Results 1 to 5 of 5
    Caution;  Merge;  Workers Ahead! Help! 09 Ignition Super Bottom Bracket Question
    I have a bottom bracket failure on my 5 month old ignition super. Not too sure what I should look for to replace but I keep seeing 68 or 73mm x 113mm. I have the fsa Alpha crankset and need the bottom bracket. Untill I get this fixed, I can't ride. Can someone help me? Thanks in advance!
    "They Call Me Bone'z"
    Reputation: facelessfools's Avatar
    it is an isis bottom bracket. and the ignition is a 68.
    68 and 73 represent the width of the bottom bracket shell on your bike. and 113 is the length of the axle of the bottom bracket.
    i like the crankbrothers BB:
    http://www.chainreactioncycles.com/M...?ModelID=46382
    RAH!
    Thanks for the fast reply. That gives me a better idea of what i need!!
    you will need one of these for removal.
    http://www.pricepoint.com/detail/145...imano_ISIS.htm
    RAH!
    Cuánto pesa?
    Reputation: Jake Pay's Avatar
    (OEM) Bottom-Bracket: FSA BB-5000 w/ Outboard Bearings
