Results 1 to 45 of 45
    boba
    Adjustable Seat Posts..Which is best?
    Hi...I have a Mojo Carbon (not SL) and would appreciate opinions on what is the best Adjustable Seat Post with Remote. I have long legs and would want one with fairly long post travel and do not want to use shims. thanks, bob, Vancouver Island.
    Reviewer/Tester
    Reputation: Rainman's Avatar
    I've been testing the Joplin [Maverick Speedball] for quite some time with very good results. It only has a limited amount of drop, [3"] so it depends on how much you need.
    The post with the biggest drop is the "Rase" post, [9"] but I don't think these are readily available yet...
    Other options are the Gravity Dropper and the AMP post, but you need to specify what sort of overall drop length you need.
    R.
    Quote Originally Posted by bobAustin
    It is inevitable ...
    Mojo0115
    I have a Maveric Speedball (now the Joplin) and like it.
    However:
    - a 3 inch drop is not enough for the terrain you ride Bob. I was regularly manually dropping my seat while riding many of the trails on Vancouver Island.
    - It needs love and a service pretty regularly.
    If my mine breaks I will certainly look at a post like the AMP with is still remote adjustable but has a 4" drop. The AMP would need shims for the mojo however, so hopefully by the time I am back in the market there will be a good post that fits without a shim.
    4" would be plenty for my needs as a 5" drop might not even fit my seat height needs. The 3" drop is enough for Colorado and Moab but the steep that the North Shore and Vancouver Island region commonly has on it's trails would like a little more.
    www.derbyrims.com
    Reputation: derby's Avatar
    My AMP (All Mountain Post) 1/4 inch remote drop post has worked flawlessly for over 1/2 year, only twice adding a couple drops of oil in the guide grooves under the neoprene dust cover to keep action perfectly easy. It has a very tiny bit of slop now, but I don't feel it when riding. I've seen on other bikes the Gravity Dropper develops a little more slop after break in, and the Rase post I saw at Interbike a year ago had much more slop when new.
    I'm 6'1, have a 33 inch inseam with bike shoes on. AMP has promised doing a 1/5 drop which should just fit my large size Mojo for me, but not the XL if I had one. The 1/4 is plenty for me and leaves 1 inch of room to clamp on a rear fender.
    It came with a Cane Creek shim and it has been quiet with no creeping lower and actually easier grip of the post using the quick release than my previous Thompson post. The AMP is flexier than the Thompson, but again not noticeable. The AMP is surprisingly nearly as light as the Thompson within an ounce I’d say, plus the remote cable weight.
    I wouldn't want an infinite adjust drop. I prefer the set 1 inch mid-drop height for consistent mid-drop pedaling reach and handling feel.
    Mojo0115
    Quote Originally Posted by derby
    I agree, infinite adjust drop is nice as an idea and decent to actually have, but the reality is that you don't really need it at all. When I drop my seat I always drop it fully down to get it out of the way.
    http://superstar.tibolts.co.uk/produ...roducts_id=153
    I was looking at one of these, 5" drop, well built and good reviews so far, cheaper too!
    The Crow
    Reputation: Iwan's Avatar
    Another Jolin user
    I'm very happy with my Joplin. I've read that the 09 ones will have 100mm drop. I've custom-cut a slap-sock to protect my post from flying mud and grime.
    There's a feeling I get
    When I look to the West
    And my spirit is crying for leaving
    MPI
    MPI is offline
    Reputation: MPI's Avatar
    Quote Originally Posted by james beaumont
    Hi!
    I have this one. 5" drop is enough. Remote lever´s tightening system is weak and mine broke during installation. I used zip ties to do the trick . I was planning to use Speedball´s remote lever but KS post lever needs more wire travel than Speedball´s lever can deliver. After all 5" drop is much useable than Maverick 3". Maverick´s or Joplin´s seat binder clamps are discrace IMO. Post has no play like others do. Just one test ride behind. I will keep you posted later.
    Greets MPI!
