Results 1 to 39 of 39
    650b up front/26" rear -- ROCKS AND ROLLS!
    After 3.5 years of riding my Mojo, had no idea the design could be perfected... Onto my 2010 32-Talas-150 FIT/RLC/QR15 went a Stan's ZTR 355 650b wheel (w/Nevegal 27.5" x 2.1" DTC with Stan's solution) and immediately knew I'd never go back to 26" on front. I'll definitely keep the 26" wheel on rear, as I love the slight increase in rake angle and rearward saddle position, not to mention faster acceleration/less mass. As far as mass increase on front - the 650b wheel weighs the same as my 26" ZTR 355 wheel - maybe the newer American Classic 15QR hub weighs less, not sure - and the Nevegal tire adds (an unnoticeable) 80 grams more, total.
    I love the way this set-up rolls over rocks & roots, up and downhill, here on the endless, technical singletrack of SW NH. As well, the increase in rake angle makes it easier to manual, and the bottom bracket is slightly higher. I'd like to calculate how much more rubber from my Nevegal is contacting the ground around turns -- that must be significant -- another fraction of a knob? - my physics is too far gone - maybe someone has done this?
    Ibis Mojo (small)
    GravityDropper Turbo 2"/4" adjustable seatpost
    Formula Oro brakes
    XTR drivetrain and shifters
    2010 32-Talas-150 FIT/RLC/QR15 fork
    2007 RP23 shock (Pushed w/high volume)
    Stan's ZTR 355 650b (front)/26" (rear)
    Kenda Nevegal 27.5 / 26 x 2.1 conventional, w/Stan's solution
    etc!
    More Torque
    Reputation: Diesel~'s Avatar
    Glad it is working out for you.
    Do you have any concern that the tire will jam under the crown during a hard impact?
    -D
    impossible.
    More Torque
    Quote Originally Posted by rshalit
    impossible.
    Impossible for you to be concerned about it, or impossible for it to happen?
    www.derbyrims.com
    Reputation: derby's Avatar
    The diameter of a 650b tire is just under 4% greater than the same size 26" tire. The larger volume 650b allows lower tire pressure. I'm not sure of the math, but the tire patch is probably 4% bigger in every direction from the center of the patch plus whatever the lower tire pressure can gain. The ability to lean harder when braking and cornering on the 650b adds more to the traction gain. The subjective gain in traction feel is far greater than just 4%, it feel more like 20% gain, not to mention the easier rolling.
    impossible to happen - there's plenty of clearance and the wheel is fixed to axle at any rate.
    www.derbyrims.com
    impossible.
    If you let the air out of a Fox Float or Talas 140 or 150mm travel fork then a 650b sized 2.3 or greater will rub the crown. In my 3 years of closely following and participating in 650b experimentation I've never seen a report of someone actually bottoming and rubbing the tire while riding of any fork that clears the arch including Fox forks. Riders complain that they cannot access the bottom inch of travel of a Fox Float or Talas 140 or 150mm travel fork. There are modifications that can be done by a pro turner, or ambitious home mechanic to gain more usable bottom travel for these forks.
    I truly don't understand - your first two sentences contradict, and the first, wrt letting the air out of the fork, why on Earth would someone do that and then ride around ?? Am I missing something? - the fork leg tubes are rigid to the axle, not to crown and stanchions, so how could a tire that has enough clearance, like mine, at more than a centimeter from tire to legs' brace, ever possibly rub anything?? Rubbing should I imagine depend strictly on the knobs, and why would someone run tires that rub - it would be obvious as soon as the tire was mounted and the wheel was put into the dropouts. While I usually run 2.1, I am certain a Nevegal 2.3 isn't going to touch anything. Perhaps you mean lateral fluctuation in the rim while cornering? I suppose there are some really flimsy rims with loose hubs out there that with a really fat 2.3 could rub in a turn.
    As to your third sentence, I have no trouble getting full travel from my fork - an inch is 2.54 cm - why would a gain in axle height of 3/4 inch (the radius) cause such a dramatic decrease in travel ? I have read more than one report in MTBR forums of people with 26" wheels not getting full travel with their Floats; I also read that, before FIT, nobody could get "full travel" due I believe to a bumper stop. I certainly never could get that last cm with my 2007 32 Float 140 RLC on my 26.
    What type of "participating in 650b experimentation" did you take part in? Are there reports and data available?
