Originally Posted by PeterG
... two years old, but with some custom modifications. Have you noticed the difference?
Yellowish wheels on the picture are only the second pair, so please no comments on that ;)
Just curious, who makes those gold rims?
Looks really good on an all black Mojo.
Those rims are Mavic XC317 from app 2001-2002, they are in fact citron-greenish/gold colour. I use them as a second pair of wheels on my Lefty build Jekyll and Mojo. Still going strong (xc riding) after all this years.
Right, Mavic X317 disc, called citron-yellow (yellow-greenish-gold anodized)...
... but real difference is in custom cable routing ;) :D
5 Attachment(s)
My Mojo SL w/ XX & 2011 Fox
So, the 2011 Fox Float RLC Fit 15mm just came in yesterday from Fox which was the final piece to my Mojo SL. I think it all turned out well, as every component was carefully thoughtout. As pictured it weighs in at 23lbs 15oz.
Yes it did. Super nice. :thumbsup:
Whoa, 24lbs that's very good. My regular XL Mojo comes at 28lbs even though I have XTR hubs/ XTR 180mm rotors/XTR derailers/XTR shifters, Noir carbon cranks (lighter than XTR) with 2 rings+carbon bash, Magura marta SL brakes, carbon light DH bar, fitzik seat post, thomson elit post and stem, egg beatters (regular) clip. damm... don't know where I could loose 4lbs. Ok fork is Revelation 150 uturn maxle (4.1lb with axel) and 819 mavic rims (likely heavier) with 2.35 El Moco F, and 2.1 cross mark R running tubeless.... still, that a big difference.
Big weight difference in your tires. You could inflate them with helium though, to compensate.
Wow, sub 24# with real wheels, grips, seat, etc.... that XX must be as light as they say.... the tires and pedals wouldn't last a week on the local loose rock, over sharp rock, over rock ledges though.:nono:
Super sweet build...enjoy it!
What cranks? can you tell me how you mounted the whole bike?
I don't understand your second question? how? :) What do you mean?
The first question: aerozine sl.
probably a translation error, i think hes asking for your build spec
ibis sl frame L
fork - manitou minute mrd abs 09
rear shock - cane creek cloud nine
wheels - ztr alpine/tune king/kong/sapim cx ray
tires - schwalbe rocket ron evo
tubes - schwalbe ultralight
brakes - formula r1 brakes/discs
stem - extralite the stem 100 mm
handlebar - ritchey superlogic low riser
headset - cane creek is 110 integrated
shifters - sram rocket
seatpost - kcnc ti pro lite
saddle - bontrager rxl
der - shimano xtr shadow/xtr
cassette - recon ti 11/34
chain - shim xtr
pedals - exustar ep-m 28 ti
crank - aerozine sl
bb - shimano xt
chainwheels - extralite octaramp 44/32 aerozine 22
jagwire cables and wires
spacers - woodman/ibis
top cap - cane creek
grips - foam/no name
Sorry for my bad English :D ; I wanted to know what other pieces you have installed on your bike to get to that weight.
Originally Posted by caravan2001
Thanks-- I just got back from my first ride and I am glad I got the Large-- The bike fits perfectly....Can't believe how well this thing tracks and climbs, not to mention how fast it goes down hill! So awesome.....Here's a pic from after the inaugural ride...We're having sunny 50's here in Portland, which is unheard of for February- woohoo!
Mine is going to look very similar, a lower kit but same links and stuff.
Maybe we can ride together and be the two amigos?
If only there was a third person with a matte clear SL...
Is the Mojo SL frame lighter than the 2010 Giant Anthem X SL?
Well, it depends. How much does an Anthem X SL frame weigh? My 2010 medium white Mojo SL frame with a RP23 shock weighs even 2450g. Hope it helps.
That would be heavier. A Giant Anthem X SL is around 2120g in medium.
I've seen Med. through XL Mojo SL's weighing in the 2200s. Maybe they are naked and yours painted?
ibis sl frame L
chain - shim xtr
crank - aerozine sl
bb - shimano xt
Ah, now I understand how you managed to make a bike so light, congratulations!:thumbsup:
I also weighed the frame M, white, with fox RP23 to about 2480 grams, but can not remember if there was also the seat binder :???:
My matt clear large Mojo SL frame is exactly 2352g incl. Fox RP23 and Ibis bolt on seat clamp (standard links, no newer Lopes one).
Yes, probably. Paint coat can add a half pound over the mate finish. Guess the Lopes link can add some weight too.
7 Attachment(s)
I thought I would share my new ride that I just put into service today. I retired my ETSX 70 and after much deliberation and test riding of many frames I have decided on the MOJO SL in white. I have included my components spec as well as some pictures.
Component spec is
Bike = MOJO SL (Large) 2010
Front Shock = 2011 FOX Talas 150
Cane Creek Head set
Rear Shock = RP23 BV
Shifters = 2010 XTR
Cables = XTR
Brakes = Formula ORO K24
Disks = 2010 XT
Wheels = 2010 Mavic CrossMax ST
Cranks = 2010 XTR
BB = 2010 XTR
Pedals = 2010 CB Candy SL
Stem = Easton EA90
Bars = Easton Monkey LiIte SL
FD = 2010 XTR
RD = 2007 XTR
Cassette = 2010 12-34 XTR
Seat post = Thompson elite
Seat = WTB Carbon Devo
grips = ODI
Chain = Sachs hollow pin PC-991
I did my first ride tonight and after a few adjustments to the drive train and some fiddling with the shock pressure I am ready to head out to the mountains. The bike feels great, climbs excellent and goes down hill much better than my ETSX ever did. This bike is going to get me into trouble I mean serious fun.