    Aug 2005
    it's sheer coincidence that this thread was posted... i just visited my local distributor for crank brothers and took a close look and handled the joplin (r) and tried the compression by hand etc. I'm pretty impressed with the build quality of the seatpost, and consider it much better (at least, on cosmetic terms) than the gravity dropper..
    the store owner is a long time acquaintance of mine, and he did say to me that if i'm having concerns about the post getting damaged etc, it's better not to buy it - he clarified that he told me honestly because i've been to his place for years (though much less frequently, because i hardly ride these days).
    the thing about the gravity dropper i don't like, is that it appears butt-ugly, with a m2racer-resembling kind of saddleclamp, which looks kind of flimsy to me. (i said, "looks", from what i see visually)
    the other consideration is that the joplin is a hydraulic system, which the gravity dropper is a magnetic system.
    any other viewpoints that any of you thought through before you bought either post? thanks.
    HIKE!
    Reputation: sparrow's Avatar
    Of the RASH (Remote Adjustable Seat Height) posts I've used Gravity Dropper's standard model, the Turbo, and the Descender; the All Mountain Post, and the Maverick/Crank Brother's Speedball/Joplin.
    First off, the remote switch is key, don't bother with the "reach between the legs" activation, get the bar mounted remote!
    The Gravity Dropper Turbo has proven to be the most solid/dependable and functional model I've used. My favorite is just a 4" drop, no intermediate, great for my local riding (Black Hills of SD, and trips to Wyo, Colorado, Moab, etc) as it really adds flow to any ride.
    The Turbo has a solid mechanical activation, with a very positive "click" to lower and instant "up" with a flick of the switch, no need to give it a slight "butt tap" to bring back up. The Maverick/Crank Bros has the "instant up" but it is far more vague, not as quick or snappy, and you never really know if you got it all the way back up to max height.
    The infinite adjust of the Maverick/CrankBros is good on paper, but not so good in the real world.
    Get a Gravity Dropper Turbo, then swap out the stock seat rail clamp assembly for a Thomson!
    www.derbyrims.com
    Quote Originally Posted by zzsean
    The 1 inch drop is what I spend the most time in.
    The 4 inch drop is great for getting the seat completely out of the way for sketchy downhills and drops where there is very little pedaling. Pedaling is weak and weight rearward in the 4 inch unless standing.
    I reserve full height mainly for longer easier climbs and street. The 1 inch drop still has very good seated pedaling power for climbing and handling is much better than all the way up.
    The AMP remote is mechanically very solid and smooth with a strong but easy coil spring to raise height and a mechanically sprung height detent. It never hangs up going up or down, no hesitation. It appears to be made by CNC machine and is anodized, and has the finish quality of a Thompson post.
    boba
    Good Advice, thanks.
    Thanks for the input.
    I think I shall wait for a seatpost to be available in Canada that has about 5 inches of travel. Sean who commented above, visited us this summer and pointed out that he had to adjust his post position for the downhills as the 3inches of travel were not enough.
    That was my worry and I'll wait for a longer travel post to come out. The post that the fellows in Scotland and Finland suggested, sounds great and maybe they will be available along with service/parts in North America at some time.
    thanks bob.
    how much seatpost do I need to use these?
    I've got a relatively short seatpost, about 7 inches from collar to rails.
    Is this enough to use these adjustable models?
    Nov 2006
    Well I just received my Joplin post. I had been trying to decide what adjustable post to go with and I opted for the Joplin R. Ultimately I think it will work out well for my needs.
    Overall I am very happy with the quality of the post and remote kit. Only time will tell how reliable it will be.
    So as an extra precaution and with winter coming on I scavenged a fork boot off an old fork I had to help keep mud and grit off of the slider. I also used a little hose guide to help keep the cable housing from flapping around.
    I will be giving it its first flogging tomorrow up at Annadel, hopefully it was worth it!
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    Quote Originally Posted by sessionrider
    .... hopefully it was worth it!
    Your next post about it will be:
    "It is totally worth it. Everyone should have one of these!"