    Jan 2005
    What you guys may be missing is the requirement for more fork offset to corrospond to the larger tire. For nowm the best way to get there ( IMHO) is to run a 29"/100 mm fork and enjoy the benefits of a 42 mm offset vs. 38 mm offset of a 26" fork. The corrosponding A/C height is the same as a 140 mm fork/26" wheel. Best of both worlds, while eliminating the tire crown clearance issue. The better tracking of the 27" wheel minimizes the 40 mm of travel that is lost, I feel.
    Reputation: BitterDave's Avatar
    Nov 2007
    Quote Originally Posted by derby
    The area of the tire contact patch is a function of the PSI of the tire, not its size. The size of the tire will affect the shape of the patch, but not the area. Of coarse this is all in theory and assuming that you are running a slick. Things change once you start introducing knobs on the tire.
    Quote Originally Posted by buggymancan
    by "A/C" you mean axle/crown? Are you saying there's more trail and therefore the 27.5 front/26 rear doesn't handle as well? I really don't notice this for some reason - it corners quite well - should the increase in trail put more rubber in contact with ground perhaps compensating for increase trail? Isn't it a bit more complex than simply:
    trail = [(wheel radius) x Cos(head angle)] - rake/sin(head angle)
    since geometry of smaller rear wheel sets saddle back, etc.?
    "theory guides, experiment decides" -- as a chemistry professor, I often use this saying with students in the lab... it's difficult to believe a 29" fork would give me the same feel, and besides, would it stress the head tube too much? I do 1 - 3 foot drops and lots of babyheads, roots, etc.
    [QUOTE=rshalit]After 3.5 years of riding my Mojo, had no idea the design could be perfected... Onto my 2010 32-Talas-150 FIT/RLC/QR15 went a Stan's ZTR 355 650b wheel (w/Nevegal 27.5" x 2.1" DTC with Stan's solution) and immediately knew I'd never go back to 26" on front. I'll definitely keep the 26" wheel on rear, as I love the slight increase in rake angle and rearward saddle position, not to mention faster acceleration/less mass. As far as mass increase on front - the 650b wheel weighs the same as my 26" ZTR 355 wheel - maybe the newer American Classic 15QR hub weighs less, not sure - and the Nevegal tire adds (an unnoticeable) 80 grams more, total.
    To come up with your handling opinion with the larger frnt wheel, are you riding tech single track with a 150 setting or dropping to a 130 setting on your Talas?
    The reason I ask is that a 150 with a 650B is very slack and slow handling I would imagine
    Mojo
    I'm not dropping to 130 mm (except on some long, steep climbs) - the handling is superb at 150 ! This thing about increasing "trail" and sluggish handling with 650b - there are just too many variables - there isn't a multi-variable formula that can simulate the real world of mountain biking - besides rake, wheel diameters front and rear, etc., there's rider mass and position, frame size & geometry (ie, I ride a Small Mojo), rear wheel and tire size, handlebar length & height, stem length, not to mention riding conditions & styles - drops, babyheads, manualing... you just have to get out and ride and decide. It took one ride to the local summit and down to know the 650b front/26 rear setup was for me -- the lower mass and better acceleration with 26 in rear and the seat back farther (my height puts me between a medium and Small Mojo frame size, and Gravitydropper doesn't make a set-back seatpost -- I absolutely can no longer tolerate the thought of not being able to lower and raise my seat on the fly so I have to have this; I have btw tried a Medium 26/26 Mojo and it didn't handle as well as the Small on the technical singletrack) and the rake angle with this setup is very sweet - as I said before, it manuals better. The only possible disadvantage I notice with 650b is going up over one very technical section, crawling (a necessity due to extreme technical entry just before this part), navigating simultaneously up and around a turn and over roots & rocks and preparing to turn quickly again to roll down babyheads in opposite direction, all through narrow clevis, & all this in about 10 or 12 feet distance, that I found myself having to noticeably, consciously, turn handlebars a bit more heavily in order to clean this section. I'm still not completely convinced it's the 650b - this is a very technical section which I was used to cleaning only about 80% of the time anyway (I know only two other people that have ever cleaned this section.) Perhaps I should lower the travel to 130 for this short section, but I'd have to do it far in advance as it would be unsafe to take left hand off the grip through there. (I'm waiting for blinkable/thinkable Talas and lockout controls... actually I'd be happy if Fox would make a remote lockout for this fork! Hmmm... if both the Talas AND lockout were remotely controllable, I wouldn't have room for thumb-reaches on my bars for both of those levers AND the Gravitydropper Turbo remote ...)
