Results 1 to 7 of 7
Thread: My new Ignition
    My new Ignition
    Here she is, introducing the brand new and re-designed Ibex Ignition. I bought this frame from Garvin as a warranty replacement for my broken Ignition. I bought a new crank-set and headset since it just seemed wrong to transfer my old ones from the other Iggy:
    All other parts (brakes, saddle, wheels, fork, etc.) are from the old frame. I set it up as as a 1X9 just like my previous bike:
    Quote Originally Posted by MiniTrail View Post
    back to bushings again on the rockers???
    Ehh?? This bike has sealed bearing cartridges on the main pivots. You don't have to take the bike apart to see the smaller ones where the rocker mounts to the frame on the seat tube (the black ring is the bearing seal) The cartridges on the lower pivot should be pressed into the frame on both sides and protected by the through-bolt connecting the chain-stays to the frame (just like the '09 Ignition) There better not be any bushings down there....I could remove the rear triangle to check but I think I'm just gonna confirm with Garvin before I start dismantling a brand new bike and messing up the torques on the bolts...
    The only bushings I'm seeing are on the minor pivots on the triangle.....just like I would expect to......is that what you are asking about? Why would you want cartridges there??? I mean, they probably rotate like what, fractions of a second of an arc?????
    '08 ignition had bushings in the spot I circled. '09 went to bearings and it was a noticeable improvement.Attachment 656211
    Nope....my '09 Ignition had nylon bushings in the spot you circled, not a sealed bearing cartridge. My '09 Iggy's sealed bearing cartridges went bad before my bushings did.
    But I think we can agree that both bushings and cartridges eventually will wear out.....I hope Ibex stocks up on bushing/bearing kits like all the other "major" bike companies....
    sorry but you are wrong about the '09 or didn't know what to look for
    and which is it on this frame? Nylon bushing or bearing
    It has sealed nylon bushing bearing cartridges thing-a-ma-bobs