    I like the positive clicking sound of the GD myself, but just being able to get rid of the seat is key to really enjoying a downhill.
    What is the weight on these?
    First of all I am a bit of a recovering weight wennie so please forgive me. I received my Mojo SL a couple months ago and am completely in love with it. When I built mine up I definitely went the light weight racer kind of build. Not stupid race only light, but definitely as light as I could get with 100 percent durability/repairability in mind.
    Coming from a single speed hardtail I had NO idea what kind of terrain I would start to take on with this bike. Now that I am getting an idea, I can finally see the reason for a adjustable seat post. (yes just about everyone on this forum told me I would want one and should just get it right away, but I am not always the smartest, best listening rider in the world)
    I was looking at the AMP, like the mechanical mechanism and the two indent design, but was wondering what the various weights of the posts. I looked around for them and couldn't find them, no even asking this question probably in validates the point of an adjustable seatpost, but I just have to ask.
    Thanks for any info.
    Kevin
    Nov 2006
    The AMP post was the other adjustable height seatposts I was considering. They seem to have very good reviews and offer custom drops and lengths to suit anyone's particular preferences.
    The things that ultimately led me away from the AMP post was the cost (I saw somewhere that they were around $350), having to shim the post, and the seemingly unknown wait time for one.
    Now however, they are back up on the website and the MSRP seems very competitive $275-$299 depending on the drop. They definitely look nice and especially for those riders who want a larger drop than either the Joplin or GD provide. The posts they are stocking now have up to a 5" drop. Check em out www.precisioncyclingcomponents.com!
    My Gravity Dropper (350mm, 3 inch) weights 560 grams, including remote control and shim to adapt it to a seatpost diameter different from 27.2.
    Reviewer/Tester
    My Joplin with remote and cable weighs 1.21lb
    R.
    So it will add about 1 pound, and make the downhills about 50 pounds more fun. hmmm, guess I know what I will be saving for this winter.
    Thanks,
    So I have a dumb question about the AMP. The sizing chart for the 4" reads as follows:
    4" drop 390mm: Minimum post exposed ~ 7.25" - Maximum ~ 12.5" post exposed
    So if I'm reading this right, the post is 7.25" when dropped and 12.5" when extended? If so, that's a long post. My max extension is 7.5" on my normal post, and I don't exactly have short legs.
    Tantrumcycles #1
    Reputation: Gunnar Westholm's Avatar
    Quote Originally Posted by MPI
    Hi!
    Greets MPI!
    Does Pure Racing have a website?
    Oo, thats a nice and neat mod
    Most adjustable seatpost in the market is now around 400-500 grams ++.
    I do hope in the future the weight of adjustable seatpost will become smaller, hopefully around 200-300
    07 Giant Anthem 2 (Int'l Edition) | omartan.co.cc
    Im a MOJO Fanboy
    Reputation: getbusyliving's Avatar
    Quote Originally Posted by Hummbird
    Kevin
    Kevin---I did the research on the three most popular posts a while ago and here are the weights (with remotes):
    GravityDropper 450g
    AMP 480g
    Joplin 534g
    I went for the 4" / 1" drop GravityDropper, although not because of the weight---because of the simplicity and function of the mechanism. The GD Turbo is mechanical and has quick, positive action. The Joplin has far superior aesthetics, so it was hard to pass it up, but I have seen a few reports of the hydraulic mechanism failing, and like others have mentioned, I don't like the infinite height adjustment---I like to know exactly where my my seat will be (either full up, 1" down, or 4" down).
    Been using the GD for about a year, and it is fantastic. A few months ago I crashed and broke the cable, so decided to just send the whole post in to GD for an overhaul, and they only charged $12, and turned it around in one day! You call and the owner answers the phone...great CS. Just wish the GD wasn't so ugly...so I may add a DIY neoprene sock more like the AMP to replace the ugly accordian boot.