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    What you could be missing is teeth.
    What people are trying to get is:
    Have you tried letting all the air out of your fork and fully compressing it to see if at bottom out the tire can hit the upper crown? You don't do this while riding, you do it in the comfort of your garage. You'd hate to find out the hard way that the tire rubs right when you land a jump, throwing you over the bars and breaking teeth.
    Derby says he has yet to see this happen to any 650b bike, but says a 2.3 could hit. And his experiment is part of some major government 650b cover-up. It didn't happen, don't ask questions or "they" will silence you.
    So, let all the air out of your fork, put weight on the handlebars until it bottoms, and see if the tire rubs the crown. Make a note of it, and put air back in your fork. Then report back here your findings.
    kthxbi
    T.W.O.
    Reputation: mimi1885's Avatar
    Derby, Do you think Ibis would release an official version of 650b, and do you think that geometry change needed? What would you change.
    I've been happy with my 650b front so far and have not done the full conversion yet due to a couple of things. 1) slight reduction on travel, not a big deal but it means I have to send the shock in and I just had it pushed.
    2) I like the 2.3 Neomoto I think it's an awesome tire, I don't want to put a smaller tire in the rear to take away traction I need.
    meh
    Reputation: clewttu's Avatar
    why would you need to reduce travel?
    www.derbyrims.com
    Quote Originally Posted by mimi1885
    Don't hold your breath for an official 650b Ibis anytime in the next few years, unless they do a metal 650b bike. The HD easily clears 2.3 x 650b now with no shock mod, and so do all the 160mm travel forks. The HD's BB goes over 14 inches topped out with 650b as it does with DH tires on 26" rims, but with the deeper sag the HD should use its about right for climbing rough trail without frequent pedal strikes.
    I should start up a RP23 bottom travel limit service. It appears to be very easy to do from the pictures I've seen. I'll try to find an RP23 to test with (I run a coil shock).
    I really like the Neo-moto tires a lot too. I wish the casing was a bit tougher against sharp rock punctures, but no heavier if that is possible.
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    Holy Smokes...
    ...some people in this thread (face palm smiley here)
    rshalit, nice work. Been tempted to try such a mod with my 26" bike/fork as well. Nice to see it's working for you.
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    On wuss patrol
    Quote Originally Posted by clewttu
    Likely to get weight forward a bit to keep the front from lifting too much when climbing. That's what u-turn forks offer.
    T.W.O.
    Thanks Derby, I might just go for the HD as a replacement for my Mojo build and build it 650b since the Fox, and RS fork would clear the tire anyways. The frame weight increase is less than half a pound.
    Now I wish KP makes 2.5 Neo Moto,lol
    meh
    Quote Originally Posted by Malibu412
    was under the impression he was talking about the shock, not the fork
    On wuss patrol
    Talking about "trail" and "sluggish handling" = fork, I believe. Longer post, though so maybe I missed something.
    On a related subject..... Who's got black 650b Blunts in stock???? Everybody that I can find is out of stock....getting tired of waiting so thought I'd go ahead with a 355, but now Stan's is out too.... Whhaaaaaaaaa.... I wanna run 650b!!!!! Anybody got any suggestions for where I can find the above, or alternatives that are wide-ish & light-ish for a 170 lb rider hitting rocky trails fast and hard 5 days a week w/ 2.35 nevegal on front at 24 psi?
    meh
    this makes me think hes talking shock
    T.W.O.
    Yes shock
    Sorry your first comment, I was not sure if it was to my comment or others.
    yes converting the rear Derby put about a quarter thin spacer on the shock that reduce just a tad of the travel, which reduce or eliminate the chance of the tire bottom out and make contact to the back of the seat post.
    www.derbyrims.com
    The larger 650b rear tires can rub the seat tube at bottom travel of the Mojo C and SL if the shock's bottom travel is not limited with a home made thin shim or PUSH big hit bumper limiting bottom travel. (The HD clears 650b no problem with stock shock, I've tested this with my rear 650b and shock deflated on an HD).
