that.
    Since it's not covered by the warrantee I'd carefully remove any loose material there, wet out some fiberglass/CF strand and repair it with either epoxy or poly resin, after I talked to Ibis to see what they use, and keep riding it. IF IT WERE MINE. I'm not suggesting others do it, but I'd personally be comfortable making that kind of small repair.
    Before anyone says "you can't do that it's dangerous!" consider that lots of us repair/modify and even build boats from similiar materials and then go out in the ocean with them. Carbon fiber, kevlar, fiberglass structures are commonly repaired.
    edit: just to add, you can effect a small repair on damage like above and check the area for propogation of cracks. If it gets worse, we can then take advantage of the crash replacement program. I love having these options. Options rule.
    Church of the Wheel
    I guess I don't understand. You guys keep saying that it was a "crash". If it were a crash I'd agree that it was the riders fault. This particular bike was made for attacking the chunk. It definitely falls into a grey area, but with all of the controversy surrounding carbon they would do well to replace the frame in this particular case.
    That is why I will probably never buy a carbon bike.
    The Mojo rides great, but as I have stated I have NEVER seen an aluminum frame put down due to a rock strike to the DT. This may be a one in a million case, however, $450 would be a lot for me to swallow. Especially, if it was within the warranty period.
    He said he ran into a rock. That's sort of the definition of "crash". What's not to understand?
    Church of the Wheel
    So if you buy a new car and run it into a brick wall, then that's clearly your fault, right? But if a deer jumps in front of you then you're going to take the car back to the dealership and demand that they fix it for free?
    Stationary rock versus airborne rock: Neither one is a manufacturing defect. They both result from the user's choices and actions.
    _____
    I'm not sure it is accurate to say that I ran into a rock. It's more like the rock ran into my bottom bracket after my front tire flung it into the air. My front tire often times throws rocks as I ride over them at speed. Sometimes they fly into my down tube/bottom bracket (or my shins ). The ironic thing is that most of the rock strikes happen on the flats and not the steep technical areas. I don't pay attention to rocks strikes because it happens so often where I ride. I found the crack when I was cleaning the bike.
    Church of the Wheel
    Cars are not made for running into brick walls.
    Down tubes should be made to sustain such damage due to the type of terrain for which they are intended. Regardless of the outcome, it is my opinion that this proves we are not ready for carbon in the aggro trail/light FR application. I take hits like this sometimes and I have the dents/chipped paint to prove it.
    I don't believe for one minute that the DT protector was made for protecting the housing. Maybe the housing was intentionally routed that way to minimize damage?? Either way that "rock guard" would be an essential component of a carbon frame as witnessed by the Picture. Why in the heck would they want to only protect something as cheap as the shifter housing and not the $450 carbon fiber underneath? The fact that he was not provided with one at the time of the purchase should be grounds for a warranty. If the rider chose to remove the "rock guard", then I could see bad judgment.
    FWIW...during my Demo on the HD I was throwing an unusual amount of rocks into the DT. More so, than my aluminum frame in the same conditions (possibly because I was going faster!)
    We'll see what the next year brings .
    Dude, get a grip, and get your facts straight.
    1. The "Picture" is of a Mojo SL.
    2. Mojo SL's do not, nor have they ever, come with a downtube protector.
    3. The Mojo HD comes with a protector that is expressly designed to protect the cables. Are you calling the designers at Ibis liars? I'm pretty sure they know what they had in mind when they made it, and there is zero reason to believe that they have misconstrued their intent to the public.
    4. You say cars are not made for running into brick walls. Very true. Neither are bicycles.
    5. We're not ready for carbon FR bikes? You haven't been paying attention, because the industry is making a crapload of FR and DH bikes out of CARBON right now. Maybe you know something the big engineering brains don't, eh?
    6. Your idea that a piece of plastic is better protection than carbon fiber indicates that you don't understand the physics of the materials. Short version: carbon fiber is a lot stronger than plastic. A plastic guard will prevent scratches, but anything strong enough to crush carbon is going to crush plastic first.
    7. Why put a plastic guard on then? To protect the cables, which are more fragile than the carbon. Why protect the cables? Because bikes don't brake or shift well without them, duh.
    Did I miss anything?
    Oh, one last thing - Please don't buy an Ibis. Buy something - anything - else, so neither Ibis nor this forum needs to hear about your claims after you ride it into a brick wall.
    Peace.
    T.W.O.
    Don't hold your breath on the RFX. At best it'd be the end of 2012. World as you know it may not be the same, just like the carbon is stronger than Alu.
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    When would you ever get a rock strike that was hard enough to puncture cable housing?
    Busting housing is easier than the carbon. Specialized runs the cables down the bottom of the DT on quite a few of their bikes and there are complaints about the housing being destroyed by rocks hitting it. A riding buddy of mine had the der cable on his 04 Stumpy busted when a rock hit it in Tahoe a few years ago.
    On the 29er board a few years ago there was a reports from a guy racing the Downieville classic and a rock hit his downtube hard. For the next few miles he said the bike felt weird. Eventually it snapped in half. It was not a carbon frame.
    Given the right set of circumstances sh!t can go wrong.
    It's pretty simple. If you don't trust it, don't get it. I don't trust carbon bars or seatposts, but I have no problem tearing downhill on a full carbon Mojo frame.
    Reputation: miles wadsworth's Avatar
    Nov 2006
    [QUOTE=n0uD'nt]Thanks for clearing that up MTB143!
    Good to know that they don't even have as much confidence in the DT of the HD as the Mojo SL .
    The Mojo SL has the cables on the top tube, there for they don't need protection on the down tube. HD has cables on the down tube.OK?
    milesW
    Weird thread....
    The damaged BB area in the thread is probably the 3rd one we've seen over several years of production. So it's not a common problem.
    The test HD that OG raced in France DNF'd due to the casings getting cut in half by a rock. That's why we routed the casings outboard of the down tube a little earlier and made a guard. The guard is really strong and light and is backed with foam to keep it quiet and help spread out the force of an impact.
    It does help protect the down tube, but we're not selling it that way. The DT is pretty tough as it is, and you don't need the part if you don't ride fast in loose rocks, so it's not for everyone. We have had so few cases of damage in that area (without any guard) that it is nearly a non issue.
    That said, I'm pretty confident that the damage in the photo would not have happened with the HD DT guard, so you should use it for riding in very rocky areas if you're worried about it.
    As mentioned, carbon is stronger than the material the guard is made from, but it is very expensive and we were able to improve the performance of the plastic with the shape and foam backing.
    H