    Quote Originally Posted by sehsuan
    Actually, I believe only the standard GD has a magnetic switch. The GD Turbo uses a simpler pull-pin mechanism and has faster/better/simpler switch action. I've used both and the Turbo has better function, although the entry point of the cable into the post on the Turbo is a somewhat funky design, as cable can kink if something impacts it: http://www.gravitydropper.com/wherephone.html (scroll down).
    Quote Originally Posted by Gunnar Westholm
    Yes it does. http://www.kindshock.com.cn/en/produ...3&fid2=&id=668
    I bought one of these for my Mojo SL to save the carbon round the seat clamp.
    Having come off a bike which had a NZ made 'Q-Shifter' on it, I missed it.
    Am super impressed with the KS900i I have bought, it has five inches of travel which I use constantly, Have just spent four eight hour rides on it with no problems at all.
    Have owned it for about a month and a half and the only thing i would recommend is a bit of loctite on the clamp bolt, as it had worked loose a little.
    Nov 2007
    Quote Originally Posted by Arty50
    Arty, no. What AMP is saying is that your current seatpost has to have at least 7.25" of post showing to use the 4" drop post. If your current extension is 7.5" you're in good shape.
    Aug 2005
    Hope I didn't read wrongly about 4 inches, on a future Joplin? If it's 27.2, it sure makes the current one sound a heck lot stiffer...
    http://www.bikemagic.com/news/article/mps/uan/6532
    Quote Originally Posted by nomadcrazy
    UPDATE TO THIS NOTE:
    Post is on way back to supplier, it is stuck down and no amount of pulling will bring it back to full height, this also means i cannot undo the seal cover to see if i can fix it. Will post another reply when i know how the company treats warranties etc.
    The Crow
    I've sold my Joplin and bought a KS i900 Cobra for three reasons:
    1. No sideways play. None
    2. Three ince drop wasn't enough
    3. The seatclamp is not the best design.
    Other than that it worked 100% for many happy miles. The KS is going strong and a worth while upgrade.
    No dabs.
    Reputation: Robo SD's Avatar
    Quote Originally Posted by Iwan
    I'm looking forward to using mine (Fezzari version), but the one I ordered didn't work. It took a huge amount of force to drop the post, way more than body weight - and no, it wasn't cinched too tight by the seat collar. After a call to Fezzari, who rerouted me to a tech guy at KS, I had to send it back to have it taken apart to be looked at, rebuilt, etc. Still waiting for it a week and a half later.
    Looking at it I wasn't impressed. Seems there's much that can be done to lighten this up, and the pieces are not elegantly designed or sized correctly. Does that red screw-on cap in the middle of the post really need to be about an inch tall?
    The remote seemed super flimsy, but I'll have to get a working post before I can say for sure how well it works.
    But I do look forward to the 5 inch drop rather than the 3 on the Speedball I've got. And I like that the seat won't wiggle (though I never notice it while riding), and the seat won't rise when pulling it when in a down position.
    Iwan - sounds like you had a problem with seat tilting on the Joplin? You know you needed to grease the screw on that and tighten it HARD, right? A dry screw cannot tighten enough. From what I've read, this seems to be the solution to the problem nearly every time.
    I have a Joplin, live in Scotland and subject my bike to the worst of UK riding conditions.
    I run a lizard skin on mine to avoid the worst of the muck.
    Post was fine for approx 9 months then it developed a suspension action.
    In it went to the LBS for a service...easy I thought. 2 weeks and they haven't managed to fix it. Off for warranty now so I'll let you know.
    I would like to try the KS. Not esp bothered about having more than 3" of drop but I would like to see what the KS is like without the side to side play.
    I am only marginally aware of the play whilst riding but if it is possible to get one without without a performance drop that would be nice.
    AMP not available in the UK and Gravity droppers look like they have been made in a shed, so thats not going on my Mojo. Gotta have standards, right?
    I wonder how KS solve the side to side play problem. Its a pity CB didn't bother to fix this problem which existed even when it is called Maverick Speedball
    Im a MOJO Fanboy
    specialized post?