    Regarding fork offset for 650b, the 26" forks have some variation in offset (rake), there is no set standard, offset is usually between 35 to 38mm. Going from 26" to 650b front and rear there is just under 4% increase in steering trail, about 3 to 4mm. The isolated difference in steering response going to 650b front and rear is not noticeable, but the overall factors of rolling, increased traction, and 1/2 inch higher ride height are what is noticeable and very favorable to about 95% of those who try full conversion of a 26 incher to 650b.
    Front only 650b using the same fork is very noticeable in slacker steering response, especially low speed climbing where there is increased flop, similar to simply extending fork travel 20mm. Font-only 650b raises just the front of the bike and slacks the head and seat angles about 1/2 degree which adds another 5% and 5mm steering trail, netting about 9% and 9mm increase trail for 650b front only.
    When converting to front-only 650b (26" rear), re-balancing the rider's weight distribution and sag to prior familiarity reduces most of the steering feel change. This can be done easily by bumping the seat forward about 1/4 inch and lowering your bars the same 1/2 inch amount as the front axle is raised by the larger 650b front wheel. By far, most riders report in the 650b forum they like the tradeoffs of front-only 650b after loosing some steering quickness, but gaining cornering traction, smoother bump hits, and easier rolling over obstacles.
    BTW, I've been experimenting with 650b front-only and front and rear conversion with my Mojo for almost 2.5 years. I think its a big advantage for taller or heavier riders, maybe not so much advantage for very strong riders especially who usually jump over rather than roll over obstacles. Lopes won't even consider 650b.... yet! But I bet he'd gain another advantage with 650b in increased cornering grip for DS and the A-Line DH.
    T.W.O.
    I found that on the technical climb with the 650b front, it's easier to carry more momentum and roll over the obstacles. Manual is easier to do as well despite the increase weight of the front wheel.
    Steep climb never bother me that much because regardless I still have to move to the nose of the saddle and weight the front wheel. I just simply ignore the flopping trade and just focus on putting weight over the front to add bite. I love the set up and seriously considering the HD to make a full 650b conversion. Too bad I tried it on the Tranny and it would not fit the 650b on the rear. It would have been my instant favorite HT.
    So what forks are people running a 650B front wheel with? I notice Fox has been mentioned, but what about Rockshock or Manitou?
    www.derbyrims.com
    Quote Originally Posted by dreednya
    Check the sticky in the 650b forum. Many Rockshock and Manitou forks clear also.
    Cheers Derby
    Nevegal 2.1 x 27.5 w/2010 32-Talas 150 RLC - reporting back!
    yikes do I feel stupid!... -- here's my report on letting all the air out of my 2010 32-Talas 150 RLC QR15 with a conventional Kenda Nevegal 27.5 x 2.1 DTC on Stan's 650b ZTR/355, no tube, and pushing crown all the way down to bottom: the clearance was exactly one thin dime - this tire has been ridden maybe 30-35 hours off-road only on 95% hardpack dirt, and shows almost no wear to knobs.
    I though maybe Derby might have been with a particular company testing out 650b with different tires/forks - I hadn't been following this thread at all, until now.
    Sure is nice to know that I won't be missing teeth due to knobs catching - also the first time I've let all the air out & found out that I do indeed bottomed out on occasion (many thanks for enlightening me, Dan!)
    Quote Originally Posted by dan51
    kthxbi
    update to question re lowering Talas-150 for technical climbing
    wrt my previous description, and with more experimentation, I do find that for technical climbing, lowering the 2010-32-Talas-150-RLC down to 130 mm definitely helps (note that I have 650b on front only.) Thanks for asking - it might have taken me longer to figure this out -- I need all the help I can get! Anyway and otherwise, I love this set up!
    Quote Originally Posted by Mojo Man
    Mojo
    lowering bars quest
    (did you mean "3/4 inch amount...front axle is raised" or is it only 1/2 inch due to rake change?)
    anyway, do you think that the effect of lowering Talas 150 to 130 for tech. climbing achieves the same as lowering bars 1/2 inch?
    thanks for all of your input Derby!
    www.derbyrims.com
    The axle is raised 1/2 inch going from so-called "26" inch to 650b using the same size tire, such as 26x2.1 to 650bx2.1 size tires. Measure your 26 inch rear wheel diameter it is probably very close to 1 inch shorter than your 650b front, not 1.5 inches.
