Results 1 to 5 of 5
    2015 Fox 32 Float 1 1/18 Steerer 27.5 fork for Mojo SL
    I have been riding 27.5 on my Mojo SL for five years now and my 2009 Fox 32 Talas was needing a complete rebuild. I started looking for options to replace it and after a few calls found out that this was doable.
    So here it is:
    -2015 Fox 32 Float 140mm 26" 1 1/8 steerer upper with 27.5 lowers.
    2015 Fox 32 Float 1 1/18 Steerer 27.5 fork for Mojo SL-imag1500.jpg2015 Fox 32 Float 1 1/18 Steerer 27.5 fork for Mojo SL-imag1497.jpg
    Here is what Fox says you are able to configure:
    32mm 26 forks can be converted to a 27.5 wheel by replacing just the lower. (All 27.5 lowers are 80 -150mm)
    34mm 26 forks cannot be converted, due to the fork crown offsets between 26 and 27.5
    36mm 26 forks cannot be converted, due to the fork crown offsets between 26 and 27.5
    40mm 26 forks can be converted to a 27.5 wheel by replacing just the lower.
    Thanks to the guys at Fox I will be riding this at Copper Harbor, MI(awesome place!) tomorrow. I will try and post up some videos to my You Tube site later.
    https://www.youtube.com/channel/UCM0...WYEDG1KoJrIrUw
    Reputation: mwandrusz's Avatar
    looks sweet! nice work Larry.
    Reputation: trap121's Avatar
    Mar 2011
    Can't you run 27.5 with 26' fox lowers? I've read on here that a lot of people have been doing this on their SL. Did I miss read somthing??
    Yes you can run some 27.5" tires in Fox lowers. I did it with my 2009 Fox 32 Talas. The clearance was tight. Since I was looking at getting a new fork and Fox offered to switch the lowers to the 27.5 for no charge, I jumped on it.
    Nov 2014
    A question. I am going to building up an sl frame soon. Was on the fence about going full 26, full 27.5 or 27.5f/26r.
    How's the clearance with 27.5 in the rear? What's the rim width and tire you are running?
    Did you have to limit the shock travel?
  1. Replies: 7
    Last Post: 07-08-2014, 08:08 AM
  2. 2015 Fox 32 Float 1 1/18 Steerer 27.5 fork
    By lml427 in forum Shocks and Suspension
    Last Post: 07-02-2014, 12:18 PM
  3. paid spam-2015 Fox 34 Float 140 CTD Fit 29" Fork
    By rockman in forum 29er Components
    Last Post: 06-06-2014, 10:17 AM
  4. Replies: 3
    Last Post: 02-17-2014, 05:34 PM
  5. Replies: 19
    Last Post: 06-19-2011, 02:58 PM