    The new Specialized post was well-propagandized by one mag (forget which). Anyone have any experience with this one?
    shootout
    Another of the mags did a somewhat useless spread on five such seatposts, which gave little in the way of opinions.
    A thorough side by side thrashing of all of these posts would be very very welcome. Anyone know how mtbr decides on what it tests, and/or how to suggest this for a future pro review?
    www.derbyrims.com
    Quote Originally Posted by getbusyliving
    ...Just wish the GD wasn't so ugly...so I may add a DIY neoprene sock more like the AMP to replace the ugly accordian boot.
    AMp now sells the neoprene boot on line for $5. http://www.precisioncyclingcomponents.com/Parts.htm
    Also, I finally broke a small AMP post part, a seat mounting piece, and AMP's customer service was over the top! Dan replied to my weekend email within hours and sent out the replacement with spares the next morning for free even although I offered to pay for what I consider normal wear and possible over tightening of the seat by me.
    AMP does not advertize.
    No dabs.
    derby,
    How long is the shim that AMP sends out with the post? 4 inches or so? I decided not to go with the AMP at the last minute just because the shop I bought my Mojo at had a Speedball sitting there calling my name - and I never was crazy about the shim. Any concerns/issues with it?
    www.derbyrims.com
    Quote Originally Posted by mikuteit
    derby,
    The shim is 4 inches, or slighlty longer, as long as the Mojo seat post insert. It's a very high quality Cane Creek brand shim. I have no creaking or slipping problems with the shimmed AMP (unlike my Thompson post). I'm very satisfied with the AMP post and now my experience with AMP customer service.
    flow where ever you go
    Reputation: noshortcuts's Avatar
    Quote Originally Posted by mikemikemike
    there is a thread on these (Specialized Command Post) and it looks like many people are having problems
    "I must not be crazy because I'm seriously questioning my sanity"
    AMP all the way...I've been riding one for over two years now and I still love it. Like anybody with any kind of adjustable post, I can't imagine riding without it. I have the 1" and 4" dropper. I use the 1" all the time at Bootleg Canyon, I think all bikes should come with a standard 1" drop post, even for xc bikes. You get the best of both worlds, you can pedal at full leg extension on all the climbs and then drop 1" inch for most everything else and still pedal relatively well. The 4" is always there for the big stuff, but forget trying to pedal anything with it dropped all the way down. I probably use this post atleast 20-30 times every ride at Bootleg. It becomes second nature with the handlebar control. The workmanship is great and I have only ever added grease a couple of times to it. It does wiggle a little bit, but it's not noticeable while riding...and that's after two years of use and probably 1500 - 2000 miles on it!
    No dabs.
    Fezzari / KS follow-up
    So I get my Fezzari Drop-In post back, which I'd sent to Rick at KS to fix. It wouldn't drop without a huge amount of pressure. Post still has exact same problem. Only now, it also raises from its lowered position on its own and also can easily be pulled up - like the Speedball or Joplin. Perhaps too much air pressure? Surely that would've been looked at, no? Well, I can't take the thing apart to check, as the poor design makes it too difficult. The spanner wrench piece is too tight for me to remove without thrashing the thing.
    So, it's being returned - which I again have to pay to ship. Needless to say, I'm very disappointed. They're great guys at both KS and Fezzari, but in my opinion, this is a cheap POS.
    I may look into an AMP in the future, but I think I'll just be happy with my Speedball for now. Maybe I'll just wait for next year's Joplin which will supposedly go to 100mm drop.
    Well I would be more impressed if CB can made the Joplin as the worlds first 0 flex adjustable seatpost
    Im a MOJO Fanboy
    I'm feeling better about my speedball all the time - the newer models just don't seem to offer much of an advantage - if any. It looks like the Amp may be a possibility...
    The Crow
    09 Joplin...
    100mm drop & upgraded seatclamp only available on 27.2 model. Stupid.
    Hey Bob, I know this is a little off topic but how are the trails up there in the Comox Valley? I'm down a ways in P.A. and was wondering if it's worth a trip to Cumberland yet.