    Lower the Talas 20mm after replacing a 26 inch wheel with 650b removes all the increase in steering trail simply going to 650b front only, but lowers the bars about 3/8 inch lower than the 650b raised the fork crown and bars, so your weight is further forward and weighting the front wheel more than before with the 26 inch wheel and 20mm higher travel.
    We each have to experiment with fit position after converting a 26'er to 650b. It's almost like a totally new bike. Front-only 650b is a more exaggerated change in fit and handling feel than going to 650b front and rear.
    Hope that's not too confusing. I appreciate your courage in experimenting with 650b conversion and finding improvement in the Mojo ride. Sounds like lowering to 130mm travel with 650b front-only climbs well for you. Lowering the bars 1/2 inch is suggested more for converting fixed travel forks.
    I normally don't comment on 650b in the Ibis forum unless directly asked or correcting errors about 650b geometry and such. There's much more interest and good suggestions to be found in the 650b forum.
    Derby, I am converting my Mojo SL to full 650b. I was trying to run the WTB 650b 2.2 Wolverine on the rear and there is not enough clearance. Here is the thread link with pics.
    http://forums.mtbr.com/showthread.ph...=1#post7147383
    I think you are running the 2.35 Neo-Moto on the rear. How is the clearance?
    Thanks.
    www.derbyrims.com
    Quote Originally Posted by lml427
    Thanks.
    Bummer. I wanted to try those tires too. Some of WTB tires are very tall for their width.
    The Kenda Nevegal 650b x 2.35 also appears too tall for the Mojo rear. The Pacenti Neo-Moto 2.3 is a short tire for it's measured 2.3 inch width at the widest edges of the tread and a new Neo 2.3 clears the stays by 4mm. As they age they stretch in volume a little and never gain much more clearance. But it has been enough in muddy conditions. They have rubbed less than 1 mm into the finish inside the stay yoke at the tread's side edges over the 2 years I've run them, mostly done by the grinding of mud packed tires I think.
    I had to shim my shock bottom travel 3 or 4mm for new Neo 2.3's to clear the seat tube. It's easy to do using some plastic bottle material cut into split flat washers using scissors, here's a link to instructions I posted in the 650b forum:
    650b shock bottom-out shim for seat tube clearance
    650b front/26 rear - update - 2011 32-150 Talas w/2.35 Nevegal & question
    2011 Kashima Talas 32/150 very nice - this replaced my 2010 32/150 Talas. Kashima & 2-step (120/150) I like. Fork feels more responsive although I don't know if it's the Kashima coating or some internal valving tweak. Low speed compression dial doesn't move as easily when locking out lever is rotated.
    But discovered, with new 2.35 x 650b Nevegal, that even though when I forced all air out of fork and found a space of US quarter's thickness (approx 2 mm) between crown bottom and center knobs, that when I actually bottom out on a jump I hear the knobs rub - not loud, not enough to notice any slowing down or anything like that at all, and the knobs don't even appear to have rubbed, but the sound was, at first, a bit unnerving (of course by the time the rubbing sound registered in my brain I was long past landing the jump)- now that I realize it's not affecting performance I'm not worried about going over bars, etc. But it seems odd that while I thought I'd squeezed every molecule of air out of fork, and measured, and found the O-ring (Fox is finally putting these on fork stanchions for the first time that I can recall) to come to within 3 mm from top of crown, which measured, btw, a full 150 mm of travel, and that on bottoming out while riding (jump) the same exact full-travel of 150 mm was noticed - what is then causing the knobs to rub? I mean did the wheel (Stan's ztr355 650b) deform (seems unlikely since deformity would be horizontal), or is there a rubber bumper in the fork that deforms a couple mm on bottom-out?
    www.derbyrims.com
    ... or is there a rubber bumper in the fork that deforms a couple mm on bottom-out?
    Most likely there's small bumpers or o-rings as bumpers inside to prevent metal to metal bottoming which are crushing further when riding and bottoming. When you service the fork and remove the lowers it would be safer to add 3-4mm thick washers under the bumpers. And/or increase the oil volume a few CC's if possible in the air chamber to ramp up bottom out resistance slightly.
    I have no experience with servicing a Talas, so these are just suggestions what to look for when opening up the fork.
    650b conversion of 26 inch frames and forks is experimental. Be careful!
    it's a FIT cartridge system so I'm not messing with it. I've had the 650b since April w/o problems and love it.
