Results 1 to 16 of 16
    Stripes
    Guest
    New question here. 2x10 Drivetrain question on the HD
    I love my HD, and the current drivetrain setup is:
    2x10 Shimano XT
    Double crankset with a 38/26T
    Rear cassette is a 11-36
    My problem is we have a lot of climbing here, and I would be happy running a 36/24, BUT... Shimano only offers these huge crunching chainrings in the 2x10, and in the 3x10 crankset has something like 40/30/22. I could always do the triple with a bash, but a 30/22 seems kinda silly.
    So I'm looking at Raceface and E13, but I'm not sure how compatible they are with the Shimano 10 speed drivetrain.
    I tried to do Raceface cranks and a Shimano 10 speed rear cassette on the Ventana, but couldn't get the chainline right. Using a chainguide was the only way I could do that before. I don't want to resort to running a chainguide as a bandaid (and adds resistance to the change).
    Would I run into this with the HD too?
    Thoughts on my alternatives? My knees most likely will appreciate it.
    40/32/24 is the Shimano DynaSys Chainring setup. 32 would run out pretty quickly on the road for myself. On the Trail I can run the 32 on everything.
    I have used Raceface Rings on a Sram drivetrain and they worked great.
    Nothing wrong with a Triple if your knees are bugging you. I run a triple with a K-Edge Chain Catcher, works great.
    Chain getting stuck on Mojo HD lower link.
    Lightly salted
    Reputation: fuenstock's Avatar
    This is a pretty cheap buy.
    Shimano XT M780 Oe Crankset > Components > Drivetrain > Cranksets | Jenson USA Online Bike Shop
    I ran xtr triples, 40/32/24 with a bash replacing big ring and a k-edge chain catcher. Trouble free, never had no issues with shifting. I was using a clutch rear der with it as we'll. Ended up going 1x10, but only for simplicity.
    Quote Originally Posted by Stripes View Post
    I had the same problem with the 38/26T on my XTR 2x10 crankset - the 26T was way too big a gear for my legs and the hills around here. So I just swapped out the 26T for a Blackspire chainring. It still shifts fine. (I didn't change the 38; sometimes it seems a bit tall, but then there are other times when I like it so I haven't bothered to change it yet. This is actually a bigger jump than the 14T the front derailleur is rated for, but it is working fine. You would be fine with a 38/24T.)
    Feb 2005
    I bought the XT triple setup and replaced the big ring with a bash guard. Was running bash/32/24 for a long time but recently picked up a Race Face 36. I also changed my front derailuer to a 2X. Everything runs great. Love having the extra high end range for downhills and my 24 for steep climbs.
    The MTB Lab
    Reputation: pastajet's Avatar
    Running the Shimano SLX 210 38-24 with 11-36 in the rear without any issues.
    [put something cool here]
    Oct 2011
    Quote Originally Posted by pastajet View Post
    Me running the Shimano XT 210 38-24 with 11-36 in the rear without any issues. My LBS set this up on my wish, I didn't bother with the actual origin of the 24 ring.
    Reputation: brankulo's Avatar
    Aug 2005
    shimano triple is 42-32-24. i used to run it as 2x10 with bashguard and 11-32 casette here in front range, co. lots of climbing here too. i am now on 1x10 and can not see myself going back to front shifter. you will only get stronger pushing bigger chainrings .
    Aug 2005
    ok, wasnt aware of that. however, you can always use some of the cheaper mods to rear cassette than xx1. general lee or one of the others
    Aug 2005
    i actually run 41 cog from ebay with 11-36 cassette. have over 2000 miles on it since this spring, no issues so far. $35 investment.
    Reputation: TahoeBC's Avatar
    Running a Sram 3x10 XO crankset with the big ring replaced with a bash guard 22 / 33
    Got kinda a crazy combination drivetrain but it works perfect, do use a small spacer on the derailleur though to get precise shifting. Works great with the big ring also but those things only last me a few weeks riding Tahoe before I grind off the teeth.
    XO 9 speed shifters
    XO 9 speed cassette 11-34
    XT 9 speed chain
    XT 10 speed front derailleur
    XT 10 Speed Rear derailleur
    XO 10 speed 3x10 crank with big ring removed.
    Cool, I'll see if I can get a 24T blackspire ring and see if it can cooperate with the XT 2x setup. That's what you're running right? You dind't actually say what size ring you're running The worst it costs me is a small chainring.Does Blackspire differentiate between 9 and 10 speed on their chainrings?
    Sorry about not mentioning the ring I'm using - it's a 22T. So I'm running a 38/22, which is 2 teeth more than Shimano rates the front derailleur but it's working fine. A 38/24 would be perfect.
    Blackspire does have a few different chainrings, so you would just have to pick the right one. Since I'm using an XTR double crankset, there is a ring specifically for that because it uses a different spacing. (I hear you can also just add a spacer.) I think you could just use their SuperPro rings Blackspire - SuperPro 104/64 BCD Chainrings | Blackspire, but you would want to make sure that's the right one for your cranks. They are pretty cheap at about $30.
    I see you you already have a RaceFace ring; that should work fine, too.
  1. 42/28 on 2x10 drivetrain?
    By kneetowaist in forum All Mountain
    Last Post: 03-15-2013, 01:11 PM
  2. WTF? 2x10 X9 drivetrain on HD problems....
    By circlesuponcircles in forum Ibis
    Last Post: 06-24-2012, 09:43 PM
  3. 2x10 frankenstein'd drivetrain
    By blue42blue42 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-01-2012, 07:36 AM
  4. RIP 9 & 2x10 drivetrain
    By scolli in forum Niner Bikes
    Last Post: 07-03-2011, 02:07 PM
  5. Paid Spam - SLX 2x10 drivetrain w/FSA 2x10 crank
    By mwb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-20-2011, 03:19 PM
