Results 1 to 2 of 2
    2x10 XTR FD on a SL?
    I'm planning on going with a XTR 38/26 crank on my SL. But the Ibis book says that the only compatible FD is the Shimano SLX (M986L6) 2x9 down swing dual pull.
    I was wondering if I could instead use the Shimano XTR FD-M986-D Down-Swing Front Derailleur for Direct Mount 2x10-speed and the Direct Mount Front Derailleur Adapter from Ibis???
    Has anyone done this??
    Reputation: somemechanic's Avatar
    Jun 2010
    the direct mount adapter should work. you can always call ibis too!
