Results 1 to 3 of 3
    2.4 Rubber Queens
    Just wondering before I buy a pair - how do they fit in a Mojo SL with RS 150 Revs? Currently running 2.35 Minion front and 2.2 Rubber Queen rear, but want to run these as they are pretty close to 650B in both size and weight, before I make the leap . So wondering if they'll fit in the rear without shimming the shock?
    Nov 2008
    I used to have 2.4F and 2.2R with FOX 140.
    No Problem in the Front but the rear tire rubs the seat tube. 2.4 will not fit (at least on my Mojo Sl Size M). I use XT wheels with 21 mm inner width. maybe with wider rims there will not be a problem...
    Hmm thanks Tal Kadouri . Wheels are Flow EXs so a bit wider so the profile might not be as tall. I'm guessing shimming the shock would let them fit if rubbing the seat tube was the only issue, something I would need to do for 650B
  1. Vee Rubber ?
    By fixgeardan in forum Wheels and Tires
    Last Post: 03-13-2016, 01:27 AM
  2. Vee Rubber
    By reformed roadie in forum 27.5
    Last Post: 09-21-2012, 07:16 AM
  3. queens diamond jubilee message
    By singlesprocket in forum Off Camber (off topic)
    Last Post: 08-17-2012, 05:21 AM
  4. To The Tahoe Kings And Queens And Assorted Know-It-Alls
    By dirtmistress in forum California - Norcal
    Last Post: 05-26-2012, 10:40 AM
  5. Hans dampf vs Rubber Queens (Trail king)
    By J273 in forum Wheels and Tires
    Last Post: 12-07-2011, 08:18 AM
