Results 1 to 14 of 14
    1 X 9 Speed Conversion
    Can anyone recommend a single speed front conversion for a XTR crank set?
    I'm looking to drop my front derailuer and run just the middle ring. I'm concerned with (2) things:
    Chain falling off and chain rub on the front sprocket guides from using both extreme gears (1 and 9)
    Thanks for any advice
    David
    MPI
    MPI is offline
    Reputation: MPI's Avatar
    Hi!
    I am using now E13 SRS+ which seems to run fine with 970 XTR crankset.
    http://www.kiva.org - Loans That Change Lives
    Keep Singletrack Single
    Reputation: willem3's Avatar
    Paul Chain Keeper or MRP
    Support Bend Trails
    http://bendtrails.org
    Phil's Trail Facebook Page
    https://www.facebook.com/PhilsTrail
    DWlink Fanboy
    Salsa ring dinger and blackspire inner chain plate - simple and effective.
    If using any of these, is there any noticable chain rub when using both extreme gears?
    David
    Happy when not-last.
    Reputation: MinskyBA's Avatar
    Tried the Blackspire Stinger first, but it didn't do a damn bit of good. The MRP system 3 works great - I use it with a Salsa bashguard.
    Yea, it'll rub a bit and the rollers will likely get chewed but nothing out of the ordinary.
    All your base are belong to ME.
    Reputation: ExpertCrasher's Avatar
    I use the MRP 1.x. Works great. The trick though is to run a spacer against the frame then the MRP then the BB cup, which is opposite of the instructions, otherwise it will interfere with the lower link.
    The Paul won't work with the mojo.
    Quote Originally Posted by ExpertCrasher
    What type of front ring are you using on your XTR cranks? It doesn't look stock.
    Thanks,
    David
    _dw
    _dw is offline
    I am running an LG1+ on the HD, but I've also set up an e*thirteen XCX and it fit perfect.
    dw★link
    Split Pivot
    @daveweagle -Twitter
    I'm running a Renthal chainring. They're relatively new to the MTB scene but well known for motocross stuff.
    Not to say you can't just use the middle XTR ring, I did for a while with no issues.
    holding back the darkness
    Reputation: subliminalshiver's Avatar
    Quote Originally Posted by _dw
    I am running an LG1+ on the HD....
    sneaky.
    On the HD, or your HD?
    Where did you get the red chain ring mounting bolts?
    Nice looking
    David
    Where did you buy your red chain ring bolts? What length works with the ZTR crank set?
    David
    I know it is a little pricey, but I have never had my chain come off. Several chain ring sizes avaiable also. Check out www.widgit.com.au
