Results 1 to 9 of 9
    2x10 vs 3x10 on Mojo HD
    I have been running a 2X10 28T/40T along with a 11T/36T Cassette. This is somewhat painful to climb on at my level. I got me some 38/26 Chainrings to use with my 2X10 cranks but read somewhere this was not compatible. Question is tho, why would the 38/26 not work but the 3X10 appears to be compatible and has a 42/32/24 chainring? Whats the best most affordable way to go to an easier climbing gear?
    I have a 3x10 and a 2X10 Crankset, just need to figure out what works. The option of the 24T Granny is what I'm shooting for.
    What matters is the bold circle diameter (BCD) = the distance between the bolts that bolt on the chain rings.
    What crank do you have? SRAM sells these 24/38 conversion kits:
    SRAM x 9 GXP Spider and 10sp 24 38 Guard | eBay
    Correct number of bikes: n+1 bikes
    Correct body weight: m-10 pounds
    I have shimano XT.
    I'm more leaning toward using the 3x10 ditch the large ring and replace with a bashguard in hopes to be able to use 34middle And 22 small.
    Anyone running this setup?
    [put something cool here]
    Oct 2011
    I'm even fine with my XT 2x10; rear 11/36, front 38/24
    So I wonder why Ibis says the 38/26 2x10 is incompatible
    Oct 2011
    We the people ...
    I'm not too much into the technical details of chain line etc. I asked the LBS for this setup (for the same reasons you mentioned) and they built it.
    Oct 2010
    I run a 3x10 with large ring removed at 33, 22. SRAM. I love my granny,
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    I run XTR triple, with 24/36 rings and the large ring ground down as a bash.
    Rings shown in the picture are 24/32, I have since gone to 24/36.
  1. Mojo SL 2x10 drivetrain help please!
    By ludwig1 in forum Ibis
    Last Post: 03-30-2013, 07:05 AM
  2. Looking for the best deal on a XT-XTR 3X10 OR 2X10 for Mojo SLR
    By mazspeed in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-05-2013, 08:56 PM
  3. xtr front mech for 2x10 on mojo hd help
    By stejekyll in forum Ibis
    Last Post: 01-30-2013, 10:57 PM
  4. X9 2x10 does not work on Mojo HD?
    By circlesuponcircles in forum Ibis
    Last Post: 09-23-2012, 11:24 AM
  5. Shimano XT 2x10 on Mojo HD
    By dustyman in forum Ibis
    Last Post: 10-16-2011, 04:51 PM
